Solar Panel to charge a 52v 13.5 ah battery pack?
Solar, wind, hydro and other non-fossil sources of electricity.
fcbrants   1 mW
Re: Solar Panel to charge a 52v 13.5 ah battery pack?
Post by fcbrants » Jul 13 2017 3:19pm
Thanks Amberwolf, That was the information I was still missing. I appreciate your help!!
Franko
amberwolf wrote:BTW, to be more specific, to get the rough charger end voltage for 80% of the voltage of the battery, it's 80% of the difference in voltage between empty and full, added to the empty voltage.
However--if you want actual 80% of charge state, you have to know which cells are in the pack, then look at the actual cell specification sheet, which has a voltage-vs-state-of-charge chart. Then find 80% on that particular chart, and multiply by the number of series cells. Then use that for the charger's final voltage.
Just keep in mind that if you don't at least periodically charge to the full voltage, the BMS probably won't balance the cells. It won't matter if they're really good cells that are well-matched and used well within their specifications and not run down too far; if they stay balanced there's no worries. (but it would require manual checks to find that out).
Matt Gruber   100 kW
Post by Matt Gruber » Aug 07 2017 8:53am
MPPT BOOST low low price!
https://www.youtube.com/watch?v=omAhsQqwWSo&t=248s
see update too. set V, does not trickle.
similar version on ebay $33
very cool at such a low price! 300 watts! 24v up to 100v
