List of Speed Controller Manufacturers
7bigjohn   1 µW
Post by 7bigjohn » Jul 11 2017 11:12pm
Can someone point me to a list of Ebike speed control manufacturers? If not, maybe we can start one here. The more I look, the more confusing it gets because none of the vendors want to display the manufacturer's name. Any help would be appreciated. Thanks.
amberwolf   100 GW
Re: List of Speed Controller Manufacturers
Post by amberwolf » Jul 12 2017 2:16pm
There are probably hundreds, if not thousands of makers, and there is no certain way to differentiate between them without opening each one up, and even seeing them doesn't because some may be clones of other makers but use different firmware or settings. Or even simply be exact clones except for the quality of the parts installed on the boards. (or even including that).
So the practical thing to do is post your specific needs, then people can respond with their experience of a controller that meets those needs.
7bigjohn   1 µW
Post by 7bigjohn » Jul 12 2017 6:48pm
Alrighty. Thanks. I was hoping I was missing something but unfortunately it looks like I'm not. Thank you for you reply. :-)
Talon   1 mW
Post by Talon » Jul 14 2017 11:08pm
amberwolf wrote:There are probably hundreds, if not thousands of makers, and there is no certain way to differentiate between them without opening each one up, and even seeing them doesn't because some may be clones of other makers but use different firmware or settings. Or even simply be exact clones except for the quality of the parts installed on the boards. (or even including that).
So what you are implying is.....If the controller cost $20 bucks. Chances are it is a clone to a higher quality controller with cheaper Chinese components on the PC board? :?:
amberwolf   100 GW
Post by amberwolf » Jul 15 2017 2:08am
That's often how it works.
One company designs a product; demand for that product is then demonstrated to be high even at a high price point.
Another company makes a cheaper version of it--partly because they didnt' have to do the R&D, they just copy it; partly because they often use less-expensive parts with either lower specifications or are cheaper because the parts themselves are actually clones / counterfeits (by other companies) of the parts or types of parts used on the original. They sell it for less than the original, and thereby sell even more of them.
Another company takes the cloned version and copies it, sometimes taking out "extra features" that might save a bit of money (sometimes those are not extra but actually necessary parts of the design, so the device becomes less reliable than the previous versions), using even cheaper parts, even less QC, etc.
Eventually this process reaches a point where a significant number of the product don't even work right (or at all) right off the production line, or die immediately upon first use. But those get sold anyway, because it's still money, and if they sell them to dumb foreigners overseas, who is gonna bother paying to ship them back? ;)
Also, at any stage in the cloning process, it may not be an exact copy--they might change all sorts of things, either because they want to make it cheaper, or because they think they're improving it, etc. They might even actually do so, and sometimes a product that is actually significantly better than the original will arise, even though it's cheaper.
I'm sure this process happens in every manufacturing-capable country around the world with different types of products. :(
