The intent of this post is to share the experience I had on repairing my BionX Ktm Battery pack.
Here you can find the bike specifications: http://tmp.ktm-bikes.at/e-bike/e-bike/eRace.php?lang=EN
The Motor is a:
BionX Nabenmotor „KTM Edition 2013” 250W HighTorque
The Akku: Motor 48V, Akku 52 cells = 8,8Ah = 423 Wh
After few mounts of inactivity probability the battery pack discharged too much and I couldn't recharge it anymore, it was pissing me off with a cyclic BIP every few minutes.
I did try then opening the enclosure and after disconnecting the 2 main + and - cables of the battery I did try recharging the battery with an external power charger directly into it. I didn't have a 48 power supply, I just used a 24V car battery charger (I have limited the change to 2A).
opening the case
After around 30 min of charge I connected back the the battery to the main board and packed everything back and finished charging with the Bionx power supply, yes this time after 30 min of direct charge the original charger was working. Unfortunately this second charge took very long time, around 10 hours and I could feel the battery pack becoming unusually hot during the charge.
Tested the bike and it worked immediately quite well but after few days (without recharging) the display started showing weird symbols and the bike was shooting down. Battery don't charge anymore again...
New battery pack from BionX cost 750 Euro, 1/3 of the entire bike price. Way too expensive, decided opening the battery wrapping and inspect individually the batteries.
Lable
The battery pack is composed by 13 series of 4 Parallels for a total of 52 batteries.
4P 13S
Nominal voltage 3.62, Max 4.2.
2 out of the 13 parallels was at 0.5V. I have tried to brake the parallel and recharge the batteries individually.
If you try doing this please consider safety as a matter of priority, use safety glasses at least, Lithium battery can explode easily. As a basic rule never supply the battery with more than 4.5 V and the current shouldn't never exceed 750mA to remain in the safety side.
Unfortunately none of the battery was maintaining the charge.
brake the parallel
Ordered on ebay 10x same SAMSUNG batteries at the price of 64 EUR including DHL shipment. I ordered from this site because the batteries come with a plate already soldered to the ends of the batteries.
http://www.ebay.de/itm/Samsung-ICR-18650-22P-2150mAh-3-7V-Loetfahne-Z-/321678359433?ssPageName=ADME:L:OC:IT:3160
battery
Replaced the 8 bad batteries, charged, Packed everything back and went out for a ride. Noticed on the bike display the battery was not charged 100%. The bike worked fine at the beginning but after 1 hour or so the display in diagnostic mode was showing error code 41 and the battery was stopping providing power to the motor.
Back home opened everything again and measured the voltage for each one of the 13 parallels. 2 Of them were at 2.6v, charged those 2 parallels individually. Discharged with a 6v halogen lamp adn recharged again. Recharged the entire pack again with the Bionx official power supply and tested again. This time the bike was charged 100%. Tested on the street with max level of assistance for few hours, no problem. Did another full charge and finally tested offroad on the center of Italy mountains for various hours.
with 64 Euro and many hours of work at night while the baby was sleeping managed to save 685 EUR and recovered my lovely bike.
The Motor is a:
opening the case
Lable
4P 13S
brake the parallel
battery
