Electric Hydrofoil/E-Foil
Boats, Jet Skis, Kayaks etc., including hovercrafts
bbq870   10 W
Re: Electric Hydrofoil/E-Foil
Post by bbq870 » Jun 22 2017 9:42am
what about a jet engine?
high RPM and no need for gear reduction. I think that every additional part eats up efficiency.
would a jet be better? (longer runtime?)
dirkdiggler   10 kW
Post by dirkdiggler » Jun 22 2017 11:41am
Oh so close! Good job! Still one of the few working boards. You should be proud. I always ask my kid to try my creations, and they politely decline. How nice would it be to weigh 80 lbs sometimes.
fechter   100 GW
Post by fechter » Jun 22 2017 2:39pm
There are a few out there already. Maybe good to copy.
https://www.liftfoils.com/
https://www.youtube.com/watch?v=1yEmtz4ZVMM
Jezza   10 W
Post by Jezza » Jun 23 2017 3:23am
fechter wrote:There are a few out there already. Maybe good to copy.
Hi Fechter, if you look on the first page, you'll see that that's what we are basing our designs off.
Jezza   10 W
Post by Jezza » Jun 23 2017 3:26am
bbq870 wrote:what about a jet engine?
While a jet is a bit simpler in terms of construction, it has a much lower efficiency when compared to a prop.
Isham.padron   1 µW
Post by Isham.padron » Jun 29 2017 7:18am
Hello. I'm new to this forum and have a couple questions but first a lil bit of background. I am a designer with a number of 3D printers large and small and I want to build an efoil type board. My questions are:
Can a trolling motor be converted to operate like an efoil?
What kind of thrust is needed to get you riding and what are the thrust specs on the efoil?
Here is a trolling motor that I found on Amazon. https://www.amazon.com/dp/B00VYP3R82?psc=1
I was thinking I could design and 3d print the foil/wing and infuse that with resin. Buy the motor and attach that to a board. Then build some kind of remote using one of those power skateboard controllers. Forgive my ignorance as I dont know much about this kind of thing but I'm interested in the build.
Thanks
Ish
Jezza   10 W
Post by Jezza » Jun 29 2017 9:07am
@Isham.padron - The problem with trolling motors in general is that they are not designed for speed.
From msk8's last youtube video where he manages to get up on the wing, you can see that he needed around 1.6kW of power. In terms of thrust, I'm not quite sure what the calculations would be.
Jezza   10 W
Post by Jezza » Jun 29 2017 9:10am
On another note, all my electronics have now arrived! I think I will proceed as follows:
- Test Electronics
- Print and assemble motor housing
- Build hydrofoil (wings, fuselage and baseplate)
- Fit to board
- Go flying :)
parabellum   10 MW
Post by parabellum » Jun 29 2017 11:41am
Isham.padron wrote:Can a trolling motor be converted to operate like an efoil?
This motor is about 300W and probably brushed, which makes it impossible to push far out of its design performance limits. I cooked seadoo torpedo brushed motor in 1 min, just doubling the output.
Anyway, something similar designed for 2000W from start on, could make a great platform for efoil.
Bazaki   10 kW
Post by Bazaki » Jun 29 2017 12:20pm
https://www.amazon.com/Caroute-N400-48V ... B01EZTR6VM
There is this brushless trolling motor. Different prop and probably it can do it.
ropower86   10 W
Post by ropower86 » Jun 29 2017 1:44pm
You guys are making a good move on this project as of finalizing the hard part of the jet foiler. It makes more sense to build a E-foil than the jet board as for now. Last night I made a plexi waterproof box specifically for the ESC, so no contact with the water if the board gets submerged. I'm just going to remove the jet drive and refabricate the compartment for the ESC and the hydrofoil mount. I will be posting more better video's.
https://youtu.be/iWc6zFIvtB0
By the way the board is updated. almost close to done until now, turining it into a hydrofoil.
