Apple Cider Vinegar / ACV, health benefits
Discussion about fueling and maintaining the rider.
spinningmagnets   100 GW
Post by spinningmagnets » May 08 2018 2:00pm
My wife finally started taking some, and her joints don't hurt anymore (inflammation reduction?). With reduced joint soreness, she now sleeps deeper and longer, so...she has more energy and is happier (from both the reduced soreness and also increased sleep quality). I had suggested to try ACV about once a year. No doctor visit, no prescription, cheap and easy to try...
She finally saw some gel capsules, which avoided the problem of the harsh taste and smell. I have a friend who's been using a bit of ACV each day for several years now. He dilutes it with water, and then over time...he simply got used to the taste of his "medicine". He still uses the generic liquid, because its so cheap.
I would suggest to anyone to try it for three days. That's long enough to see if you feel any different.
Dauntless   100 GW
Re: Apple Cider Vinegar / ACV, health benefits
Post by Dauntless » May 08 2018 2:22pm
Sounds dramatic expecting a 3 day result. My understanding is it's supposed to help with the 'Fermenting' digestive system Dogman referred to recently, which then affects problems caused. I understand joint problems to be on that list. The capsules even worked that well? Usually you're better off with the original source, but with things like garlic and vinegar people would like a work around.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
neptronix   100 GW
Post by neptronix » May 08 2018 3:31pm
I like ACV so much that i did a video on it for GERD.
The fingers   100 GW
Post by The fingers » May 08 2018 6:51pm
A swig helps clear the crud before a singing gig.
:wink:
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
methods   100 GW
Post by methods » Jun 10 2018 12:43pm
Ack... had to throw mine in the bushes :D
I just cant handle the flavor.
When I have an upset (system) these days I have found Coffee does the trick
It its a big acidic dose - but more importantly - its a stimulant
For me personally
The shot of acid along with the euphoria of caffeine...
Derails me from the ICK
and puts me on track for a good day.
The best I can tell...
When my gastro system goes to hell...
(For me personally)
Its a mix of too much sugar, too much stress, not enough exercise
Lowering stress
By drinking water and exercising hard
(and sometimes drinking a little stimulate to get there...)
Does it
Good luck and report back
-methods
Increasing battery voltage and controller current limit will result in a non linear experience
nickatnoon61   10 mW
Post by nickatnoon61 » Jun 22 2018 1:39am
ACV, one of the BEST health foods there is! I know from about 50 years using it internally and externally.
methods   100 GW
Post by methods » Jul 03 2018 11:26am
Had another episode
Trigger set off gnarly stress - Exwife with her sub-human lawyer trying to wreck life again (4 years running)
Snot pours out of my nose and down my throat
Strange clear and very thick mucus comes up out of my throat by the cup (I can fill 3 cups easy over a 4hr period)
Stomach fills up with gas and will not let it out
Bile piles on top of the gas - some sort of snot substance
Gnarly feeling of nausea - debilitating - only option is to induce vomiting
Vomiting yields either gas or snot - no acid
Hiccups, tossing, turning - cant sleep all night
Extreme mental spinning - problem that is insolvable
Extreme physical discomfort
The sort of thing you feel when a psycho is trying to wreck you (ask me how I know?)
The strangest part is the liquid
Perfectly clear and extremely thick
Holds together across a 4' gap
Pours like syrup but much sticker
Comes up from my stomach and down from my nose by literally cups
Mouthfulls
Chokes me in my sleep and I have to wake over and over to spit it out
Gnarliest of gnarly
I can drive at over 150mph
I can drop into literally 15' wall-waves on a tiny piece of foam up against rock cliffs - certain drowning and death
I can walk right up to any cop, CEO, whatever... and drill them... I am no coward
But
When a psycho is after me... It triggers primals
Happy to fight but cant
Hands tied behind my back
That leads to helplessness... and I dont do well with that.
Tried to knock myself out with cough syrup a couple times - 2 doses
Has no affect. Too much adrenaline - body thinks I am poisoned or under attack
When it happens I just have to sleep it off the next day
Leaves me "off" for two to three days
Then... like it never happened
Now when I feel it trigger I go straight to the beach
Jump off a 20' cliff
Fight the ocean
That works
Nothing else does
Certain this is beyond the benefits of ACV... but... if anyone else has those symptoms... get exercise.
-methods
Dauntless   100 GW
Post by Dauntless » Jul 03 2018 1:52pm
methods wrote:
Jul 03 2018 11:26am
Had another episode
That's why I ain't ever gonna have an exwife.
One thought is clearing your intestines. A few days of just spinach and soup broth. Mom had whatever condition swole her legs and made it hard to walk. Went away and she was walking again. There's all sorts of things that feed the various yeasts and bacteria in your system and you ed up with too much. When stress sets that off it could be mass killing of that stuff by the stronger battery acid being produced causes the symptoms but if thesebthings were reduced you wouldn't have the episodes.
- Arthur C. Clarke
The fingers   100 GW
Post by The fingers » Jul 03 2018 4:34pm
Sugar feeds the yeast. Gonna try some Yakult Light. :P
Hebrews 9:27
methods   100 GW
Post by methods » Jul 12 2018 8:21am
Yea...
