Sabvoton SVMC072150 controller review, variable regen *PICS*
Get real world experience and user feedback on the electric bicycle products.
cr0m08   1 W
Re: Sabvoton SVMC072150 controller review, variable regen *PICS*
Post by cr0m08 » Oct 24 2019 6:01am
I am getting the same result as BionicBlitz. I only have the iPhone app and bluetooth dongle to configure it. Do I need to try get hold of a windows laptop? Anyone know if the windows exe will work on windows 7 OS and does anyone have the right usb drivers for it ? I have been able to use the high brake setting, but cannot get the variable to work ( 2nd throttle plugged into it ).
2015 Nukeproof Pulse, Tangent Ascent V1.5, 3220/HV160/CA V3 @12S, 26x2.8" Nextie 50mm wheel set
2006 KeeWee Cromo Eight, Tangent Ascent V1.5, 3210/HV80/CA V3 @12S, 24x3" wheel set.
1998 Marin B17, Mac 10T/CA V3 @18S in 19" Kris Holme Trials rims, 19x2.5" wheel set (still to finish)
part build Project346 Basman, QS205 4T hub motor, SVMC48150/CA V3 @12S in 24x3" wheel set. (still to finish)
minde28383   10 kW
Post by minde28383 » Oct 24 2019 10:15am
cr0m08 wrote:
Oct 24 2019 6:01am
Usd drivers might work or might not work with win7.
Exe will work on win7.
Drivers are available on net. If you don't find I can share usd drivers from my disk.
Just try it.
*Link removed
in progress
cr0m08   1 W
Post by cr0m08 » Oct 24 2019 10:29pm
Thanks for the advice and the link. I have downloaded the contents of that drive so you can remove link now, cheers. I had to do that on my mac and I will try, when I get the chance, to transfer contents with a thumb drive to the win7 bootcamp install on my old macbook pro which is not on the net. I did manage to get a version of Sabvoton exe loaded on that but when I tried the usb drivers from QS motors links, it told me it failed. I haven't however tried yet to connect that to the motor controller. I will get to that and try again with your files. Big thanks for your link, even if it doesn't work, its very much appreciated. Cheers.
BionicBlitz   1 W
Post by BionicBlitz » Oct 26 2019 9:55am
getting the driver to work is a bit of a pain. for me it took lotsssss of messing around. i think in the end what got it working for me is (on Windows 10) go to "device manager" ---> coms and L... something ---> find the device that pops up when yiu plug the sabvoton cable into the pc (the bigger end of the cord goes into the computer) then right click and go to drivers and "search for online update"
if you cant get the decice to show up under "COMS and L.. whatever it is" and insteac it pops up under usb decices with a caution sign for me the soloution was to disable windows 10 virus protection theres two things you have to disable to do so and it turns back on when you power off your computer... if none of that works try running it as administrator or try a different installer.
and im sure youll have issues with getting the controller to connect to the pc even after you get that to work. its a bit of a pain
qs205 5t, 28s li-ion 36Ah, 120a esc, homemade frame.
minde28383   10 kW
Post by minde28383 » Oct 26 2019 10:14am
there should be be no issues once get get usb driver and app installed.
It is a pc porn. Sound complicated and i know you not alone encountering such things.
Some just can't make app to get installed on pc no matter windows version.
in progress
cr0m08   1 W
Post by cr0m08 » Oct 27 2019 7:47pm
Finally I have been able to activate the variable regen braking on my SVMC048150 (haven't tried yet with my 72150, I don't need that much speed on my very low cruiser frame,as yet still an unfinished build project and can't get over a speed bump, check the pic :lol: ). Big thank you to minde28383 for his files access. Turns out I think my original install of usb drivers on my Bootcamp Win7 OS did work........ but it helps if you get the controllers usb cable plugged into the computer the RIGHT way around.... doh! :oops: As soon as I turned it around, the drivers finished their install and then it was just playing with the communication ports in the controller program till I found the one that works.
However my original install of that controller program did not give me the options required to activate that variable regen and it was minde28383's copy of that program that worked for me (thanks mate). As a bonus I now also, have been able to activate the motor temp sensor, and even more amazingly, I now get temp readouts for the motor on the MQCON iPhone bluetooth app, wahoo! So that's an unexpected bonus. Again, thank you to all for their input here.
Volts   10 W
Post by Volts » Nov 09 2019 3:43am
Does someone have the sabvoton windows software and if so can you post a link or send it to my email, I’ll let you know it (my email) when you can confirm you can send it thanks
minde28383   10 kW
Post by minde28383 » Nov 09 2019 3:54am
*Removed
Here you go:
Let me know once I can remove links
in progress
rockstar195   100 W
Post by rockstar195 » Nov 16 2019 10:13am
Has anyone set the "Motor Limit Speed Set" under "MOTOR" to over 100%?
What were the results?
rockstar195   100 W
Post by rockstar195 » Nov 16 2019 5:00pm
Found this webpage today, with a mod at the bottom of the page to hot rod the controller. 72150
Translated page:
https://translate.google.com/translate? ... guracja%2F
Original page:
https://ebike.nexun.pl/sabvoton-program ... figuracja/
Volts   10 W
Post by Volts » Nov 24 2019 10:15pm
Cant seem to make my controller run slower changing the DC currents and the phase currents, only works when changing the motor speed percentage but this makes the motor run hot, any input would be helpful I’m running a 96120 controller
minde28383   10 kW
Post by minde28383 » Nov 25 2019 3:38am
Volts wrote:
Nov 24 2019 10:15pm
Run controller slower? How does it is even possible. What do you mean?
in progress
Volts   10 W
Post by Volts » Dec 04 2019 7:29am
Does anyone know if the wrong programming setup makes the motor and controller run warm?
minde28383   10 kW
Post by minde28383 » Dec 04 2019 9:29am
Volts wrote:
Dec 04 2019 7:29am
Yes, it might.
in progress
larkmachineco   1 µW
Post by larkmachineco » Dec 17 2019 12:19am
Hello there! total nube to the forum. If this is earlier in thread, let me know. I have browsed this thread it is a great spot for trouble shooting!
