Overvolting Bafang m420
Yer bike busted? tell us all about it here.
Cooker   1 µW
Post by Cooker » Mar 22 2021 10:53am
Hi guys, I hope someone could help me. I have braded ebike with bafang m420 motor. It's locked. I cannot overwrite settings. Since it's not posible to change wheel diameter or speed limit i thought that maybe hardware change can bring some more power to the engine. It comes with 36V battery. I saw some specs on the web of this motor and it looks like the controller can handle different types of battery Up to 52V althought I'm not sure if mine one can, but it's probably universal. Is it?
My question is, is it a good idea to upgrade the battery from 36V to 48V? Is it safe? Will this bring me more power?
Thank you for any tips
AngryBob   1 kW
Re: Overvolting Bafang m420
Post by AngryBob » Apr 02 2021 5:07am
Here is a tip.
If you cannot supply any useful information, it is extremely unlikely that you will get any useful answers.
Identifying the "brade" of the bike, meaning the company which implemented the restrictions you are trying to circumvent, would be a useful first step.
An educated guess would be that you will need a replacement controller and display, and perhaps someone else to choose and install it for you.
"Not being treated like a dumb dick is one of the incentives we have to become less stupid." - Balmorhea.
fatty   1 kW
Post by fatty » Apr 02 2021 2:00pm
Agreed, this post is unclear.
You tried using the "Bafang Configuration Tool" and the settings were locked?
The motor is available in/configurable for 36/43/48V, not 52V. Try 48V -- if it doesn't trigger HVC, it will indeed be faster and you can downshift for more torque.
Don't take advice from:
there is no difference between a mean well CC/CV power supply and a device sold as a charger. they operate in EXACTLY the same way
Testing has demonstrated that ordinary rim brakes thermally outperformed all but the best disc brakes...You'll always add weight and cost, while not equalling the capabilities of comparable rim brakes, if you use discs
