Gotta Hole in my Phaserunner
goatman
Surrey, B.C.
couldnt pull the xt60 out the other day, then i noticed the speed would disappear and then come back, today it died in the middle of the Pattula Bridge, after doing the walk of shame here it is
cant clear the faults
thinking of doing some surgery to see if its fixable
any ideas?
had to reef on the xt60 to get it out
the negative was all melted
crud on the pins
tried another xt60 but it was loose
going to clean it up and open up the pins to see if thats the problem
got pins open but phaserunner still isnt working
one of the faults is code 1-8
last time i had code 1-8 on another pr i have, had to wait 2 days and put it in the oven to fix it
https://endless-sphere.com/forums/viewtopic.php?f=3&t=109781&p=1608279&hilit=oven+rack#p1608279
going to let it sit 2 days and see what happens
battery voltage isnt being read correctly, it was initially saying 3 volts and it slowly crept up to 7.34v
the battery is about 65v right now
#284, #285 and #286 should read about 65 but are at 7.78, 7.78, 7.84
picture wont upload here?
address 306, 307, 308 should be 0.51 and theyre at 0.16, 0.15, 0.16
that picture wont upload either right now, try later
very similar to the last 8-1 fault so maybe theres hope it will recover
markz said:
Not a lot of power is that thing, leg muscles must be used, kinda cool for you
goatman said:
what the heck is that thing?
kinda cool
wheres a place thats warm all the time in Canadus
took a heat gun and heated the heatsink i made for the PR and got the PR to 63 celsius
heres a pic of its internal temp after it cooled for a bit (notice the battery voltage is still wrong)
address 306,307 and 308 are no longer at 0.16,0.15,0.16 but are now at 0.48,0.47,0.48
i think it should be 0.51 but that should solve code 8-1
i could clear the other low voltage error codes and get this working but ASI or Grin wont let me lower the battery settings lower than 12 volts
picture wont upload again
hey moderators, is there a limit to how many photos per post?
Yup, it's a Giant Revive. Picked it up last year. It had a 250w Hilltopper kit on it when I bought it. Basically a 250w geared 8fun motor with an on off button and a saggy 24v lion pack. Saving that kit for my kid.
I had a 24f sitting here begging to be used so strapped it to the Revive, assembled a 20ah 18s lipo pack and added proper throttle and ebrake. Haven't swapped out the motor yet, debating between leaf and mxus. As it stands, 74v hot off the charger, limited to 20 battery and 45 phase. That little bugger screams along at 30mph. Obviously not climbing any steep hills but not bad. Looking forward to the new motor though. But I digress, Nucular all the way.
wanted to see if i could get into the phaserunner and see what the yellow thing is, might be some kind of fuse
https://www.digikey.ca/en/products/detail/bourns-inc/MF-RX250/259986
start peeling
see if i can read this number
couldnt find that number but this is 72v/40amp
https://www.digikey.ca/en/products/detail/bourns-inc/MF-RX160-72-2/3767906
keep looking
thought they used 2 different potting compounds, 1 for the board and a different for the form but i pulled something off on 1 side
goes right to the outside surface of the potting
says 151 on it
might be this, 10uh Inductor Choke Coil
other side went ok
just need to dig a litte more potting out and ill unscrew the heatsink
used a T10 to get the screws out and needed to get the heatsink hot with a heat gun to soften the grip of the epoxy to pull the guts out
T290 BV5L15
found a ball of solder when pulling back some potting
from where the pick is
cleaned up that area, nothing looks fried
cant see a reason for that solder to be there and im not going to dig around there anymore
start testing i guess, its too bad i ripped that 151 part off or id try plugging it in :D
Nice autopsy pics. I take it you're past the 3 year warranty period. :oops: Did you smell anything before you had the issue with the XT-60?
Pretty incredible piece of electronics for it's capabilities. I wish Grin would come out a with a big brother version.
3yr warranty????
i thought it was only a year :lol: :lol: :lol:
hey grin, you want to send me a new one???
checked the fuse for continuity and i have continuity
ill order a 151 if digi-key has them and see if it works
noise
the trike gets noise from the motor cable at the axle over 3200 watts
the stiletto sometimes gets noise at 3500 watts
same batteries
both phaserunners both heavy gauge grin motor cable but the wires are a little tighter going through the trike/mxus axle than the stiletto/3540 motor
saw those rental bikes all over vancouver today.
gotta question
i hard wired this PR in
this new phaserunner wont turn on and off, stays on
auto tuned fine, no faults
i run 2 wire regen, i connected it black and blue
is it supposed to be black and blue or red and blue????
regen works when activated while riding but if i push the regen button with tire in air, it wants to go backwards, tries to keep bouncing backwards, release the button and virtual electronic freewheeling starts turning motor forward. tire should just stop
went for a quick test ride and a bad vibration goes through the battery box on take off????
no faults
regen is the only connection i might of done wrong
edit***
went reading the version 3- PR manual
with the new CA plug, i think its made for a ca3 and im running a ca2 on this bike
the default for the on/off is different on PR-V3
the regen is wired correct as far as i can tell
the vibration on starting off, might be able to get rid of that by changing the throttle ramp up rate from 50ms to 70ms
im thinking this PR is putting out more amps than the old one
i used my old settings
when setting up the virtual electronic freewheeling the old setting was 1.5amps for 1 rev/sec
had to lower it to 1.2amps with the new PR
i have a ca3 on the trike, if i can get rid of the shudder tomorrow then ill just swap the phaserunners between the 2 bikes so the PR3 is with the CA3 and the PR2 is with the CA2
