Gt it1 Rare left hand side frame. what motor to use
Get real world experience and user feedback on the electric bicycle products.
aCeMadMod
Post by aCeMadMod » Mar 21, 2018 4:47 am
hi all after 7 year of looking for a.Gt it1 frame
https://duckduckgo.com/?q=GT+IT-1+MTB&b ... &ia=images
what would be best way make it a mid drive what motor to pick any input would be good . money is not care this ebike
I guessing any more then 2000 watts will kill gerbox
thank you all
SlowCo
Re: Gt it1 Rare left hand side frame. what motor to use
Post by SlowCo » Mar 21, 2018 8:28 am
BBSHD seems to fit and is <2kW.
aCeMadMod
Post by aCeMadMod » Mar 23, 2018 6:10 am
hi thank input , it odd one ,,, if I skip. the gearbox.
what is best 1 chain wheel setup how Mary teeth should I use ? . not power limt 8)
what motor
has my rear hub is fixed.
this frame Way stronger then look on pics.
can you mods the gearbox. ? it nexus 8 I been told what max watt you can put into it
any help from es gods have helpful :D
aCeMadMod
Post by aCeMadMod » Mar 25, 2018 7:29 am
hi all look like a got a long term plan and short one
I try test the frame with what I have around. other one is to wait to get a. lighting kit. he make for me when he has time
it looks like I have most of what I need to test it .
neugat pl870 25.1 gearbox can't find data about this gearbox. look like max input 7000 rpm
I think like a PLQE080
https://www.neugart.com/en/products/pla ... qe/#PLQE80
motor 360 out runner 180 kv 2800 watt 12s lipo or can use Astor 3220. deta or wye 6t motor not real what I want to long
esc 250 amp 14 s and vesc
2 x 28 teeth for go cart chain 219 1x 14 teeth 1x 12 teeth 1x 11 back wheel all I have84 teeth for gearbox to use what best gearing at 12s lipo
or should use belt drive from motor to gearbox
I need some help. what best for this setup in teeth 8)
any input will be good thank you
izeman
10 GW
10 GW
Post by izeman » Mar 26, 2018 12:56 am
Why did you choose the most complicated setup for a mid drive anyone could think of?
What is the benefit of this complicated chain routing?
If you look at my bike you will notice that even if it's a simple frame, it was not easy to get a clean chain line.
A mid drive per se is more complicated than any hub motor. You are adding complexity to more complexity.
And tbh i have no idea how to help with gearing issues if you haven't chosen a motor yet???!
