Kingfish
Greetings
I presume someone has talked about this board before and yet I cannot find a reference to it. Abstractly, this is the new Infineon 6FET 25A board from eBikes.CA. You can find it available here:
TOP VIEW
Board ID: EB777XC-080918(350W)
BOTTOM VIEW
New pads located right side between GND-1 and EBS: P20, P21, P22
The packaging (e.g. the extruded box) did not have anything on it, no label, no nuthin’ except the R_Shunt value. Minus one star; I don’t care that I know what I ordered – I expect proper labeling of product.
Confirmed:
EB206 My other 6FET controllers from eBikes.CA map to this version pretty well.
Upgrades OoB:
MIA:
I am keen to learn if the P20-22 series maps to the X1-3. I won’t know until I give it a twirl, but odds are that someone else out there in the virtual realm already has an answer, yes?
Cheerios, KF
- Store List of Infineon Controllers
S/N C3625-NC for $110.00 USD.
TOP VIEW
BOTTOM VIEW
Confirmed:
- Infineon XC846
- IRLB4030 Qty-6
Upgrades OoB:
- C1 to 100V 1000uf
- C2 to 100V 100uf
- C201 to 100V 220uf
- R1 = 201 ohms 2W, was Qty-2 (parallel) but is now just Qty-1.
MIA:
- Pins X1, X2, X3 for 3-way Speed Control
- EBS- and EBS+ replaced with just EBS.
- According to Ebikes, it is not required to short BK to GND to enable Regen. I can confirm that mine is not shorted. Instead BK and GND go to the EBrake connector (formerly was EBS- and GND).
- Fwd/Rev, one wire goes to GND-4, while the other to P21 in a new area with three pads, P20, P21, and P22 (located between GND-1 and EBS pads). Could this be the replacement pads for X1 through 3? It sure is painted on the backside like a 3-pin connector. Called eBikes to query but they said they don’t support 3-Way Speed control. Boo hoo ~ minus one star. Must investigate further…
Cheerios, KF