I have accsess to a small laser cutter, Small CNC 3 axis mill and a 4 axis wood cnc. Please give some idea what I can do to utilize these machine to make parts to keep cost low.
ropower86   10 W
Post by ropower86 » Jun 29 2017 11:52pm
Have an idea, what about using 2 gears like drive gear and driven gear to run the bigger diameter prop instead of using the planetary gear setup? My 300a ESC just got in today and I have a gear drive setup to the brushless motor about to design a prop and PLA 3d print it.
dirkdiggler   10 kW
Post by dirkdiggler » Jul 05 2017 2:01pm
fechter   100 GW
Post by fechter » Jul 05 2017 2:17pm
Nice! That thing really lifts out of the water.
ropower86   10 W
Post by ropower86 » Jul 06 2017 7:58am
Check this site out, a Torqueedo planetary gear box is a lot cheaper but I don't know how long it would take to come in the mail. Better than paying over $300. :roll:
http://www.torqeedo.com/us/en-us/produc ... 00005.html
dirkdiggler   10 kW
Post by dirkdiggler » Jul 07 2017 3:45pm
yoyoman   1 kW
Post by yoyoman » Jul 07 2017 5:54pm
$5000-$7000 on alibaba
bbq870   10 W
Post by bbq870 » Jul 09 2017 7:54pm
many times they put (non-exiting) products online to see the customer feedback.
even show it ready to order. but will just produce it when enough people buy it.
2000-3000$
an other supplier
https://m.alibaba.com/product/606682766 ... .20.DSyqg2
anbat8   1 µW
Post by anbat8 » Jul 11 2017 11:23pm
Hello guys,
First, I would like to thank you for all the information that you gave concerning the construction of a efoil. It's very amazing!
I saw another electric motor (competitor of Torqeedo) which don't use a gearbox and deliver approximately the same performance than the Torqeedo.
Torqeedo Travel 1003: http://www.torqeedo.com/us/products/out ... 42-20.html
epropulsion spirit 1.0: http://www.epropulsion.com/spirit-support#spirit-specs[/b]
According to you guys, which electric motor on hobbyking will give the same spec than the epropulsion spirit 1.0 in order to avoid the gearbox (speed reducer) in a construction of a efoil motor?
Thank you,
Jezza   10 W
Post by Jezza » Jul 12 2017 5:16am
anbat8 wrote: According to you guys, which electric motor on hobbyking will give the same spec than the epropulsion spirit 1.0 in order to avoid the gearbox (speed reducer) in a construction of a efoil motor?
Thank you,
Hi anbat8, quite simply there isn't a motor on hobbyking that will allow you to avoid a gearbox. That spirit motor appears to be around a 50KV motor (allowing for inefficiencies). Its completely custom built for epropulsion. You'd have to custom wind a motor to try and achieve something similar or alternatively buy the lower pod from the spirit motor and hope it works.
nanni   10 mW
Post by nanni » Jul 12 2017 7:05am
dirty_d   10 kW
Post by dirty_d » Jul 12 2017 1:55pm
I've been toying with the idea of making one of these. I've ordered a kit from http://www.clearwaterfoils.com/ already. I'm going to just use it as a wake foil behind a boat for now. The thing that's holding me back from making an electric one is the gearbox. Even the one that pacificmeister used doesn't look like it was made to handle the power of that motor. I don't think it will last long. I was thinking maybe go direct drive with a small impeller and jet pump, but I think at 20,000rpm or so there would be really bad cavitation.
fechter   100 GW
Post by fechter » Jul 12 2017 2:15pm
dirty_d wrote:I've been toying with the idea of making one of these. I've ordered a kit from http://www.clearwaterfoils.com/ already. I'm going to just use it as a wake foil behind a boat for now. The thing that's holding me back from making an electric one is the gearbox. Even the one that pacificmeister used doesn't look like it was made to handle the power of that motor. I don't think it will last long. I was thinking maybe go direct drive with a small impeller and jet pump, but I think at 20,000rpm or so there would be really bad cavitation.
Maybe not with the right impeller design. Implanted heart pumps can run up to 15k rpm without cavitation. Instead of a more conventional propeller-like arrangement, it looks more like a screw with a housing around it.
bbq870   10 W
Post by bbq870 » Jul 12 2017 3:23pm
how/where can I find an "efficient" jet drive?
and how much less efficient are they compared to impellers?
edit:
for an impeller, would it make sense to rewind a motor to have less RPM?
anbat8   1 µW
Post by anbat8 » Jul 12 2017 8:58pm
No, did you tried one of these? Is it reliable?
Thanks
