another must see new ev very cool
Things that fly
truckerzero   100 W
Post by truckerzero » Jun 03 2008 3:44am
need i say more?
ford explorer 12 mpg
pontiac sunfire 30 mpg
883 harley sportster 55 mpg
raze rc nitro buggy 196 mpg on 5% nitro methanol fuel
stryker electric rc plane 3.3 watts per mile@80 mph(too bad i cant ride on that thing)!!!
truckerzero   100 W
Re: another must see new ev very cool
Post by truckerzero » Jun 03 2008 3:48am
looks like a alltrax controller on the back just in front of the motor
truckerzero   100 W
Post by truckerzero » Jun 03 2008 3:58am
check these photos of a all electric plane
e plane.jpg (143.19 KiB) Viewed 3467 times
front of eplane.jpg (179.23 KiB) Viewed 1580 times
truckerzero   100 W
Post by truckerzero » Jun 03 2008 4:15am
no way is that a perm motor they are using for that plane the one so many like to use for their emotorcycle conversions
Doctorbass   100 GW
Post by Doctorbass » Jun 03 2008 8:54am
truckerzero wrote:need i say more?
wow! this is nice!!
i wonder the range or... flying time he get.. and what are the cells used...
maybe a future project! :wink:
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
TylerDurden   100 GW
Post by TylerDurden » Jun 03 2008 9:46am
Doctorbass wrote:maybe a future project! :wink:
+1
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
docnjoj   100 GW
Post by docnjoj » Jun 03 2008 5:31pm
Supposedly Don at one time was {selling or testing) his LifeBatts with this company. Dont know how it came out!]
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
Link   100 MW
Post by Link » Jun 03 2008 7:24pm
*mutters to self*
Hmm, now how do I make that collapsible and small enough to pass off as a backpack...
8)
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
tomv   100 W
Post by tomv » Jun 04 2008 12:05pm
Electric motors are so perfect for gliders ultralights that I think you will not find pure gliders in a few years. Some approximations
Glider gross weight: 500kg (300 glider, 100kg pilot, 100kg motor/batteries)
Glide ratio: 1:40
Energy needed to climb to typical tow altitude of 1000 meters: 500*10*1000 = 5mJ. Accounting for inneficiences that would be 2kWh batteries. New A123 prius pack would be good for two launches
No themalling cross country range then is 80km.
The cost/reliability/noise/polution/ease of maintenence is many orders of magnitude nicer than typical tow-plane or 2 stroke self-launcher setups.
This is so amazing that I think it will catch on like wildfire. You should see what a pain is to wait for two planes on a busy weekend...
This is getting a bit away from e-bike discussion. But anyway, really exciting stuff
vanilla ice   100 MW
Post by vanilla ice » Jun 04 2008 12:14pm
Combined with the typically-used-for-gliders winch or tug down the runway you could get even more out of it... if you could figure out how to connect it up with the prop there.
Drunkskunk   100 GW
Post by Drunkskunk » Jun 04 2008 12:56pm
I know there have been a few paragliders homebuilt with RC parts. those guys use LiCo batts for there weight savings.
+2 on future projects. :twisted:
truckerzero   100 W
Post by truckerzero » Jun 05 2008 2:55am
does any one know the average speed on these because i know with lithium pack they say they get a hour and a half flight time on the paraglider on the video i posted
truckerzero   100 W
Post by truckerzero » Jun 05 2008 2:56am
miles nice link i saw that plane on the internet but never seen the video cool !!
truckerzero   100 W
Post by truckerzero » Jun 05 2008 3:03am
what do you guys think
if well designed do you think electric would be safer and lower maintenence than a ice (other than the shorter range of coarse)
in other words less emergency landings because of motor/engine failure and less cost of upkeep because of man hours required to keep running
i know by talking to a airplane mechanic i know most ice engines are only certified for so many hours then they must be pulled out and have a thorough inspection and rebuild of all internal moving parts
bluthermal   1 W
1 W
Post by bluthermal » Aug 10 2010 5:42pm
I have not been to the Electraflyer website for a long time now, so this may not be accurate anymore.
The original Electraflyer trike and Electraflyer C did use the Perm 132 brushed motor. There is no way they were "modified" as sometimes claimed. They might be working on developing their own motors now.
Regarding the speed of the Electraflyer trike, I believe they use the Stratus 17.5 wing. Here's the link to the wing specs from the manufacturer of that wing. Typically you fly within the trim speed range, because it's efficient. http://www.northwing.com/stratus-wing.htm
I can't wait until these are reliable, affordable, have decent range, and are in common use. Way better than 2 stroke ICE in my opinion.
