Electric Surf Board
Boats, Jet Skis, Kayaks etc., including hovercrafts
toto44   100 mW
Re: Electric Surf Board
Post by toto44 » Aug 19 2018 2:39pm
Today I tested my 3D printed jetdrive. Could not do any measurements, but gives a lot of power.
https://youtu.be/NewKjySw2ko
srn   1 W
1 W
Post by srn » Aug 20 2018 1:56am
Hello toto44,
good video, looks like a lot of thrust for this small motor. Do you have a log of motor/esc power during this run ?
srn   1 W
1 W
Post by srn » Aug 30 2018 3:37am
Hello,
i changed my carbon impeller to a 3D-printed steel impeller. It is really impressive quality and less vibration.
today I will make first measurements of power consumption. Will provide results later.
madin88   100 MW
Post by madin88 » Aug 30 2018 4:37am
srn wrote:
Aug 30 2018 3:37am
Hello,
how much did it cost?
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
srn   1 W
1 W
Post by srn » Aug 30 2018 6:44am
madin88 wrote:
Aug 30 2018 4:37am
I ordered a 62x62mm. They said that it will shrink 2-3% after thermal treatment and finally I got a 60.5 x 60.5 impeller.
It is ~95€.
toto44   100 mW
Post by toto44 » Aug 30 2018 10:04am
Hello SRN
what pitch does your impeller have? Did you balance it?
srn   1 W
1 W
Post by srn » Aug 31 2018 9:36am
toto44 wrote:
Aug 30 2018 10:04am
Hello SRN
Hello toto,
the pitch is 60mm or equal to D if you scale it.
I have not balanced it yet.
ropower86   1 W
1 W
Post by ropower86 » Sep 02 2018 2:24pm
srn wrote:
Aug 30 2018 3:37am
Hello,
How much did it cost you to 3d print in metal?
srn   1 W
1 W
Post by srn » Sep 03 2018 12:36am
ropower86 wrote:
Sep 02 2018 2:24pm
It is ~95€.
srn   1 W
1 W
Post by srn » Sep 05 2018 12:06pm
hello guys,
i am still testing in my small pool.
now my remote control is working fine. Also the new propeller is doing a very good job.
here my current MGM log. I wonder that I have really small power consumption at 10.000 rpm. At the moment I limited the MGM to 10k rpm for testing. Will try 12k rpm in a bigger pool soon.
fabianpusch   10 mW
Post by fabianpusch » Sep 05 2018 2:40pm
Hi
are you sure that there is really load on the system?
It seems to be really a too low power consumption.
Could be an issue of water mixen with air, less stress for the motor to handle / put through your jet...
On the other side, try to accelerate up to 14000, and measure the pulling force.
Christyy   1 µW
Post by Christyy » Feb 19 2019 3:59am
Hello, about electric surfboards, and more specifically to buy one. What do you think of these https:// awakeboards.com, is it worth investing?
fabianpusch   10 mW
Post by fabianpusch » Feb 22 2019 1:45am
It is absolutely clear, you have an issue with a mixture of water and air.
Normally you should have during ramp up by 10000 rpm something between 120-160 Amps.
fabianpusch   10 mW
Post by fabianpusch » Feb 22 2019 1:46am
Important, not the peak Amps....the real Amps from the battery
