Cycle Analyst V3 preview and first beta release
teklektik   10 GW
Re: Cycle Analyst V3 preview and first beta release
Post by teklektik » Apr 21 2012 11:09am
v2.23/v3.0 side by side...
<<< v2.23 | v3.0 >>>
Easy front connection points with thu-board strain relief for wires.
O-ring moisture seals on screw bosses.
Link back to post with board connections
hjns   100 kW
Post by hjns » Apr 21 2012 12:14pm
teklektik wrote:v2.23/v3.0 side by side...
so, in your case only the DP connection and the communication bus is connected? What is your plan with the V3?
Henk
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible. T.E. Lawrence
teklektik   10 GW
Post by teklektik » Apr 21 2012 2:13pm
hjns wrote:so, in your case only the DP connection and the communication bus is connected?
That's the out-of-box condition for beta folk - DIY cabling - I actually didn't expect that much done... cool.
hjns wrote:What is your plan with the V3?
I have a kind of non-standard situation with two controllers, so first get the basic CA transplanted, copy over Rshunt + stats (mileage, etc), and get basic dual controller throttle running. Then hook up external hi/lo power and boost switches - they will need to work a little differently on the v3. A bit of ghetto wiring before finalizing until I see how the new features work. ...Little steps... :wink:
This time, though, I'm going to cut a piece of LCD screen protector (like for cameras) and fit it to the CA. I scratched my v2.23 screen last time (stupidly) wiping off abrasive trail dust (Grrr).
teklektik   10 GW
Post by teklektik » Apr 21 2012 9:16pm
Justin-
How do you wish beta testers (or folks in general) to submit bug reports?
Sent you one via PM and cc'd via email "info<at>ebikes.ca".
teklektik   10 GW
Post by teklektik » Apr 22 2012 1:31pm
Setup Summary for CA vB12
The setting summary for the newer v3B13 release is available here.
Unofficial basic setup notes are available here.
Values shown are not the delivered defaults.
[...] = numeric entry field
{ ... | ... } = menu chooser
  1. Setup Calibration
    1. Cal -> Range
      { Lo (W) | Hi (kW) }
    2. Cal -> RShunt
      [1.403] mOhm
    3. Cal -> V Scale
      [31.07] V/V
    4. Cal -> Zero Amps
      (Press/Hold to normalize the currently detected Amp reading to 0.0)
  2. Setup Spdometer
    1. Spd -> Units
      { mi | km }
    2. Spd -> Wheel
      [2150] mm
    3. Spd -> #Poles
      [01]
    4. Spd ->TotDist
      [01748] km
  3. Setup Speed Lims
    1. SLim -> Max Speed
      [99.0] kph
    2. SLim -> Start Speed
      [00.0] kph
    3. SLim -> IntSGain
      [200] Gain
    4. SLim -> PSGain
      [0.59] V/kph
    5. SLim -> DSGain
      [002] Gain
  4. Setup Power Lims
    1. Plim -> Max Current
      [99.0] Amps
    2. Plim -> AGain
      [150] Gain
    3. Plim -> Max Power
      [1800] Watts
    4. Plim -> W Gain
      [50] Gain
  5. Setup Throt In
    1. ThrI -> Cntrl Mode
      { Pass-thru | Current | Speed | Disabled }
    2. ThrI -> Min Input
      [0.00] Volts
    3. ThrI -> Max Input
      [4.99] Volts
  6. Setup Throt Out
    1. ThrO -> Output Mode
      { Voltage | R/C Pulse }
    2. ThrO -> Min Output
      [0.90] Volts
    3. ThrO -> Max Output
      [3.74] Volts
    4. ThrO -> Up Ramp
      [500]
    5. ThrO -> Down Ramp
      [500]
