Husky conversion
Boats, Jet Skis, Kayaks etc., including hovercrafts
Rickard m   1 mW
Husky conversion
Post by Rickard m » Feb 13 2019 3:38pm
My dad had this beautiful outboard motor from 1961 standing for many years, he found it in the trash.. I need a new winter project so I took it :wink:
fit nice under the lid
Some paint,
fit good
Had a sprocket that fited to the axle, welded on a 12mm socket, that fit to the original drive shaft.
the prop was quite beaten up
reparied it with melted zinc, made a stainless steel form
as new
battery guage fited to the choke slot.
Now I just need to build a boat... :roll:
Hillhater   100 GW
Re: Husky conversion
Post by Hillhater » Feb 13 2019 4:31pm
Excellent conversion, very skilfully done.
You are a very talented welder.
What motor did you use ?
I suspect the boat will be a classic wooden design ?
Rickard m   1 mW
Post by Rickard m » Feb 13 2019 4:56pm
Thank you! Probably looks better on picture :oops:
It is the Golden motor Model: HPM3000B -- BLDC Motor
1. Voltages: 48/72V
2. Rated power: 2-3KW
3. Peak power: 6KW
4. Speed: 3000-5000rpm
5. Rated torque: 10 Nm
6. Peak torque: 25 Nm
7. Efficiency: >90%
8. Dimensions: 18cm dia. 12.5cm height
9. Weight: 7.3kg(air cooled)
Yes it will be a retro plywood boat, but with little modern shapes. small one. 2,5meter long
sgulond   1 µW
Post by sgulond » Feb 28 2019 3:59am
Nice Work!
I like to see things in a second life instead of trashing.
Saving resources is really what the world needs. Greta woukd like it.
