Electric Surf Board
Boats, Jet Skis, Kayaks etc., including hovercrafts
chris_kline   100 W
Re: Electric Surf Board
Post by chris_kline » Oct 20 2019 12:43pm
srn wrote:
Oct 20 2019 5:56am
I have a 3D printed steel impeller. Ordered it at i.materialise.com
There you can upload your file and instantly get a price.
The print quality is impressive
great thanks, i will try them.
fabianpusch   1 W
1 W
Post by fabianpusch » Oct 21 2019 1:21pm
One question:
When I have printed something from metal there was a shrinkage.
I have checked i.materialise.com what was the shrinkage there?
I think this is still something unknown with steel?
srn   10 W
Post by srn » Oct 23 2019 3:46am
fabianpusch wrote:
Oct 21 2019 1:21pm
One question:
Hello,
i.materialise writes:
As the production of your steel model involves a thermal step, shrinkage is something you should take into account. We advise you to scale up the desired design by 2% for designs where X, Y or Z is below 70 mm and 3% for models which are larger. This larger scale will compensate for the shrinkage and as a result, the dimensional accuracy will be ±1%. This is an indication but it cannot be guaranteed
I scaled my impeller accordingly and got a good result.
For the shaft I made the hole smaller then needed and drilled it afterwards to the right size including screw thread.
chris_kline   100 W
Post by chris_kline » Oct 23 2019 9:52am
hi guys
i made a full video, jetsurfing at the beach.
https://www.youtube.com/watch?v=hpW3-ppHwgc&t=2s
fabianpusch   1 W
1 W
Post by fabianpusch » Oct 23 2019 1:28pm
Once again, big congrats from my side.
Good job, nice ride, cool video and a nice spot.
I would like to talk to you about your jetpump.
If it would be ok for you :D
chris_kline   100 W
Post by chris_kline » Oct 23 2019 2:26pm
fabianpusch wrote:
Oct 23 2019 1:28pm
thanks fabian.
feels good to finally have a working board.
sure, what would you like to know?
fabianpusch   1 W
1 W
Post by fabianpusch » Oct 24 2019 12:06pm
I am trying to build up a pump. The problem is the CFD actually...I am not sure where to start.
Second, I have already tried to print one in metal.
Big fail because of the supports, needed to build up the impeller.
Which diameter are you using?
What are the main specs?
Maybe it is possible to give you a short call instead of trying to write a proper English 😄
chris_kline   100 W
Post by chris_kline » Oct 25 2019 6:01am
fabianpusch wrote:
Oct 24 2019 12:06pm
tbh my skill with CFD is basic/beginner, i can do a simulation on something simple like a tube, or a fin, but to do an entire jetpump, with moving parts etc is well beyond me.
to design my pump i used simple 2d calculations for torque, flow volume, inertia etc. which gave me perfect thrust and engine loading from the start. but what it didnt account for, was cavitation which has been a bit of a headache trying to solve. esp as seawater cavitates more easily than freshwater.
the way i got around that was just by machining in total 4 different moulds for props, each with different pitch on the blades, to keep max torque and thrust the same, each prop has a different size nozzle.
the design i ended up on is 87mm diameter, 80mm pitch, and a 50mm nozzle. the inlet port of the pump is a little larger in cross sectional area to cut down on cavitation and accelerate the water into the pump, a little bit of positiove inlet pressure from forward movement helps to cut down on cavitation.
if you like i can send you my 3d models for you to look at.
or i can give you my phone number by PM if you like. let me know
fabianpusch   1 W
1 W
Post by fabianpusch » Oct 25 2019 7:01am
Hi Chris
Both would be fine for me and a big help.
Actually I have an offer from China 1200$ for an Impeller because of the complex geometry (CNC).
Maybe I am actually doing an overengineered solution.
I am really interested in looking at your files.
My private E-Mail
fabian.pusch@googlemail.com
I will have a look at your data and give you a call.
When would be the best time for you?
Thanks a lot
Fabian
chris_kline   100 W
Post by chris_kline » Oct 25 2019 10:46am
no probs.
what format is good for you?
ill find the drawings and compile them together for you over the weekend
fabianpusch   1 W
1 W
Post by fabianpusch » Oct 25 2019 11:00am
Perfect, I have Catia V5, so Stl., Step, Iges.,...nearly any format.
Please, if it is ok for you, send me your number.
I would like to talk to you....maybe we can go one step further...
Have a nice Friday evening
Fabian
fabianpusch   1 W
1 W
Post by fabianpusch » Nov 01 2019 6:01am
Hi Chris
Any news?
Did you already sent an email?
