What is the "battery jumper", and what exactly does it do?
Regarding the battery current limit--what is your controller's current limit?
And/or:
What is the max current you have measured the system using, peak?
What is the max current you have measured the system using, continuosly?
Those are what you need to know, to get a battery you know is capable of handling the demands of the system.
FWIW, a 36v battery with a 30A continous capability can output about a thousand watts continously. So if your system is a 750w continous system, then such a battery could handle it, even if it has peak usages of up to a thousand watts. If your system has a higher continuous / peak demand, then you'd need a higher-capability battery.
Another thing to ensure is that you get a battery with enough total Wh to give you the range you need. Do you know about how many Wh/mile you presently use? Or at least, what range you get with the battery you have, *and* what Ah (or Wh) of the battery you have is capable of?
