Bafang BBS01 350w vs Dillenger 250w front hub
byebyepetrol   100 W
Post by byebyepetrol » Nov 18 2014 2:02am
After a highly reliable and fun 4000KM using a 250w Dillenger front hub 10AHr kit I thought I'd be in a good position to compare it to a 350w BBS01 Bafang kit.
My Dillienger kit has been great. The road test thread's here:http://endless-sphere.com/forums/viewto ... =4&t=56711
Two Boxes
Two boxes arrived today only two weeks after payment. I thought this was OK. Here's everything in the kit:
Drive System:
Trouser Guard
Chainring
Cranks
Supporting Tech.
Battery & Holder
Total weight = 8462g = 18.65lbs
Tats   1 kW
Location: NOR Perth, worlds best kept secret, Australia
Re: Bafang BBS01 350w vs Dillenger 250w front hub
Post by Tats » Nov 18 2014 7:18am
Looking forward to this thread - let me know the difference in cruising speed. I take it you're sticking with 36v?
byebyepetrol   100 W
Post by byebyepetrol » Nov 18 2014 8:01am
Hi Tats,
Yes, 36v 14.5AHr.
The Dillenger has been great but the 35kmh is a little limiting.
I expect this set-up will make the bike lighter (but not by much) and faster.
I get 60km range with the Dillenger kit and the 10AHr pack, so another 20km might be possible with this combo.
It's not a plug n' play situation though, the battery is from BMS and needs a power lead routed into the base through
the rubber grommet holes then soldered on internally to the socket pins.
They supply a lead with average quality connectors.
I'm tempted to simply bypass the connectors and solder the motor power lead into the socket.
If I need to remove the motor the battery base unit can be removed with it.
mfj197   10 W
Post by mfj197 » Nov 18 2014 11:30am
Thanks for the breakdown of weights for the BBS01. This is very helpful information as I'm looking to convert a lightweight bike so will be totting up the grams!
Michael
byebyepetrol   100 W
Post by byebyepetrol » Nov 18 2014 6:24pm
Hi Michael,
Happy to help.
Another plus with the mid-drive is handling I expect. The front hub set-up adds 3Kg to the front wheel so agility suffers.
One advantage of a front-drive however, is the accurate way you can direct the thrust; you can angle your wheel to better suit the terrain.
I can't wait to get home and start wiring it all up. Today might be the last trip the Dillenger system makes on this bike.
cwah   10 GW
Post by cwah » Nov 18 2014 6:50pm
you need to overvold your dilliger for proper speed :)
byebyepetrol   100 W
Post by byebyepetrol » Nov 18 2014 10:22pm
Hi cwah,
Tell me more! Define "overvolt" and "proper speed" ;o)
Chris.
byebyepetrol   100 W
Post by byebyepetrol » Nov 19 2014 2:20am
Fancy a Bafang install video performed by a Czech hottie ?
Et voila!
[youtube]https://youtu.be/Ia8lpz5J1pII[/youtube]
https://www.youtube.com/watch?v=Ia8lpz5J1pI
byebyepetrol   100 W
Post by byebyepetrol » Nov 23 2014 6:54pm
One thing to note
I charged the battery using their fan-cooled changer. The cooling fan works, the charger stays cool but it's noisy.
There's an on-off switch on the pack and you'd think pushing it in would activate the pack.
This isn't the case, pushing it turns it off.
Anyone else experienced similar?
My other pack which is identical apart from cell capacity works as you'd expect it to. You push the button to activate it.
My guess is the switch has been wired back to front.
If this is the case it doesn't say much about their "Quality Control" process.
Tats   1 kW
Post by Tats » Nov 25 2014 10:43pm
Any updates on his the BBS compares against the Dillenger mate? Still struggling with my PAS...
byebyepetrol   100 W
Post by byebyepetrol » Nov 26 2014 11:06am
Hi Tats,
Sorry to hear your PAS is a PITA.