I have built a couple of e-bikes in the past using cheapo controllers and I decided to get the 72150 off of amazon.
I originally hooked it up without a motor hall sensor and it was throwing an error.
I got the Hall hooked-up, started troubleshooting.
I cant get any throttle signal on the Phone app, but I am getting variable voltage at the connector (.8 -4.2V). The app just shows .04 to .05 (floating, I think. no change when i sweep the throttle). Throttle is your standard 5V hall sensor
Has anybody had this issue with this controller?
I am all finished with the bike and fab and I would hate to have to cut it out the mounts and change back to the cheapos.
Wires i dont have hooked up:
Rx (not going to)
Tx (not going to)
reverse (not going to)
Crime Signal (not going to)
Antitheft (not going to)
Boost (not going to)
Brake for high level (Will use)
Electric lock (not going to)Image
larkmachineco   1 µW
Post by larkmachineco » Dec 17 2019 3:02am
larkmachineco wrote:
Dec 17 2019 12:19am
added note: I have done the temp bypass with a 1k resistor to ground and the motor temp is reading 0C.
No faults on the App
When i manually spin the motor, the values are in reverse. spin forward, neg rpms. I flipped the phase wires and no change.
Can some one link me to the manual and the PC programming app. I dont think I fried it, but I would like to run through the installation manual and make sure it isnt anything stupid.
I have a 16s battery with about 50Ah. I have set my voltages, current limits are moderate and all values save.
High voltage pops when it is connected (typical) and HV enable wire pops when it is turned on. not as bad as the Main HV. Is this standard?
larkmachineco   1 µW
Post by larkmachineco » Dec 21 2019 2:28am
I returned the one I had and got a new controller.
ok, I got the motor to turn during the hall test, but it is crawling.
it takes about 3 minutes to run the test and always fails.
I tried multiple motor parameters 300-3000. It just changes the tone coming out of the hub. it only pulls .25 amps when it is testing
test amps were tested from 10A-30A.
Maybe I have a bad hall sensor?
Does anybody have a crystalyte rhs3540? I dont know what to put in for the motor parameter.
Does anybody have the manual or the PC EXE?
Im at a loss with this controller.
Still no throttle voltage on the app even though it is at the controller side of the connector
dudeguy1111   1 µW
Post by dudeguy1111 » Feb 27 2020 10:13am
It might help to change the order of the phase wires, you need to try all combinations. If that does not work you should change the order of the hall wires as well. I think there are 36 combos in total. Google: Hall and phase wire combinations.
Here is a chart for just the phase wires: https://i.imgur.com/GsugRE9.jpg. But from what I understand it might also take some hall wire combinations testing.
Savara   1 µW
Post by Savara » Mar 15 2020 3:15am
Hi All.
Firstly, first post so definitely needs a comment about how much amazing useful info I've had from you guys already! I'm less than a year into all things wheels and volts - loving it. This is a quick question about the SVMC72150 and regen braking.
Screenshot
This is the options page for braking in the software I have (no idea what version it is). I seem to be missing the dropdown for choosing variable regen braking. Do I need later software for this? I cannot seem to find it. The regen charge/slide function is working fine as is the +12V (purple wire) high brake. I also have the controller with a 3-wire connector (red, brown, black) for the 0-5V brake but when I connect a 5V thumb throttle, nothing! This is whether I have all brake options enabled in the software and apply my (12V, purple wire) brakes before using the thumb throttle.
I have my thumb throttle wires (red black white) connected to (red black brown) in that order but not sure if that's right or I could hurt anything by connecting a 5V throttle wrong, I'm guessing not!
Any help appreciated!
"Everything in moderation, including moderation" Oscar Wilde
Ecobit (Quazzar) 3000W moped/scooter
Sabvoton SVMC72150 Controller
72V Li(NiCoMn)O2 battery
Savara   1 µW
Post by Savara » Mar 15 2020 4:45am
Haha, found it! Lol.
Thanks josephm15234
Time to do some tinkering...
transposon   100 W
Post by transposon » Apr 20 2020 7:55pm
Does this have the option to use a torque/current based throttle or a voltage/speed based throttle?
Audisport09   100 mW
Post by Audisport09 » Apr 28 2020 2:03am
Hello, I received a Sabvoton with a Julet connecter and no wiring. I cut it off it has 9 wires inside, I have no idea which is which.Black, Grey and red: Throttle? Brown, green, white, purple , Blue and yellow no clue.
Volts   10 W
Post by Volts » May 19 2020 9:06am
Anyone else here have a 96120 controller? Was wondering what battery max people are using on this controller 22s, 23s or 24s.
Black6spdZ   1 W
Post by Black6spdZ » Jun 05 2020 1:02pm
does anyone have documentation or photos of the internal pad locations for hi-brake, 0-5v regen input and/or motor temp input? My 72100 controller doesn't have any of those wires.. can't believe I paid >$200 for a controller with NO brake regen capability out of the box.. POS!
Black6spdZ   1 W
Post by Black6spdZ » Jun 16 2020 12:14am
MQCON v2.1 is reporting my low brake input as electronic brake but at least free-wheeling on a stand it doesn't feel like it is slowing the motor at all.. as a matter of fact even the slide regen doesn't feel like it works free-wheeling
