Thruster/ generator from alternator?
Boats, Jet Skis, Kayaks etc., including hovercrafts
Islandmode   1 µW
Post by Islandmode » Mar 03 2018 8:35pm
Hello all :mrgreen:
Looking for some experience and knowledge here and appreciate any reply.
I have a small sailboat with a center channel space in bow for a paddle wheel prop. My goal is to put an electric motor here for low speed auxiliary thrust. I would like it to recapture energy when under sail or engine power.
My previous attempt to wire an old trolling motor went up in smoke when i over revved it running outboard petrol motor at speed.
Now i have an old three phase AC condensor fan motor, and a Chevy 100amp alternator in my parts shed.
From whatvl read both can be converted to motors, but the AC fan is improbable as a generator.
What do i need to know about using an alternator to create thrust and also generate power. I am running on a single 12v deep cycle Lead Acid battery. I would like to have control over maybe three speeds (have a left over speed controller :wink:
How far fetched is thisor is it doable?
amberwolf   100 GW
Re: Thruster/ generator from alternator?
Post by amberwolf » Mar 04 2018 4:32am
In case no one else drops by, some of these threads may have info on converting the alternator:
https://endless-sphere.com/forums/searc ... mit=Search
Islandmode   1 µW
Post by Islandmode » Mar 07 2018 7:18pm
I am thinking now i would be better converting an mid mount ebike motor, a lot of work and watts to make an alternator work.
Just wondering if i can get decent torque from 12v, maybe 24 Jack Bauer
eCue   10 kW
Post by eCue » Apr 06 2018 9:48am
This guys method of operation might work for your sailboat
Solar charge station on wheels join the Revolution