I haven't had a chance to install the BBS01 yet. Likely this weekend; there's an MTB event I'm off to on Sunday and I'll degrade the bike to human propulsion only
after which I'll install the new system.
byebyepetrol   100 W
Post by byebyepetrol » Nov 28 2014 4:30am
Bike relieved of Dillenger kit ready for BBS01.
Replaced heavy Schwalbe front tyre with something a lot lighter.
23lbs 15oz = 10.86Kg
byebyepetrol   100 W
Post by byebyepetrol » Nov 30 2014 2:46am
I haven't seen this mentioned in the official Bafang install manual or any YouTube install videos with the exception
of the Czech Rep lady installer....you can see the "gap" (below) in her video but her install continues without addressing it.
There's a gap between the "fixing plate" and the BBS01 body.
Is this a problem? I imagine it would be as you torque the M6 blts up it must distort the plate.
byebyepetrol   100 W
Post by byebyepetrol » Nov 30 2014 3:49am
Measured the BB and it's precisely 68mm spec.
Sourced two washers that, with a bit of grindage will fit. 1mm thick guesstimate.
What seems to be a new refinement, the lock ring has evolved into a lock-ring cap:
This is a first; the rotten bottle cage screw snapped off while fixing the battery holder:
This is going to have to keep 'til tomorrow; I'm having dinner and a drink.
byebyepetrol   100 W
Post by byebyepetrol » Dec 01 2014 4:21am
Battery Mounted
Drilled the stuck bolt end with a .6mm drill and it just fell out inside the frame. Just a small chunk that can stay there for all I care.
Battery holder now mounted with a longer and newer pair of bolts.
I decided against using their long battery lead extension and instead soldered the leads to the terminals after threading them through the
cable grommets in the base of the mount. Shorter leads = less resistance = less cabling to worry about.
Leads stripped ready for solder:
Soldered and insulated:
It Goes.
You know that moment before you fire it up where you hope it works but experience tells you to expect the worst? I had it for a split second but
thankfully everything powered-up.
I lashed the cables with gaffer tape and took it for spin.
At this early stage it seems comparable to the hub system. It's slower to accelerate but it's more agile.
The BB is smooth, in fact the entire drivetrain is smooth.
With power off, pedalling is far easier than the hub system.
Weight: 17.86Kg = 39lbs 6 oz
The hub system was 17.92 but that was with a 350g penalty with heavier Schwalbe Marathon front tyre.
So the Bafang 250w is heavier by 290g.
I was hoping for a lighter result since the front derailleur / lever and triple chain ring are gone.
I was also hoping for more pedal assistance to match what I'm used to on the hub system.
Next stop, off to the Bafang forums to work out how to adjust the response curve.
Tats   1 kW
Post by Tats » Dec 01 2014 7:42am
Interesting - I went back to the Dillenger controller this morning as a trial after using the Lyen controller for a week. Mostly because the PAS isn't working yet and I'm getting a stiff arm using throttle all the way, especially when out of the saddle.
The Dillenger controller is torquey, with PAS its great off the mark with a very quick ramp up speed compared to the Lyen. Its also much quieter up to 22kmh. But ... from 22kmh and up the Lyen has it beat for top speed (+10% quicker), acceleration and quietness. The Lyen also seems to be much more economic with about 2 volts extra left on the battery. Need to get the PAS working on the Lyen controller and tune the ramp up to make it a bit more torquey.
cwah   10 GW
Post by cwah » Dec 01 2014 8:18am
How come a 250w motor is heavier than the 4.3kg bbs02 750W?? :?:
mfj197   10 W
Post by mfj197 » Dec 01 2014 11:41am
cwah wrote:How come a 250w motor is heavier than the 4.3kg bbs02 750W?? :?:
It's not - the individual weights are given at the top of this thread, and the motor unit weighed 3.8kg. However the total weight gain over the base bike is 7kg, which includes the battery pack, crank arms, display and everything else.
Michael
byebyepetrol   100 W
Post by byebyepetrol » Dec 01 2014 1:43pm
One thing I forgot to mention is the throttle lever offers far greater assistance than the pedal sensor when wide-open.
