MikeSSS
Today's ride was 24 miles, mostly flat, a few short and mild climbs, I pedaled a lot. The built in battery indicator showed 3/4 capacity left. Resting voltage, before charging, was 48.5 volts. Power near the end of the ride was as good as at the beginning. Power: no idea about maximum power, the throttle never is pushed all the way forward, except when using 36v or 12ah gel cells.
I'm using an Aotema front, direct drive, brushless, sensorless hub motor, on an old mountain type bike with 26 x 1.5 no name tires at 50 psi. Riding is bike path and streets, riding slow, looking at deer, avoiding imperial entanglements, pedaling mild to significant.
Bottom Line: Luna's 48v, 13.5ah, GA cell, shark battery and Luna Advanced Charger ..... exceeds all my expectations, and exceeds them by a lot. Same can be said for the Aotema hub motor and controller, a 36v setup that performs just fine at 48v.
WOW!!!
PS, thanks to all who have posted their results and therefore paved the path for we noobs to follow.
These are the good old days.
WOW!!!
