Inverter with my Solar system make a noise! why?
Solar, wind, hydro and other non-fossil sources of electricity.
General_Lee   10 W
Post by General_Lee » Apr 26 2018 7:52am
Hi guys, I bought a PowerBright ML2300-24 inverter, I tested it and when I plug a devices the inverter make a inside noise. Is it normal? this noise is not good to ear!
I plug a PC computer on it and the power supply on this PC make a noise to.
What is the problem?
Thanks.
Alan B   100 GW
Re: Inverter with my Solar system make a noise! why?
Post by Alan B » Apr 26 2018 8:23am
Inverters often make some noise. This particular unit is putting out a "modified sine wave" which is actually a square wave with three states - low, zero and high. This causes the AC supply in the load to make noise. The square wave is not a nice clean 60hz sine wave that is the normal for AC power, it has harmonics across the audio spectrum that you can hear.
General_Lee   10 W
Post by General_Lee » Apr 26 2018 8:34am
Alan B wrote:
Apr 26 2018 8:23am
This is bad for the devices plugged on it? like I said, I use a computer and I ears a noise from the Power Supply. I not ear that when it plugged to home wall AC or APC UPS.
Alan B   100 GW
Post by Alan B » Apr 26 2018 8:54am
General_Lee wrote:
Apr 26 2018 8:34am
Alan B wrote:
Apr 26 2018 8:23am
If you do some searching on "modified vs pure sine wave" you can find articles and videos answering this question in more detail. In some cases it works fine even though it might make noise. In other cases it makes the power supply warmer than usual. In yet other cases it does not work or even causes damage. It depends on how the load reacts to this waveform.
billvon   10 MW
Post by billvon » Apr 26 2018 10:38am
General_Lee wrote:
Apr 26 2018 8:34am
For some devices, yes. It depends on how they are designed. It's very bad for any motor based appliance (refrigerators, pumps.)
--bill von
General_Lee   10 W
Post by General_Lee » Apr 26 2018 11:24am
billvon wrote:
Apr 26 2018 10:38am
General_Lee wrote:
Apr 26 2018 8:34am
Thanks, Having known, I have not checked this before :oops: . My mistake, I know now the best is Pure sine wave.
