Friction drive 12v alternator w/26" hub wheel
Solar, wind, hydro and other non-fossil sources of electricity.
Locked
1of3   10 W
Post by 1of3 » Oct 08 2011 8:01pm
Has any one ever done this.?
12 volt light bulbs (1157 ?) & sockets are cheap, 12 volt 6 amp 14" 1000cfm fans are $20 each.
24/7 house fan force and lights for nadda sounds good to me.
Those with calculators can keep to themselves. Please.
What about practical experience, anyone.?
Thanks.
neptronix   100 GW
Re: Friction drive 12v alternator w/26" hub wheel
Post by neptronix » Oct 08 2011 8:08pm
This is an early 1990's era setup.. is not very efficient.. and friction drive likes to eat tires and collect road dirt which clogs up the motor and roller surface.
Cheap, but not recommended. Chain drive and hub motor drive are far superior.
1of3   10 W
Post by 1of3 » Oct 08 2011 8:20pm
neptronix wrote:This is an early 1990's era setup.. is not very efficient.. and friction drive likes to eat tires and collect road dirt which clogs up the motor and roller surface.
Sorry,
Mean to have stationary, mounted on purpose to compress against a wide 'pulley' alternator. Have 26" hub motor, want to turn alternator for 12 volt power.
So, maybe a belt around 24~" wheel instead of filling tire tube for 'traction' would be less work to hub motor.?
Board index ‹ Alternative Energy ‹ Alternative Energy
Ricky_nz   10 kW
Post by Ricky_nz » Oct 08 2011 8:28pm
Sorry,
So if I get this right you want to use an alternator and your hub motor to convert the voltage from your ebike battery to 12 volts?
There are far more efficient ways to do this without rotating parts.
Look up DC DC converter on ebay.
Latest Projects: High power vector controller for Turnigy 80-100.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Keewee Stealth dirt jump with MAC 10T rear gear hub
1of3   10 W
Post by 1of3 » Oct 08 2011 9:49pm
I a was just asking folks that actually attempted to do so, not hear say.
But, then again. You may not no me. I am a mason.
Practiced practicality is pretty much law.
SamTexas   100 MW
Post by SamTexas » Oct 08 2011 10:07pm
Attempted to do what???
I read your post 3 times and I still have no idea what you want to accomplish. What's truly weird is the fact that you ask questions but don't want an answer from people who know how to calculate. I know a couple brick workers myself and they are not bad at math.
"hear say"? You must mean theories. Without theories, we would still be living in the dark age.
neptronix   100 GW
Post by neptronix » Oct 08 2011 10:53pm
You threw me off when you said friction drive, so my bad. That's usually a term used for oldschool ebike systems..
Um anyway i don't know what you're trying to do either. lol. Trying to generate electricity for your house by pedaling a bike to generate power?
1of3   10 W
Post by 1of3 » Oct 09 2011 1:16am
Sorry for any confusion.
I am just asking if any one has ever used an electric powered wheel to turn an alternator.
What did you do, what is the results.?
As I will do it, just out of curiosity.
Unless making beans from dog shit don't work. State it, with YOUR results. Not urls of 'fact'.
All others, don't bother.
Pretty simple.
Ricky_nz   10 kW
Post by Ricky_nz » Oct 09 2011 1:25am
1of3 wrote: But, then again. You may not no me. I am a mason.
Ah that explains it, thick as two bricks.
Feel free to ignore several hundred years of scientific knowledge.
No one does what you describe any more because there are better ways but it will probably work just poorly.
on the other hand it sounds like you just want to waste your time and thats fine by me.
have a nice day troll
Locked