My current partner tells me that I gobble too much sugar
Naturopath tells me the same thing.
I eat sugar, dont drink coffee (Water), and take the stressful path at all times
Today I woke up at 3:30AM
Feeling ok enough
-- then thought about eh... life... money mostly... ---
Got all wound up
Barfed a little bit
Drank some coffee
Wrote some posts
Now for a big breakfast of SUGAR :lol:
.. .. .. You know you are really "going for it" in life when you barf from the stress from time to time .. .. ..
(set a new standard to push myself to lol)
.. .. .. I have found that when you need to perform (be it on stage, in a big meeting, in the big waves, on a bike going way to fast...)
that
When it is show time - I am cool as a cucumber
... sometime before or after that ...
I pre or post process the fear, anxiety, stress
/ Secret is to NEVER fall apart when it matters \
for me at least
Sucks but works
No idea what other extreme characters do ... but I will tell you... that I lay my balls out on the stamp mill all the time.
-methods
eyebyesickle   10 kW
Post by eyebyesickle » Aug 16 2018 10:43am
UGH
Thanks Neptronix - looks like I am switching from taking swigs to tossing back shots =) *GULP*
my pooooor enamel
neptronix   100 GW
Post by neptronix » Aug 16 2018 10:59pm
Methods, you got some crazy shit going on that i've never heard of.
Get off that sugar though, for god's sake. :shock: I cured so many insane health problems when i dropped carbs out of my diet.
Hey eyebyesickle, make sure to water the stuff down, like 5 parts water to 1 part ACV.. straight shots will certainly kill your teeth over time!
eyebyesickle   10 kW
Post by eyebyesickle » Aug 17 2018 12:01am
neptronix wrote:
Aug 16 2018 10:59pm
Yeah I have been taking it forever. I water it down sometimes but honestly usually take a swig right down the pipe - have had enough damage to my teeth, its all over for me :cry: :lol: but yeaaaaah I don't need any more trouble. Sometimes we make a tea with it at night though (when its not too hot summer) so that's watered down. I don't know why I never thought about tooth enamel - I was just 'showing off' to people that could barely stand it and it became a habit I guess!
rumme   100 kW
Post by rumme » Sep 20 2018 8:03am
It sure does taste awful so thats probably why its so healthy for us. FWIW...when I first started taking it, I just drank it straight....and it burned my esophagus so badly , it caused bleeding and I had blood in my stool. I do not recomeend drinking it straight down , undiluted.
Yes, the massive sugar, HFC, bad carbs, genitically modified foods we eat, are destroying or good gut bacteria. ACV, helps to reset that problem, but in the end, the best thing to do is to stop eating shitty foods and sugar.
FWIW....I also take activiated charcoal pills, when my stomach, intestines are going nuts and I have bad bloating, gas. Works very well and the pills bind to the toxins in our gut/stomach so you can excrete them better.
Hey eybyesickle..how ya been bud ?
rumme   100 kW
Post by rumme » Sep 20 2018 8:07am
Make sure the ACV you are using, isn't derivied from genitically modified apples....the key is to stop ingesting these types of Frankenstein foods , cut out the sugars and bad carbs/grains/milk, artificial sweetners, ,etc. Try to only drink filtered water or fresh lemons squeezed in water with stevia to sweeten it . Also, if you have severe gastric issues { like I do} peppermint tea works great to sooth the stomach.
rumme   100 kW
Post by rumme » Sep 20 2018 10:52am
Ive done alot of experimenting on my own body, to try and see what works and doesnt work. IMHO, the 3 things most destructive to our bodies are inflammation, infection, insulin release { I call it the three I"s}
I have found, that the most beneficial things I can take are .ACV, IODINE PILLS, ACTIVIATED CHARCOAL PILLS, COLLODIAL SILVER and dont ingest sugar, bad carbs, bad drinks . I drink a lot of filtered water or water flavored with fresh squeezed lemons and stevia or sometimes peppermint tea/ iced tea sweetened with stevia.
I refuse to use sugar or artificial sweeteners as additives to my drinks, food. At age 50, I have also refused any permanent prescription drugs that doctors try to put me on. They tried to get me on statins years ago, told em no way.
aroundqube   1 kW
Post by aroundqube » Sep 23 2018 10:56pm
Apple Cider Vinegar also works well as a lure for fruit flies. Fresh out of the bottle, the bugs are attracted right to it. Just be creative, and design your own trap.
rumme   100 kW
Post by rumme » Sep 24 2018 2:21pm
aroundqube wrote:
Sep 23 2018 10:56pm
I tried this in my home, for house flies. It didn't work well. Went back to sticky traps.
The fingers   100 GW
Post by The fingers » Sep 24 2018 3:30pm
The fly traps I remember on the farm used milk to attract them. :wink:
Hebrews 9:27
Surfingjeff   10 W
Post by Surfingjeff » Feb 03 2019 9:54am
It’s a well known affect with viniger a lot of research done in the fifty’s . In fact a nobel prize was won . It helps with the creb cycles or digestion. What’s even stronger and more effective is citric acid. My mom had a company for over 30 years sold citric acid tablets . It has the same effects but easier to digest .