    6. ThrO -> KV Comp.
      [0.95] V/kph
  7. Setup RPM Sensor
    1. RPM -> PAS Poles
      [08]
    2. RPM -> Dir Plrty
      5v={ Fwd | Rev }
    3. RPM -> Strt Delay
      [50] x 18ms
    4. RPM -> Stop Delay
      [15] x 18ms
  8. Setup Trq Sensor
    1. Trq -> Trq Scale
      [+200.0] Nm/V
    2. Trq -> Trq Offset
      {4.04V 4.06V}
      (Press/Hold to update eeprom offset voltage on left with current voltage on right - similar to Zero Amps)
  9. Setup Cntrl Mode
    1. Ctrl -> Aux Funct
      { Off | Amps Lim | Speed Lim | Power Lim | Pas Level }
    2. Ctrl -> PAS Mode
      { PAS Off | RPM Cntrl | Trq Cntrl }
    3. Ctrl -> Assist Level
      [0500] mA/Nm
  10. Setup Temp Sensr
    1. Temp -> Sensor
      { Disabled | 10K Thrmstr | Linear Type }
      (If Temp->Sensor = { Linear Type }
      1. Temp -> 0 Deg
        [0.99] Volts
      2. Temp -> TScale
        100.0 Deg/V
    2. Temp -> Thrsh Temp
      [090] oC
    3. Temp -> Max Temp
      [130] oC
  11. Setup Battery
    1. Batt -> Chemistry
      { LiFe | SLA | NiMH | LiMn | LiPo }
    2. Batt -> String#
      [20] Cells
    3. Batt -> Capacity
      [20] Ah
    4. Batt -> RBatt
      [028] mOhm
    5. Batt -> Vlt Cutoff
      [50.0] Volts
    6. Batt -> V Gain
      [0800] Gain
    7. Batt -> TotCyc
      [0070] Cyc
    8. Batt -> TotAhrs
      [00911] Ah
  12. Setup Display
    1. Disp -> Main Disp
      { Watts | Amps }
    2. Disp -> Averaging
      [5] Duration
    3. Disp -> RS232
      { 1 | 5 } Hz
    4. Disp -> Vshutdown
      [10.0] Volts
Printable version:
CA_vB12_ConfigSettings.zip
(1.37 KiB) Downloaded 92 times
lostrack   100 W
Post by lostrack » Apr 22 2012 1:54pm
Great writeup teklektik. Lots of new options - looks great Justin!
Not sure if this will fall on deaf ears - yet another feature suggestion - but in terms of the throttle I have an idea
It would be really useful to have a calibrated 'sweet spot' which is around 25% throttle position, which is calibrated to sustain your speed, whatever amp draw required.
It would be really helpful as a built in cruise control 'sweet spot'. This way you could knock it down by putting your throttle lower, then continue at the lower speed. Or vice versa.
This may be an effective, simple mix of current / throttle, not too hard to program?
Alan B   100 GW
Post by Alan B » Apr 22 2012 3:44pm
Nice fast delivery, Justin!
One comment - I don't recommend any display alternation on the standard displays. My adult son crashed while looking at the CA waiting for the amp hours to come up. Yes it should not happen, but sometimes it does.
Hyena   100 GW
Post by Hyena » Apr 22 2012 8:19pm
I've got my V3 on the way too, hardcore fiddling ahead. Also playing with the CA :lol:
Justin, would it be hard to have one totally user customisable screen to scroll though ?
You can configure some of it now but it would be cool to have a totally custom screen for the parameters you wanted to look at at any given time (especially useful when beta testing new features you might specifically want to look at while riding rather than the usual stuff)
In the setup you could have position 1,2,3,4 and then a scroll through menu for each position with say 10 parameters to choose from. This might be useful too for people wanting to not have certain wattage or voltage parameters on display if certain people are looking at their bike, and it might be nice to have just current speed, distance travelled, Ah and somthing else fairly innocent :wink:
If you're looking to add other gimmicky features, somthing like car trip computers could be 'distance to empty' - calculated by subtracting the current ah from the programmed ah capacity divided by the wh/km(mi). This could either go off the average wh/km when stopped (or in general) or change in real time based on the current wattage consumption. So crusing along it could show 20km range but then if you punch the throttle it drops down to 5km or what ever. It could be useful for people who need to get a certain distance and can alter their riding style accordingly (you could argue this should be common sense but it might be good for noobs) Or the CA could even enforce it if you wanted to really be gimmicky - program your minimum range requirements and the CA would limit the current to maintain a desired wh/km (or just program a target wh/km)
www.HyenaElectricBikes.com
shorza   1 kW
Post by shorza » Apr 22 2012 8:59pm
Hyena wrote: If you're looking to add other gimmicky features, somthing like car trip computers could be 'distance to empty' - calculated by subtracting the current ah from the programmed ah capacity divided by the wh/km(mi). This could either go off the average wh/km when stopped (or in general) or change in real time based on the current wattage consumption. So crusing along it could show 20km range but then if you punch the throttle it drops down to 5km or what ever. It could be useful for people who need to get a certain distance and can alter their riding style accordingly (you could argue this should be common sense but it might be good for noobs) Or the CA could even enforce it if you wanted to really be gimmicky - program your minimum range requirements and the CA would limit the current to maintain a desired wh/km (or just program a target wh/km)
This is a great, idea. Of course there will always be variances such as battery temperatures, etc but i would love to see this feature.
