Electric Surf Board
Boats, Jet Skis, Kayaks etc., including hovercrafts
FlorianAirs   10 µW
10 µW
Re: Electric Surf Board
Post by FlorianAirs » Aug 29 2019 12:57pm
Hello ,
i think i can post some pictures because the company is not anymore in buissines.
the setup from boost:
14S20P LG cells
MGN 400A
Don't know the brand of the motor but 95mm diameter
MHZ 64 Jet drive
setup of the AIR
14S20P LG cells
MGN 250A
Lehner torquestar 7050
MHZ 64 Jet drive
some pictures of the boost:
srn   10 W
Post by srn » Aug 29 2019 2:07pm
I thought the boost has an Torqstar 3 7050. Is it an inrunner on your pic of the boost motor ?
FlorianAirs   10 µW
10 µW
Post by FlorianAirs » Aug 30 2019 2:01am
the motor from the boost is an outrunner
Bazaki   10 kW
Post by Bazaki » Sep 01 2019 2:52am
I do have a new lehner torqstar for sale if anyone is interested. 7040 watercooled 320kv
aethyr   10 W
Post by aethyr » Sep 02 2019 2:52am
Florian,
Can you post larger pictures of the boost internals? The small pics are kind of hard to see the details :D
madin88   1 GW
1 GW
Post by madin88 » Sep 02 2019 5:01am
aethyr wrote:
Sep 02 2019 2:52am
Florian,
Yes please, and from the motor :)
It looks a bit like a larger version of the Torqstar..
would be interesting to know more about it, like which brand and where it could be bought.
fabianpusch   1 W
Post by fabianpusch » Sep 10 2019 12:50am
Wow, that looks really like a homemade production.
I will post a few pics from my board.
Will do it on the next weekend.
We are in Corsica and I will ride it for 2 weeks 😃
Blackdavid   100 µW
100 µW
Post by Blackdavid » Sep 20 2019 10:48am
Hello guys, just one quick question
That graupner jet 5, would one of those have the capability to move a surfboard with a 220lbs rider on the water? With a suitable motor, would it flow enough to plane on the water?Image
Bazaki   10 kW
Post by Bazaki » Sep 20 2019 3:11pm
No. Too small
Blackdavid   100 µW
100 µW
Post by Blackdavid » Sep 21 2019 3:32am
Bazaki wrote:
Sep 20 2019 3:11pm
No. Too small
What would you suggest?
Maybe if i put two of those, and twin motor?
bigbore   10 kW
Post by bigbore » Sep 23 2019 12:49pm
Did you see this?
https://www.mhz-watercraft.com/shop/en/ ... surfboards
It was used on old Lampuga Boost and Air
fabianpusch   1 W
Post by fabianpusch » Sep 24 2019 1:26pm
Hey at all
Today I have reached 23 MPH....was a good run in the early morning.
I have promised to send some pics...but how can I do that from my Android mobile?
Bye Fabian
PS the mhz 64 is a good choice
ropower86   1 W
Post by ropower86 » Oct 02 2019 10:26pm
@fabianpusch,
fabianpusch wrote:
Sep 24 2019 1:26pm
Hey at all
Bye Fabian
I think you need to upload the pics from the computer. Record a video and post a link. Also, I have a jet 64 but the only thing stopping me is the battery current is weak and the lids which I am having hard time making. Meanwhile, I bought an electric powered bodyboard in mid-summer.
chris_kline   100 W
Post by chris_kline » Oct 03 2019 6:22am
hit 75 kmph yesterday!
heres a video doing not quite full speed around 65kmph
https://youtu.be/BENxS1iLGjk
ropower86   1 W
Post by ropower86 » Oct 03 2019 11:12pm
chris_kline wrote:
Oct 03 2019 6:22am
Your skills are madness!!! You really have all the tools to make Sh## happen.
fabianpusch   1 W
Post by fabianpusch » Oct 05 2019 1:05am
https://youtu.be/hzqdDyQC6nw
Greetings from Corsica.
Your petrol powered board is amazing....really fast. Great job...and a perfect lake with best conditions. Where is it?
chris_kline   100 W
Post by chris_kline » Oct 05 2019 4:12am
fabianpusch wrote:
Oct 05 2019 1:05am
that looks awesome, really smooth!
how much run time do you get per charge? what size battery were you using?
fabianpusch   1 W
Post by fabianpusch » Oct 05 2019 4:22am
Runtime 15 minutes devided into 3 sessions of 4-5 minutes. Capacity was 53Ah, after the three runs 30Ah left. So from 100% SOC down to 60-63%.
The only limiting factor is the MGM. It is getting too hot after the 4-5 minutes. Now I am thinking about an additional cooling system.
It is running really well. Top speed was 40km/h.
In this video 36km/h.
Actually I am thinking about going back to my 15S configuration....still waiting for an answer from MGM.
Have send them the data with all the parameters to check...
chris_kline   100 W
Post by chris_kline » Oct 05 2019 4:37am
what part of your mgm was getting hot? the fets or the caps?
i was having problems with my caps, so i put a huge capacitor bank with watercooling on them and that seemed to solve it.
in the end i was having problems with my batteries getting hot, especially if i full throttle to 54 kmph, and some of my cells started to fail/internally short. i had 2 watercooling plates on my batteries, but i think i needed a bigger pack, was running 14s 12p, but having seen the lampuga taken apart here, seems i needed a 14s 20p
chris_kline   100 W
Post by chris_kline » Oct 05 2019 4:38am
so you were running a 17p battery? assuming your cells were 3000mah?
fabianpusch   1 W
Post by fabianpusch » Oct 05 2019 5:29am
Hi Chris,
No it is a 14S1P configuration.
The cells are KOKAM cells, each cell 53Ah.
The caps are okay, the internal temperature of the MGM says to hot...and then the power is automatically reduced.
How did you solve the cooling of the capacitors, sounds really interesting to me.
fabianpusch   1 W
Post by fabianpusch » Oct 05 2019 5:30am
So the FETS are going too hot, sorry missed that...
chris_kline   100 W
Post by chris_kline » Oct 05 2019 6:10am
fabianpusch wrote:
Oct 05 2019 5:29am
Hi Chris,
i have watercooling plates on the batteries, ill take a photo tomorrow. and the external caps bank just lays between the cooling plates.
thats strange that the fets are overheating, how much water are pumping through the mgm cooling plate? i never had a problem with the fets getting hot
fabianpusch   1 W
Post by fabianpusch » Oct 05 2019 6:18am
Okay, thats interesting.
I have never measured the waterflow. On the next Saturday I have planed to do some tests.
Water bypass from the jetdrive vs. 12v waterpump.
I think it should be possible to make that test stationary.
Watercooling is really difficult to handle because of the height..only 10mm left.
chris_kline   100 W
Post by chris_kline » Oct 05 2019 6:43am
yeah, check the waterflow, the fets on mine never get hot, also what motor timing are you using? more degrees timing keeps the fets cooler, but gets the battery and motor a little hotter.
how much did that battery cost, looks like the proper shiz
