Good entry value
kneedeep   100 W
Good entry value
Post by kneedeep » Jun 20 2017 10:30am
I tested this about April in Toronto at Emmo on Spadina. This was priced at $1150 CAD the bike was sturdy and the components worked well. I ment to post way back then but lost track till I seen a local ad so copy and pasted the specs.
Emmo Electric Bicycle E-Wild - :Fat Tire,
In frame controller system,
On frame Lithium Battery,
Bafang Motor Controller System,
Equipped with Top end components,
7 Speed, Lightweight,
Aluminum FrameTire:26″ x 4″ Kenda Tire with inner tube
Weight:30 kgs
Maximum Speed:32 km/h
Travel Range:40 km
*Charging Time:3 – 6 Hours
Climbing Angle:18 Degrees
Load Capacity:140kg
Motor:Bafang 500W Brushless / 48V DC
Power Assist System:Bafang 5 Levels system
Battery:48V/12Ah Lithium Battery
Charger:AC100-120V, Smart Charger (Battery maintained while charging)
Gears:SHIMANO ALTUS 7 Speeds
Front Brake:Tektro Novela disc brake system Rear Brake:Tektro Novela disc brake system
Handle bar:ProMax
Meter & Indicator:LCD Indicator: Battery Strength, Power Assist Level, Travelling Distance and Speed
Seat:ProMax bar and Selle Royal Seat
Pedal Arm:Chainwheels Lasco
*Travel range is based on riding on level ground, no stops, no winds, warm temperatures for a 175lb rider with no extra cargo.
Chinese Ebay build in progress https://endless-sphere.com/forums/viewt ... 12&t=86149 , been through half a dozen scooter ebikes..No More of those.
I like to build it better than I can buy it. I like to think outside the box...Come to think of it where is that box?
neptronix   100 GW
Re: Good entry value
Post by neptronix » Jun 20 2017 11:32am
Looks like a nice alternative to a sondors bike. Similar powertrain, better battery, less walmart grade bike parts..
That weight though.. what a pig :(
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