hillzofvalp   1 MW
Post by hillzofvalp » Apr 23 2012 12:39am
It'd be cool also if the screen flashed the inverse pixels (everything but the original black characters) whenever an alarm or pack condition was met (such as high temp). Having the inverse colored display would be quite noticeable.
justin_le   10 MW
Post by justin_le » Apr 23 2012 2:44am
I think this would less useful/valuable than it might seem when you consider the wide spread of Wh/km figures encountered over different sections of a trip. Something like a car can have a fairly predictable miles/gallon given that their huge inefficiency makes changes in grades and windspeed fairly insignificant. But with an ebike, a large hill at the end or a sudden strong headwind would make any prediction of range left fairly moot. And similarly, any attempt and dolling out power in a way that guarantees the rider makes a certain distance will also lead to a way less than ideal ride experience. A constant wh/km means having not nearly enough power going uphill and an unnecessary amount of power wasted on the downhills. With an inclinometer, GPS, and route plan tied in then in principle you could do an OK job of this, but the CA is nowhere there yet ;-)
I'm of the general opinion that it's best to show only stats that are clearly known, and leave the riders in charge of proceeding based on that info and all the other environmental stuff which a rider (and not the CA) is aware of. Is it just me coming from a bit of a tech/lab background or does that make sense? -Justin
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
justin_le   10 MW
Post by justin_le » Apr 23 2012 3:54am
oatnet wrote:Got mine, thank you Justin!
OK wow, thanks to Adam here for getting the shipments out fast, I wasn't expecting anyone to recieve theirs till this coming week!
Anyways, I just want to make sure people who did receive understand that this is beta and that many firmware upgrades will be happening in the coming 3-5 weeks as we get everything flushed out in preparation for the production release. The firmware that was shipped is V3Beta12 which is functional but has a lot of things still incomplete, and I'll try to list most of it here so people aren't surprised:
1) Battery SOC Gauge: At the moment, the battery fuel gauge has been reverted to being based on the open circuit pack voltage (calculated from V-IR) rather than doing the combination of this plus the accumulated Ah as described in one of my first posts. I'm still working out the best way to implement the algorithm efficiently with the new chip and wasn't ready with this at time of shipping. With LiPoly, LiMn, and SLA this compensated voltage based approach works quite well. Just be sure to input your battery internal resistance by looking at your pack voltage before and after applying full throttle, then use RBatt = (V1 - V2) / A, where V1 is the voltage with no throttle, V2 is the voltage at full throttle, and A is the current limit of the controller. For those with LiFePO4 batteries, you'll have to wait until the full algorithm is implemented before the fuel gauge display works in a meaningful way.
CA3 SOC.jpg (6.67 KiB) Viewed 4953 times
2) Display Screens: Some of the display screens are anything but 'polished' and are there more for diagnostic purposes during development. This will be obvious as you scroll through them. An ability to select or deselect which screens show up (both while moving and while stationary) is on the agenda.
3) Units: It was pointed out by Telektik that if you select units of miles instead of km, the units text are not necessarily carried through to various setup options. I just haven't got around to that yet, but in your head you can read V/kph as V/mph etc. It doesn't change anything, just the display
4) Initialization: Some things like the accumulated torque for pedal assist mode aren't properly initialized yet on startup, so if you have a PAS torque sensing mode you can see for a few seconds some random human watts on the screen shortly after turning on.
5) PAS Quadrature: I just realized too that the PAS direction input is set only for quadrature PAS encoders. If you have a PAS sensor that only sends one set of pulses, then the CA actually won't pick anything up for your pedal cadence because it will think that every falling edge you are pedaling backwards. In the next firmware there will be a new item in the PAS Direction setup for enabling or disabling quadrature mode
6) Temperature Probe: You have the option of adding a 10K thermistor, a linear temp probe, or no temperature probe. Once a temperature probe is enabled, then the temperature will show up on the first display screen toggling along with the Ah and Dist. It currently shows units as oC, but I will have a oF option listed sooner or later.
7) RShunt: In the calibration menu in high range mode, you can set RShunt up to 9.99 mOhm, rather than just 0.99 mOhm as before. If you do set it above 1mOhm in the high range mode, and then you switch to low range mode, the first digit will be lost. So say 2.36mOhm in high range becomes 23.6 mOhm in low range, which will show up as just 3.6 mOhm, and if you change this to say 1.8 mOhm it will actually change to 21.8, because the 2 was still there just hidden.
