Sabvoton SVMC072150 controller review, variable regen *PICS*
circuit   100 kW
Re: Sabvoton SVMC072150 controller review, variable regen *P
Post by circuit » Sep 09 2015 8:21am
What about the width of internal aluminum plate? It looks very convenient to mount that plate without enclosure (in other enclosed spaces).
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
Kodin   1 kW
Post by Kodin » Sep 24 2015 1:47pm
For those curious about the SSC-series controllers:
https://endless-sphere.com/forums/viewt ... =2&t=72706
I took my 48V/150A unit apart to see the guts. I'm told it's more or less the same layout internally as a Sevcon Gen4. Looks like the low-voltage units still spec the same hardware as the higher voltage units, though I have no idea what's in the 96V model.
Food for thought!
Tank Bike - (Previously YAG - Yet Another Genesis) - LeafBike 1500W 5t, custom shaft, 9 speed cassette, Chinese "Tank" EEB clone frame, Sabvoton SSC048150
sendler2112   100 kW
Post by sendler2112 » Nov 04 2015 6:55pm
What are you using for a screen? Cycle Analyst?
Kodin   1 kW
Post by Kodin » Nov 04 2015 7:14pm
Yup. A couple others are doing the same.
sendler2112   100 kW
Post by sendler2112 » Nov 04 2015 7:26pm
Seen any way to buy a SSC096080 shipped to the USA?
http://www.sabvoton.com/product/sabvoto ... jqhuNKrTs2
Kodin   1 kW
Post by Kodin » Nov 04 2015 9:11pm
QS stopped carrying the Sabvoton units on aliexpress apparently; and in the last few months too! They do have a different model that's 96V capable, but it's more money than the last one. Don't even bother contacting Sabvoton through their inquiry button. Took them 3 months to give me a price last time.
zombiess   100 MW
Post by zombiess » Nov 05 2015 1:01am
I have 8 SSC096100's in stock. $429 with fuse, shunt, CA Connector 8 gauge wiring.
email: jwolf # dodecahedronsolutions.com
Kodin   1 kW
Post by Kodin » Nov 05 2015 10:14pm
zombiess wrote:I have 8 SSC096100's in stock. $429 with fuse, shunt, CA Connector 8 gauge wiring.
What size of shunt do you use on these? I have an SSC048150 I'll be powering up soon, figured I'd hook up my CAv3 at the same time.
cwah   10 GW
Post by cwah » Nov 21 2015 2:58am
Are the new model any good?
Kodin   1 kW
Post by Kodin » Nov 29 2015 5:06am
Other than footprint when considering for a bike build? Hell yeah.
zombiess   100 MW
Post by zombiess » Nov 29 2015 8:30pm
Kodin wrote:Other than footprint when considering for a bike build? Hell yeah.
Foot print is sub optimal as you noticed, but yeah, the controllers appear to work pretty well.
Kodin   1 kW
Post by Kodin » Nov 29 2015 9:20pm
I'd say bulletproof for anything up to 100V and as large as a cromotor.
devmanner   1 mW
Post by devmanner » Jan 15 2016 8:55pm
I have the 80A max sabvoton controller and I saw a manual that said you can do 100v. Have you head of any one running that voltage when the settings have been set for 100v? Also I cant get the controller to be recognized by my computer. Do you have to use Win XP?
Thanks,
Devin
Kodin   1 kW
Post by Kodin » Jan 15 2016 9:04pm
IIRC... 4110 FETs are specced for 100 volt max. So the answer is of course maybe. Running close to the hairs edge on any component gets a bit iffy, and if the FETs aren't matched well they may cause failure if you're at or beyond the limits. Food for thought?
sven_nilsson   10 mW
Post by sven_nilsson » Jan 24 2016 1:04pm
I finished my e-bike project today and just want to warn everyone to be careful with the "Accelerate time" setting on this controller.
According to my findings, when set somewhere above 3000ms, it will convert your e-bike to a death trap.
Everything seems fine, but after you apply even the tiniest amount of throttle, it will give full power and the throttle will also hang at full speed.
You can imagine what can happen if you have a powerful motor and make this mistake...
FYI a value higher than 2000ms is forbidden according to the manual appendix, but not everyone reads that.
Punx0r   100 GW
Post by Punx0r » Jan 24 2016 2:58pm
Oops! That sounds like a firmware/software bug.
sven_nilsson   10 mW
Post by sven_nilsson » Jan 25 2016 5:15am
Definitely a bug yes, the UI should not allow illegal input values.
I had kind of foreseen that something like this might happen so I added a 150amp mains switch to my bike. Just in case the other power switch fails to respond for some reason.
But in the heat of the moment, it is uncertain if you would be able to think clearly enough to turn off the power in time.
Merlin   1 MW
Post by Merlin » Jan 25 2016 5:42am
there are alot of "versions" of the controller software out....
which version did you use?
i dont know who fucks who in this sabvoton/motopulse relationship, but i got from motopulse a single .exe file
which is from 2015...
March.exe (1,8MB)
Version 1.0
crank2giri   100 µW
100 µW
Post by crank2giri » Feb 15 2016 7:28pm
I have a Sabvoton SSC72100 purchased from QS motor, I was able to install the USB software but dosent look like the controller is communication with the software, the TXled blinks but the RX does not as a result not able to configure the controller. Any one who can offer some help, would be really appreciated. Thanks in anticipation.
Merlin   1 MW
Post by Merlin » Feb 16 2016 4:42am
did you selected right COM Port to communicate?
devmanner   1 mW
Post by devmanner » Apr 01 2016 7:47am
Have you figured out how to use the sliding regeneration on the controller?
sketchism   100 W
Post by sketchism » Apr 13 2016 12:27am
i have the big SSC 098150 and it came with some software but i don't have the throttle mid volt or throttle mid amp control and it was making the bike VERY twitchy, so much so it twisted my axle in half actually.
what is the current, latest version of the Sabvoton software i have seen a few versions with different filenames and different options.
Don't overheat your ebike hub motor - www.hubsink.com (beta testing still open)
https://hubsink.com HubSink - Hub Motor Heatsinks
https://australiandroneco.com Australian Drone Co - Aerial Videography
Nothing is fool proof to a sufficiently talented fool, trust me we'll find a way :idea:
miuan   10 kW
Post by miuan » Apr 26 2016 1:28pm
devmanner wrote:Have you figured out how to use the sliding regeneration on the controller?
are you able to activate brake switch regen, but unable to activate slide regen, even if both are activated in the parameter software and their respective phase currents are set to identical values? then you may try to set your low throttle voltage to a slightly higher value and see if it helps. You want to make sure the controller sees the throttle sit safely under the low voltage threshold. I set my to 1.5V but could get away with a slightly lower voltage too.
i had the opposite problem with my SVMC072080 controller. the slide regen worked but brake switch regen didn't. i resolved this by increasing the brake-hi switch voltage from 5V (throttle line voltage) to 8.4V driven by a DC DC converter.
Alan B   100 GW
Post by Alan B » Apr 28 2016 7:34am
Both sliding and braking regen work on my Sabvoton.
Teh Stork   1 kW
Post by Teh Stork » May 16 2016 7:16am
Got a pair of SSC 48060 controllers. Wrongly delivered without secondary 0-5V analog input for variable regen braking. New ones will be delivered, but looks like I will have to make-do with the current ones for a while.
Is there any way to modulate sliding mode or regen braking? I have a microcontroller in the HMI, so able to generate any kind of waveforms.
2013 VW E-UP!
Kona mtb: Cromotor, Kelly KEB, ~6kW peak, 1,4kWh 90V battery 29E cells, 38 kg