On wide-open the acceleration is pretty close, if not better, than the hub system. The lever provides a "turbo" boost
but only after 90 % of travel and I may need longer thumbs since the travel is a little awkward to utilise.
Finding the best angle for the lever is next.
As for programming, I've set max speed to 50kmh. The number of levels of assistance is now set to nine; via the "advanced settings menu" accessed by
holding down + and - and tapping the mode button eight times.
cwah   10 GW
Post by cwah » Dec 01 2014 1:49pm
So what would be the true weight difference with the 250w motor? 1kg?
byebyepetrol   100 W
Post by byebyepetrol » Dec 02 2014 6:24am
Not sure I understand the question cwah but the bike is 290g heavier with the Bafang system.
I can weigh the Dillenger hub system and post the data when I get a chance if that's what you're after.
Commute Number One
The first commute to work and back had a healthy morning headwind but the speedo indicated around 3-5 kmh faster than the old system.
There's no easy way of telling how similar the speedometers are between bikes. The Bafang indicates faster overall but it doesn't feel any faster.
The acceleration is less pronounced than the hub system. I played around with normal and advanced settings but I reckon there's still a lot I don't know
about programming it. I'm after more rapid initial acceleration.
This is where the throttle lever is fun. It's like a TURBO button. Turning it all the way definitely gives you more assistance than normal; it's great for short bursts.
Endurance?
I've done work and back and the battery is yet to come off max bar indicators. Even under heavy load the meter didn't move. I'll see how far I get this week without charging it.
Handling
Far better than the hub motor; if you bunny-hop over kerbs, this is the system to get. Overall more stable and agile than the front hub system.
Chainring
The standard chainring is 46 tooth. I may fit a 48T later on; same as the Dillenger system.
The cockpit is a little less-cluttered:
The system installed without major problems. gaffer and tie-wraps to tidy-up the wiring.
mfj197   10 W
Post by mfj197 » Dec 02 2014 4:36pm
byebyepetrol wrote:One thing I forgot to mention is the throttle lever offers far greater assistance than the pedal sensor when wide-open.
Yes, I think I read this on the programming thread - that the unit is set for lower assistance via PAS than throttle, but that can be altered. Can't remember which screen it's on though.
Have ordered a BBS01 myself, and just on the hunt for a suitable host bike.
Michael
Tats   1 kW
Post by Tats » Dec 02 2014 7:39pm
Good to hear there is an indicated performance upgrade - I ran out of battery on my commute to work yesterday for the 1st time. 20+kmh direct headwind doing less than 28kmh for 20ks. Having seen that current draw gets less as the motor is spinning faster I'm assuming for a lot of the commute I was in the low teens current draw. The cut-out was on an uphill section about 400m from work - a power off/on on the battery pack got me going again.
The bafang programming thread has got heaps of information and is really really informative - the interesting thing for me is if the 350w controller is the same as the 500w controller just with different configuration settings. If that's the case then there's plenty of headroom to play with, otherwise a 500w controller and keeping the 350w controller as a spare might be the easiest way to go.
byebyepetrol   100 W
Post by byebyepetrol » Dec 03 2014 1:01am
Tats; good to hear the on/off cycle got you over the line.
imagine the headwind without electric muscles. Credit for those who commute without but IMHO it's a little masochistic.
No probs thus far with my set-up. Changing gear under load isn't the problem I expected although it is to be avoided; change down on no-load before you come to a stop.
Turbo Button
The Turbo button got a workout today; it's been a humid old day here and I didn't feel like busting my guts to get home.
cwah   10 GW
Post by cwah » Dec 03 2014 7:56am
byebyepetrol wrote:Not sure I understand the question cwah but the bike is 290g heavier with the Bafang system.
what I'm trying to understand if the bbs02 added to a bike is actually lighter than it seems. Because you remove some of the bike weight when you add the motor such as the bottom bracket and front derailler. Controller is also integrated.
When you are using a hub, you only add weight and wiring + controller on top of that.
What would be good to know is with the same bike and battery, what would be the weight with the bbs02 vs the bafang!
