There's nothing I enjoy more than sitting down to read ES with a paper and pencil...I love it
. When I look at solar panels they always seem to be listed as watts and volts together. Example: 100W 48v or 100W 12v. I would think that the voltage of the panel would have an effect on the time to charge a deep cell battery, such as a 12v 150Ah deep cell.
You stated: "So the Time it takes to charge is the Energy divided by the Power."
So Wh/W = h. That seems self-evident. Also, W = v * A which A = W/v follows and Wh = v*Ah. Here is where I'm a bit confused with the units. The deep cell battery has 1800Wh. This is then divided by the watts of the panel 100w, yielding 18 hours regardless of the volts of the panel. If I try to include the panel volts I get Wh/(v*A) but Ampss or A = W/v. So I get Wh/(v*W/v) and the volts cancel out. There must be something in this system I'm missing like a converter, inverter, or some other device for which I don't understand the process, that adds volts to the numerator or somewhere else. What am I missing? Or is it true, solar panel volts don't fit into this equation.
