Don't we all wish we had this on our property
Solar, wind, hydro and other non-fossil sources of electricity.
John in CR   100 GW
Post by John in CR » Jul 17 2020 7:27pm
A new friend who want my help building a high powered ebike is also working on a hydroelectric project on his dairy farm that has an electric bill of over $1000/mo. It's up in the mountains at 4,000m of elevation and he has a small river with year-round flow and a whopping 200m of head :shock: . Even with just a 3" pipe he can produce an incredible amount of electricity at the 400gal/hr rate he is planning.
Hopefully he can negotiate a grid tie arrangement where he gets paid for the excess he generates.
john61ct   100 GW
Re: Don't we all wish we had this on our property
Post by john61ct » Jul 18 2020 11:32am
very nice!
no spawning fish to accommodate?
Hillhater   100 GW
Post by Hillhater » Jul 19 2020 12:11am
ES member “craneplaneguy” has reported on his “mini hydro” system for several years. Avery nice to have facility.
Another member ( ? Aussie ? Forget name) has also reported on his DIY mini hydro working with limited head, but continuously outputting 1+kw to a large Pb bank, and also to a experimental “pumped hydro” tank system for storage.
Ideal if you have the land , water, and terrain to enable such a system.
John in CR   100 GW
Post by John in CR » Jul 21 2020 3:48am
john61ct wrote:
Jul 18 2020 11:32am
very nice!
He does have some trout ponds fed with a continuous flow from the river, but no migratory fish to worry about.
999zip999   100 GW
Post by 999zip999 » Sep 13 2020 3:03pm
What voltage ?
JackFlorey   10 kW
Post by JackFlorey » Sep 29 2020 1:00pm
John in CR wrote:
Jul 17 2020 7:27pm
He should be able to get about 2kW continuous, or about 1300kwhr/month. That should offset about $130 a month at 10 cents/kwhr.
JackFlorey   10 kW
Post by JackFlorey » Sep 29 2020 1:01pm
999zip999 wrote:
Sep 13 2020 3:03pm
What voltage ?
Systems like this often use "wild AC" from generator to rectifier - voltage/frequency determined by RPM and regulated by a MPPT controller.
John in CR   100 GW
Post by John in CR » Sep 29 2020 10:42pm
JackFlorey wrote:
Sep 29 2020 1:00pm
John in CR wrote:
Jul 17 2020 7:27pm
It's been a while since I did the research to confirm his estimate of 6kw continuous as a fairly conservative estimate, but it was more than enough to offset the $1k/mo electric bill for his dairy farm. Note that our 98% green electricity is nationalized, and despite being primarily hydro power, our cost per kwh is almost double your 10 cents. Too bad there's such corruption, because I have pleasant dreams of 2 cents/kwh in the areas supplied by hydro in parts of Canada. If I live long enough to see real global warming, maybe I'll head north to Canada, which would become the new farm belt of the west.
JackFlorey   10 kW
Post by JackFlorey » Sep 29 2020 11:12pm
John in CR wrote:
Sep 29 2020 10:42pm
Hmm. 400 gal/hr is .42 liters per second. Are you sure that's right? That's a pretty small amount of water to run a hydro system with.
John in CR   100 GW
Post by John in CR » Sep 30 2020 1:13am
JackFlorey wrote:
Sep 29 2020 11:12pm
John in CR wrote:
Sep 29 2020 10:42pm
Ah, now I see where I went wrong on the original post. It's 400gpm not per hour. His river and waterfall have real flow, and then we both discounted each thing quite a lot to prove his desired 6kw seemed quite reasonable.
JackFlorey   10 kW
Post by JackFlorey » Sep 30 2020 3:44pm
John in CR wrote:
Sep 30 2020 1:13am
Ah, now I see where I went wrong on the original post. It's 400gpm not per hour. His river and waterfall have real flow, and they we both discounted each thing quite a lot to prove his desired 6kw seemed quite reasonable.
Oh, OK! Definitely agree then.
