jimmyhackers
- Joined
- May 11, 2015
- Messages
- 602
hello all..... recently got myself an mpt-7210a solar boost charge controller. but i think its not playing ball.
its linked upto 40w of solar panel and charging a pair of 12v 20ah SLA batteries in series to make 24v.
the batteries are balanced by a lead acid battery balancer, which appears to be working/balancing them fine.
https://www.ebay.co.uk/itm/Solar-System-Battery-Balancer-Equalizer-For-Lead-acid-Batteris-HA01-HA02-Charger/123235021743?hash=item1cb16133af:m:mJJJN8srJeP-rb_mFVq7d_w
they are also linked upto a 1000w UPS (uninteruptable power supply)
essentially the problem is the charge controller doesn't appear to be sensing the battery voltage correctly.
setting the battery voltage to 26v and the charger says they are full and stops charging.... changing it up or down seems to make no difference. even when its set to 30v it says the battery is full and doesn't charge.
im not sure whats up with it..... either its broken of the battery balancer or the UPS is messing with it some how.
any help would be appreciated.
