Chargery C10325 24s 1500w
Get real world experience and user feedback on the electric bicycle products.
Ianhill   10 MW
Post by Ianhill » Sep 23 2020 7:06am
Had a 500w charger fail thats never good news, but i didn't like the fact it had a green and red led that was it as to see what it was doing so i wanted something with a display and configurable for differing rides.
I searched about and came across the chargery used on cake bike and it was perfect for my freerider I could reduce my charge time from 2 hours to as little as 40 mins in theory, the current battery uses sony vtc3 cells its getting old now and I'm not going to stress it by fast charging and I've not inspected the bms to see it's max specs either but in time when the bike gets re'celled there's big room for improvement on the charge turn around so I bought it.
It's got all the settings I need and my initial thoughts after the first charge is it's really quiet compared to the stock air plane my bike came with and at double the price it's triple the power so I'm happy with that and this looks like it could be repaired not like my old stock charger potted the complete board to the case.
Only thing I will change is the charge lead I don't like how a lead comes out the front to a connector it should have just been panel mounted to save a possible cable failure at the grommet, so I plan to use panel mount Anderson powerpole connectors 45amp and make a double ended universal charge lead worked either way round as I got the same connectors on my bike, I've ordered the bits when it turns up I'll get a few more pics up of the guts with the front panel off and the mod.
Ham   1 kW
Re: Chargery C10325 24s 1500w
Post by Ham » Nov 20 2020 4:42pm
Had mine since about July. Great charger...until earlier today when it made some whirring and fizzing noises then tripped the fuses in my house.
Does it every time now and smells like burnt electrics.
Charged my battery about 10 to 15 times to date. Waiting to hear back from my UK seller to see what the warranty requires...
http://www.HamsFitness.com Strength, Conditioning & Diet
Ianhill   10 MW
Post by Ianhill » Nov 20 2020 4:57pm
Ham wrote:
Nov 20 2020 4:42pm
Andy Kirby? Best of luck by there fella.
Never had a reply with a few issues.
I got mine because it looks repairable compared to most units take it a decent psu repair shop and it will be alive again don't worry to much.
Cheer for the heads up I'll keep an eye on mine I try to nanny it keep it in a cool dry area.
What charge volts and currents were you using if you dint mind me asking ?
Ham   1 kW
Post by Ham » Nov 20 2020 5:40pm
Yes it was from him at cloudsto. Let's see what happens. I'll not hold my breath then!
I do have a guy that may fix it for me if i can convince him to... waiting to hear back there too. I seem to spend a lot of time waiting on folk:)
I charge up to 58v and 10amp for my pack. I had read of some blowing capacitors capacitors i think... or maybe some other component that was said to be simple enough to replace for those skilled in that.
Ianhill   10 MW
Post by Ianhill » Nov 20 2020 6:44pm
Ham wrote:
Nov 20 2020 5:40pm
54.6v I end up at same 10amp as you, keep us posted how you get on best of luck fella.
Ham   1 kW
Post by Ham » Nov 21 2020 1:47am
Sure will:)
Ianhill   10 MW
Post by Ianhill » Nov 21 2020 7:22am
If i was you I'd have a look myself for any obvious signs remover the board and power up on the bench look for that sound and pinpoint the area.
It sounds like the fault I had on my stock chsrger I'd turn on and make a crackling arc noise and never power up the secondary side in any meaningful way.
I got one of these becuase it was not potted up like my stick charger the components look swappable but you got me worried now on it reliability.
My warranty is gone too cuz I've swapped the lead on the front and trimmed the toggle switch down 4mm
Ham   1 kW
Post by Ham » Nov 21 2020 8:49am
I may have to at some point. Cant power it up at all as it trips house fuses even trying to plug it in at the wall.
Ianhill   10 MW
Post by Ianhill » Nov 21 2020 12:10pm
Ham wrote:
Nov 21 2020 8:49am
So its the primary side that is shorted that limits the problem to the vac side of the board long as there's no damage to the circuit board it's should be fixable, major inconvenience though I was off the road August onward missed some good weather too
Ham   1 kW
Post by Ham » Nov 21 2020 12:20pm
Good to know...thank you:)
