Wind Energy Or Solar Energy?
Solar, wind, hydro and other non-fossil sources of electricity.
jacksmith12   1 µW
Post by jacksmith12 » Oct 04 2017 4:18am
Which type of energy can be best use as alternative energy in future? wind energy or solar panels? I have a generator at my garage and i want to replace it with any of these, i want to invest by considering future prospect of alternative energy.
Hillhater   100 GW
Re: Wind Energy Or Solar Energy?
Post by Hillhater » Oct 04 2017 5:46am
A little background reading..
https://endless-sphere.com/forums/viewt ... =7&t=89002
But how much power do you need ?.. 1kW ?, 5, 10 kW ?
What will you be using it for ?
billvon   10 MW
Post by billvon » Oct 04 2017 1:22pm
jacksmith12 wrote:Which type of energy can be best use as alternative energy in future? wind energy or solar panels? I have a generator at my garage and i want to replace it with any of these, i want to invest by considering future prospect of alternative energy.
Solar; it's cheap and easy, provided you are in a good area. Most people don't want to do the work to install wind. They mount tiny turbines in poor locations (like on their roof) and then wonder why they are seeing very little energy.
--bill von
craneplaneguy   10 kW
Post by craneplaneguy » Oct 04 2017 9:41pm
Solar, absolutely hands down, small scale wind is not even worth considering. UNLESS, it's an off grid system, then, and only then a wind turbine in addition to a PV system. No matter how big the PV system, it's done once the sun goes down! A windy night is where a wind turbine shines. If grid tie, go solar only, no moving parts, no noise, no tower, and immediately from day one more power for less money. These are very tough times for small turbine manufacturers, they are dropping like flies.
jonescg   1 GW
1 GW
Post by jonescg » Oct 05 2017 1:27am
The Rainbow Power Company used to say "If you live somewhere windy enough to justify a small wind turbine, you probably wouldn't want to live there".
But they are great for generating power in bad weather. Worth the investment / headache? Maybe not.
Some lucky folks live where it rains enough that a micro-hydro system can work. Pelton wheels are best for this I think.
http://www.rpc.com.au/catalog/hydro-power-c-8_225.html
amberwolf   100 GW
Post by amberwolf » Oct 05 2017 2:06am
Most likely the OP is a spammer. (based on other "questions" I've seen like this before). I bet if you check Stopforumspam or other spamcheck sites for the IP, you'll find it there. I'd also bet that it isn't a USA IP, despite claiming to be from USA in profile (and I don't think English is their primary language based on their post).
Most likely the OP will come back and edit in their spam into their profile, or into their post.
