Farfles Electric Ultralight.
Things that fly
fechter   100 GW
Re: Farfles Electric Ultralight.
Post by fechter » Oct 08 2017 10:20am
600lbs of thrust would make for some pretty impressive climbing performance.
I noticed you can reverse the motor. That might be a handy feature when landing in a short space.
litespeed   100 kW
Post by litespeed » Oct 08 2017 5:09pm
600 lbs would let you prop hang.....little 3D flying would be fun.
Tom
craneplaneguy   10 kW
Post by craneplaneguy » Oct 09 2017 12:46am
290 lbs sounds much more realistic, and still plenty to get the job done for that light plane, very cool.
Farfle   1 MW
Post by Farfle » Oct 09 2017 1:52am
After pulling the CA data, It sounds like there is another 20% power being left on the table by an amperage limit I had forgotten to change.
I will be back at the hangar next week to do some more testing, and ill also have my temp guage wired in by then which will give me much better instrumentation than swapping between the thermocouples one at a time by hand with a fluke meter im my lap.
Test Review Revise Repeat
Ohbse   10 kW
Post by Ohbse » Oct 09 2017 5:01pm
Awesome! Love everything about it. How do your results compare to the power/thrust curves available from conventional ICE powerplants others use in this chassis?
skeetab5780   10 MW
Post by skeetab5780 » Oct 13 2017 10:18am
I think about how scary it is to try the two wheeled inventions we create here on this forum, but you are taking It to a entire different level on this build! I cannot even imagine taking my hack work into the air for "testing"
It makes the hairs stand up on the back of my neck just thinking about it!
If I were you I'd bring a parachute! I will be over here with the popcorn waiting :)
craneplaneguy   10 kW
Post by craneplaneguy » Oct 14 2017 11:28am
skeetab5780 wrote:I think about how scary it is to try the two wheeled inventions we create here on this forum, but you are taking It to a entire different level on this build! I cannot even imagine taking my hack work into the air for "testing"
Not a pilot I take it? It's like anything else, safe enough if you know what you're doing. After 45 years of flying, I tend to take it for granted, and when I see a comment like yours I feel the need to kinda stand up for what we pilots do. We're not crazy risk takers or thrill seekers. Also, in the last 45 years I've known more acquaintances that have died in motor vehicle accidents then in their airplanes, getting in their car is the most dangerous thing most people do, but we do it a lot and take it for granted. Farles bird looks solid and well designed, he'll be fine. The great thing about light aircraft is the speeds involved are low enough to make a ground loop or botched landing a non event, injury wise.
MrDude_1   100 kW
Post by MrDude_1 » Oct 14 2017 8:58pm
Not a pilot here... but he lost me at bicycles being scary. :lol:
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
skeetab5780   10 MW
Post by skeetab5780 » Oct 16 2017 5:30pm
No im not a pilot haha and landing that may be safe if you have perfectly flat runway everywhere.. what about in the mountains or heavily wooded areas? You have to always be close to a safe zone
And i didnt say a bicycle was scary but apparently Mr dude aint scared of nothin’
Arlo1   100 GW
Post by Arlo1 » Oct 16 2017 10:49pm
skeetab5780 wrote:No im not a pilot haha and landing that may be safe if you have perfectly flat runway everywhere.. what about in the mountains or heavily wooded areas? You have to always be close to a safe zone
If you land in the tree tops at low speed you will not be hurt.
I would much rather have to find a place to emergency land this thing then a 737....
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
fechter   100 GW
Post by fechter » Oct 16 2017 10:52pm
A ballistic parachute might be one idea, but they are heavy, expensive, and have a nasty tendency to not work.
craneplaneguy   10 kW
Post by craneplaneguy » Oct 17 2017 8:11pm
For sure, over unlandable terrain a bit more altitude is advisable if reliability of the power plant is in question. More altitude, coupled with a working knowledge of the sink rate and glide ratio (and winds aloft) of the aircraft usually give a viable option if the fan quits turning.