Cheers Fabian
chris_kline   100 W
Post by chris_kline » Nov 04 2019 7:57am
fabianpusch wrote:
Nov 01 2019 6:01am
Hi Chris
Any news?
Cheers Fabian
hi fabian.
sorry mate, ive been real busy with work etc the last week.
ill see if i can get it to you by tomorrow
pepe pisa   10 µW
10 µW
Post by pepe pisa » Nov 04 2019 11:53am
Hello guys, then nobody who has a lampuga boost ??
fabianpusch   1 W
1 W
Post by fabianpusch » Nov 05 2019 4:47pm
No sorry...I have my home made one.
fabianpusch   1 W
1 W
Post by fabianpusch » Nov 06 2019 1:39am
chris_kline wrote:
Nov 04 2019 7:57am
fabianpusch wrote:
Nov 01 2019 6:01am
Hi Chris
Any news?
Cheers Fabian
hi fabian.
Sorry for writing an additional message 😜
chris_kline   100 W
Post by chris_kline » Nov 06 2019 4:57am
fabianpusch wrote:
Nov 06 2019 1:39am
chris_kline wrote:
Nov 04 2019 7:57am
fabianpusch wrote:
Nov 01 2019 6:01am
Hi Chris
Any news?
Cheers Fabian
hi fabian.
drawings sent
fabianpusch   1 W
1 W
Post by fabianpusch » Nov 07 2019 11:02am
Yes you are right and a lot of E-Mails too.
Thank you, will follow up with one tomorrow 😃
jetsurfer   1 µW
Post by jetsurfer » Nov 13 2019 12:02am
Hi All
I'm looking for a 100mm or so Jetpump to build my DIY jetboard
Below is Motor, ESC, Battery setup I'm planning to use what do you think I should use for the jet pump?
Proposed Materials
Batteries 15 (Maybe 16s) x 60ah 3.2v Lipo4 cells 3.3KW - $980 https://www.aliexpress.com/item/4000067 ... 2e0eewN5LL
Waterproof ESC Seal 300A 60V ESC Motor controller - $376
https://www.aliexpress.com/item/4000092 ... 2a06jcyBBa
Water Cooling Motor 9097 150KV 18KW 24HP - $914
https://www.aliexpress.com/item/4000073 ... 88edAolPzs
methods   100 GW
Post by methods » Nov 13 2019 3:10pm
Epic project!
You are literally "Living my Dream" right now. Thanks for posting pics. . . that is about what I pictured... but you got a lot farther into the project over the years.
... I can tell that I am going to need some support that exceeds my current fab skills/resources.
- It has got to be light
- It has got to be quiet
- It cant eat my knees :mrgreen:
I will post later when I get the trolling lower end zip-tied to the old Boogie Board. One thing I have found is:
The small props scream like hell to get the thrust I need. . . so I am going "Big Prop"
-methods
Increasing battery voltage and controller current limit will result in a non linear experience
pepe pisa   10 µW
10 µW
Post by pepe pisa » Dec 27 2019 6:50am
methods   100 GW
Post by methods » Dec 27 2019 12:51pm
Hardcore video.
Lots of hints in there.
I am still visiting the "Marine Flea-market" down at the harbor waiting to find a set of pull-down thrusters. It is looking like anything that comes off of a power boat (that actually puts out some useful thrust) is very heavy and industrial. Makes sense - as in the power boating around here (fishing, crabbing) weight seems to be of little concern. It seems that the pull-down gear is focused on low cost and reliability, so large castings and standard windings.
The... sailing gear... is actually the polar opposite. Carbon fiber toilet seats and all that "save a gram" stuff going on.
I imagine...
That some rich guy...
No doubt bought a $7500 piece of gear at some point for his $300k race boat...
...And it is only a matter of time until I can pick it up used gem for a few hundred bucks....
Large racing sail boats - I have seen them park... some of them no doubt have thrusters...
-methods
chris_kline   100 W
Post by chris_kline » Jan 08 2020 3:31pm
look at that giant external caps bank on the mgm esc.
when my caps kept blowing, mgm were telling me "its your batteries, its your motor, its everything except the ESC", and charging me stupid amounts of money to repair and replace.
turns out lampuga also had problems with the caps exploding. hence the external caps bank
fabianpusch   1 W
1 W
Post by fabianpusch » Jan 10 2020 6:49am
Hi Chris
Has always been the battery, the length of the cables,...
At the moment I have to additional banks and it is working.
By the way, I have bought a Jetsurf ;-)
Cheers Fabian
chris_kline   100 W
Post by chris_kline » Jan 11 2020 7:51am
fabianpusch wrote:
Jan 10 2020 6:49am
Hi Chris
Cheers Fabian
awesome. which model did you get? new or second hand? how is it to ride?