I think that's it for the obvious shortcomings. As well, there were some things that were successfully added since I started this post
Ebrake Graphic: If you engage the ebrake levers by shorting the Bk pad to ground, then the throttle slider is replaced with an animated brake handle, to make it super clear why there is no power. As well, when the brake lever is engaged the CA's throttle output goes all the way to 0V, rather than to the min output voltage (which would typically be set to ~0.9V). This is done so that in principle you could use the throttle signal going to 0V in order to activate a regen input on the controller with just a simple comparator circuit, and eliminate the need for a separate wire going to the controller for that.
CA3 Ebrake.jpg (9.27 KiB) Viewed 4953 times
V/kph: I added a 'KV' parameter as one of the more advanced throttle control options based on earlier discussions here as a way for the throttle to jump to a value correlating to the current wheel speed before the throttle rate limiting kicks in. However this is not yet implemented, so changing the value has no effect yet.
Ramp Down Rate: There is now a throttle ramp down rate limit, similar to the ramp up rate limit, as requested by Adrian and hopefully useful to a few others too ;-)
CA3 Down Ramp.jpg (6.22 KiB) Viewed 4953 times
CA3 Diags.jpg (8.22 KiB) Viewed 4953 times
adrian_sm   10 MW
Post by adrian_sm » Apr 23 2012 4:11am
justin_le wrote:Ramp Down Rate: There is now a throttle ramp down rate limit, similar to the ramp up rate limit, as requested by Adrian and hopefully useful to a few others too ;-)
Awesome. Thank you, this will be very useful for helping to control the disengagement of my friction drive. But best to have it default to 0 or a very low number, as most people will want instant off. I wouldn't have said anything, but it looked like from teklektik's post above, that it may be non-zero by default.
- Adrian
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
justin_le   10 MW
Post by justin_le » Apr 23 2012 4:33am
hillzofvalp wrote:It'd be cool also if the screen flashed the inverse pixels (everything but the original black characters) whenever an alarm or pack condition was met (such as high temp). Having the inverse colored display would be quite noticeable.
The current plan is to flash just the parameters affected. So for instance, if LVC is reached then the voltage display would flash. If the speed limit is reached then the speed readings would flash. Overtemp would cause the oC display to flash, etc. To do the entire screen is probably overkill, as some of these limits are hit on a fairly routine basis throughout the trip.
justin_le   10 MW
Post by justin_le » Apr 23 2012 4:52am
Hyena wrote:I've got my V3 on the way too, hardcore fiddling ahead. Also playing with the CA :lol:
Hard? Yes. Doable? Yes. Likely to happen? Yes as well! With the many additional parameters being sensed and measured it's getting tough to figure out "one size fits all" display screens, and customization will be hugely appreciated. To some extent I'll have that automatic based on what features are enabled (no point showing temperature if no temp probe is connected, no point showing a human power bar if no torque sensor is configured etc).
Your suggestion is spot on for how to do a fully custom screen. 4 parameters really is the most you can show on a 16x2 LCD screen without clever graphics, and the way you described setting it up is exactly as I was envisioning. You'll notice that in the "Setup Display" menu there isn't a lot there yet, but expect this to get filled with many custom display options in upcoming firmwares.
Hyena   100 GW
Post by Hyena » Apr 23 2012 5:29am
justin_le wrote:I'm of the general opinion that it's best to show only stats that are clearly known, and leave the riders in charge of proceeding based on that info and all the other environmental stuff which a rider (and not the CA) is aware of. Is it just me coming from a bit of a tech/lab background or does that make sense? -Justin
Yeah I guess. I suppose it's something you quickly get the hang of but I've had a few noobs say to me "man, I was out having a blast then suddenly ran out of battery and had to pedal the rest of the way to work/home" (oh, the horror! :lol:)
I guess once that happens a few times they learn to keep an eye on the ah!
justin_le wrote: If you engage the ebrake levers by shorting the Bk pad to ground, then the throttle slider is replaced with an animated brake handle ...This is done so that in principle you could use the throttle signal going to 0V in order to activate a regen input on the controller with just a simple comparator circuit, and eliminate the need for a separate wire going to the controller for that
Cool, but shorting bk to ground automatically cuts out the throttle and activates regen (if enabled) anyway - atleast on my controllers it does. Or are you referring to a bk pad on the CA itself ?
Next up, an ebikes.ca throttle with only a 6" long cable on it that plugs straight into the side of the CA :)
justin_le wrote: the way you described setting it up is exactly as I was envisioning.
Excellent! :D
Now it'd really make my day if you could program the over temp alert caused the whole screen to flash
"WARNING: Danger to manifold" :lol:
On a serious note, if you're going to have temperature rotating with 3 other parameters having it just flash might not be sufficient if it only displays temp for 2 seconds anyway. Maybe that parameter could stay on and flash if it's causing the CA to cut power. Though I guess if you're really worried about temperature (primarily in hod rodding applications I assume) you'd set up one of the above mentioned custom screens to keep an eye on it, and you'd notice power ramping down before it cut right out.