Flying in general is so damn much fun, any risk is well worth it, but sure, keeping that risk down as low as possible makes sense. Sitting home on the couch is dangerous too, and I do a fair bit of that, punctuating the couch sitting with epic flights keeps me sane, and did I say, IT'S GREAT FUN!
MrDude_1   100 kW
Post by MrDude_1 » Oct 17 2017 10:15pm
Not true. someday my daughter will be a teenager.
riba2233   1 MW
Post by riba2233 » Oct 18 2017 1:51pm
Wow, impressive project!!
I've hosted my images on imgur.com for some time now, it's been very reliable.
I made a switch after imageshack went rogue, and I've also lost many images on forums. But photobucket has always been piece of shit, this isn't the first time images went missing.
Hillhater   100 GW
Post by Hillhater » Oct 18 2017 6:35pm
fechter wrote:A ballistic parachute might be one idea, but they are heavy, expensive, and have a nasty tendency to not work.
What about one of those inflateable Sumo suits, just in case ??
Sort of like a total personal airbag ! :shock:
The rebound bounce could be spectacular fun also ! :lol:
Farfle   1 MW
Post by Farfle » Oct 18 2017 6:57pm
High quality BRS's have an amazing track record, and this guy will be getting one. They are spendy, but worth it.
The system I am looking at is made by Ballistic Recovery Systems. They make systems from 600lbs up to 3700lbs.
Basically Its a rocket deployed parachute that has a 10 year lifespan and costs ~3000 dollars. They work big time, with 201 FAA recorded deployments at a 100% success rate.
http://m.aircraftspruce.com/catalog/app ... r600SP.php
The little 3x8x13" softpack lives in its anchor panel, which has 6-8 strands of high-tensile webbing that attach to the landing gear bulkheads, main wing struts, rear cabin bulkhead and front cabin bulkhead, so you can have complete structural breakup and as long as you remain attached to the most of the cabin, you are good.
liveforphysics   100 GW
Post by liveforphysics » Oct 18 2017 9:01pm
Farfle wrote:High quality BRS's have an amazing track record, and this guy will be getting one. They are spendy, but worth it.
18lbs?? Wear a few lbs body chute?
Farfle   1 MW
Post by Farfle » Oct 18 2017 10:06pm
Not super worried about the weight, as having one guves you a larger Part 103 weight budget, and I am still under max airframe weight by a hundred pounds. Plus, getting my arse out of this thing isnt exactly a speedy process just sitting on the ground :mrgreen:
Post by liveforphysics » Oct 18 2017 10:09pm
Sounds good!
Drunkskunk   100 GW
Post by Drunkskunk » Oct 19 2017 2:15pm
Damn this is awesome. Seriously awesome.
Farfle   1 MW
Post by Farfle » Oct 20 2017 3:18pm
Testing to see if google images as a host works:
https://photos.app.goo.gl/q6heDVZJJqO0dcpD2
Harold in CR   1 MW
Post by Harold in CR » Oct 20 2017 5:39pm
Works fine for me. You have a really neat project going on.
Thanks to Justin, the forum is open source and NON-commercialized.
Farfle   1 MW
Post by Farfle » Dec 03 2017 9:41am
Making more progress!
craneplaneguy   10 kW
Post by craneplaneguy » Dec 03 2017 6:15pm
Oratex for the covering? I couldn't tell by that quick shot of the roll. No paint or other coatings required, unlike virtually every other system out there. You save a ton of time plus don't need a paint booth. I've covered 5 aircraft, and all I can say about the process is anything to speed things up is worth looking into.
Farfle   1 MW
Post by Farfle » Dec 03 2017 6:33pm
Yup! Oratex ul600 it is. Stuffs not cheap, but neither is time on a weekend project. I also hate painting, and dont have the space or equipment
