Hi everyone,
I was hoping for some help with a Bafang M420.
Basically everything turns on and seems to work correctly, but the pedal assist does not kick in, whether on 1 or 5. The display shows it constantly using 0 watts of power too. Adding to the confusion is the fact that the bike will move when it is set to walking mode. This confirms the motor and the hall sensors are ok in my experience.
I have pulled the motor apart and observed the following:
- Sensor wires all connected, no broken wires or loose connections
- No error codes
- Magnetic speed sensor on the wheel is fine and shows a seemingly accurate speed
- All functions on display seem to work
- Battery shows full charge both on display and on the battery's meter itself and voltage across terminals is correct
I feel like given that the walking mode works and the motor clearly engages, it has to do with the PAS sensor, but I know nothing about the PAS sensor in this motor and have struggled to find out much online so far.
Does anyone have any ideas about what could be the cause or how I might go about fixing it?
Thanks in advance
- No error codes
Thanks in advance
