I have been running a large Turnigy motor on 24V through a RC controller of unknown make marked only with 80/100, it was in my 'it'll come in handy one day' box. The controller has a finned ally casing and is mounted in a die cast ally box with no provision for cooling as I am only drawing 12A from the batteries and thought temperature rise would not be an issue. However, after about 30mins running the controller starts to fail and can be reset by switching off for a few seconds, whereby it will run for some time before the problem re-occurs. I could mount it such that there is a better heat sink but am quite prepared to purchase a more appropriate ESC as I would prefer one with reverse and one that does not require a 'servo tester' to control it. I require only 300 watts normal cruising with occasional bursts of say 600 watts.
I have noticed that Castle Special Projects manufacture a controller 'The Monster Mamba' which appears suitable, but your comments and suggestions would be most welcome.
Geoff V
Geoff V
