Advice on Minn Kota 48V system
Boats, Jet Skis, Kayaks etc., including hovercrafts
Wolfeman   100 W
Post by Wolfeman » Feb 23 2019 1:21pm
Good Morning All,
My father in law has a 48V Minn Kota electric outboard attached to an older beautiful 14' Montgomery Ward aluminum hull boat. He currently powers it with 4 12V lead acid packs. His question is; could he use the on-board 48V charger to charge a lithium pack of similar voltage? Thanks in advance guys.
M
Trek 4300 w/ H3580 Crystalyte at 3600W
viewtopic.php?f=3&t=82738
Worksman Mover M2020-3CB w/DD 750W front hub
viewtopic.php?f=3&t=96873
Dyno Moto 7 BMX Cruiser w/BBS02
viewtopic.php?f=6&p=1467001#p1467001
GT Palomar Vintage hardtail w/BBS02
viewtopic.php?f=6&t=104255
Chalo   100 GW
Re: Advice on Minn Kota 48V system
Post by Chalo » Feb 23 2019 2:13pm
Wolfeman wrote:
Feb 23 2019 1:21pm
Good Morning All,
M
If the lithium pack has BMS with charge balancing, and the cells are well able to take the charge rate, and the maximum voltage is correct, then it would probably work with a "dumb" constant voltage charger. If it's the not-quite-as-dumb hiccup type charger, then probably not.
