Power Options for Off Grid Cabin in Northern Ireland
Solar, wind, hydro and other non-fossil sources of electricity.
campbell1987   1 mW
Post by campbell1987 » Oct 18 2017 4:40pm
Hi all, I've ha d a friend ask me to look at which would be his best option for getting some 240VAC to his cabin in the mountains, The weather here is quite poor most times so we were thinking maybe some sort of combo setup like some solar pannels and also maybe weld up some home made turbines using car alternators to charge a bank of old car batteries, I know it sounds a bit rough but the plan is just get enough for at least 1-1.5kw but as cheap possible,
Hillhater   100 GW
Re: Power Options for Off Grid Cabin in Northern Ireland
Post by Hillhater » Oct 18 2017 6:41pm
How much use does this cabin get ?
Permanently occupied ?, one night per week ?
What do you intend to power ?....just lights, heating, cooking, hot water, ????
Im guessing you do not want a generator ? (Probably the simplest , cheapest solution)
amberwolf   100 GW
Post by amberwolf » Oct 19 2017 2:47am
"Best" is relative; you'd need to define specific priorities and needs, along with actual power usage (both peak and continuous watts needed, as well as kWh needed) to figure out what "best" means in this case.
A generator is the only easy and relatively cheap option, if neither wind nor sun are constant and sufficient.