Or if that parameter isn't on the current screen, maybe you could have a flashing exclamation mark icon or something (like the brake lever display) that instantly tells you the CA has has cut your power rather than a BMS, wiring or hardware fault.
AussieJester   100 GW
Post by AussieJester » Apr 23 2012 6:15am
highside hyena wrote:Excellent! :D
Well...at the very least..."WARNING: Frocked motor imminent"
:-P
shorza   1 kW
Post by shorza » Apr 23 2012 7:52am
I am unfamiliar with thermistors.
10k NTC thermistors on Ebay vary in size and price. Can you recommend one?
lostrack   100 W
Post by lostrack » Apr 23 2012 9:31am
Here's the throttle map idea.
More than a curve, it's got an adaptively set mid-point, based on the energy needed to sustain the same speed.
Outside this zone, it's current throttle.
cruise zone.jpg (37.97 KiB) Viewed 5584 times
Thoughts?
justin_le   10 MW
Post by justin_le » Apr 23 2012 11:43am
Hyena wrote: Yeah I guess. I suppose it's something you quickly get the hang of but I've had a few noobs say to me "man, I was out having a blast then suddenly ran out of battery and had to pedal the rest of the way to work/home" (oh, the horror! :lol:)
I'm hoping that the battery gauge graphic will go a long way to eliminating that surprise for riders who don't yet get the gist of Ah. But trying to say "you have 15km of charge left" is potentially asking for trouble when a change in grade or wind could quickly reduce that to 7-8 km.
Should have been more clear. Yes, I am referring to the EBK pad on the CA itself. I need to check what the logic thresholds are like for the ebrake signal in most of the controllers, because there's a chance you could do this even more simply than a comparator circuit by just linking the throttle to the controller's ebrake input with a diode. So suppose the controller turns on regen when "BK" falls below 1.2V. If you link it to the CA's throttle output via a signal diode, then at a low throttle of 0.9V, the ebrake would be ~1.5V and hence not activated, but the moment the CA's throttle goes to 0V, then the controller's ebrake input falls to about 0.6V, which would enable regen.
Having the CA enable regen has some other benefits too, since it could then take care of regen over-charge protection, and enable regen via other means without needing ebrake cutoffs, (like negative pedal torque or backwards pedalling). It's also in that case possible for the CA to do a low frequency PWM on the ebrake line and potentially modulate the regen force a little bit.
In my head the idea of overtemp protection limits was to eliminate the need of the rider having back off from the motor overheating, as the CA itself will do that automatically. If all it had was a temperature display, then yes a fairly proactive alerting system would be on order. But since it's also taking care of ramping power down way before temps get critical, then it seems less urgent no? It wouldn't be too hard to have whatever display screen is currently periodically flash to show the temperature whenever it is between the threshold and max value.
-Justin
justin_le   10 MW
Post by justin_le » Apr 23 2012 11:47am
shorza wrote:I am unfamiliar with thermistors.
Good question that I should have addressed. Anything with a beta constant between 3800 and 4000 should be pretty accurate. At some point we'll make the thermistor lookup table programmable via a PC interface so that you can calibrate it to different models, but for now it is fixed and hard coded assuming B~3900.
-Justin
electricwheels.de   100 W
Post by electricwheels.de » Apr 23 2012 4:51pm
Finally I received mine too. :mrgreen:
Sometimes Germany seems to be a loooong way away... :wink:
Custom made cables and wiring harnesses for e-bikes. HIGO and JULET connectors, extension cables and much more. World wide mail order.
e-bike-technologies webshop
Tench   100 kW
Post by Tench » Apr 23 2012 5:07pm
Got mine today too :D Big thanks to Justin and Adam for getting these out so quick!
I will get the bike rewired later this week and start playing :D
Justin you had better get ready for the myriad of questions! :?
Simon.
Project one http://endless-sphere.com/forums/viewto ... ilit=tench
Project Two http://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
hjns   100 kW
Post by hjns » Apr 23 2012 5:20pm
Mine arrived today as well! Yippiaeee!
Oh, and it came with a cycle analogger as well (cause I ordered it...)
Henk
oatnet   10 MW
Post by oatnet » Apr 23 2012 10:29pm
hjns wrote:Oh, and it came with a cycle analogger as well (cause I ordered it...)
Another great tool I am happy to have, but it is in serious need of a new name - the term analogger suggests other images to me. :shock: On the other hand, odds are good that the trademark hasn't already been taken like drainbrain was. :lol:
-JD
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
