Phaserunner Autotune invalid hall pattern detected.
P3yot3
Hi all,
OK, next problem for all you clever people out there. After setting the default parameters from Grin for a GMAC motor using a 52v battery then running the AutoTune feature in Phaserunner I'm getting the following error:
A bit worrying for a brand new setup - or is it? Should I be concerned? I've only run this & tested outside briefly but the motor seems pretty juddery with both throttle & PAS, but I've not touched anything in Cycle Analyst yet as I wanted to be sure that there were no problems with my sensors before attempting any fine tuning.
Is there a problem with either my GMAC or Phaserunner do you think?
Hi goatman,
Yes, shunt is set to 1ohm in CA3. I've been doing some more testing, both outside & on rollers & both the PAS & Throttle seem very erratic - speeding up briefly for no reason & I've only been able to stop it by using the ebrake to kill the motor. Changing the motor position sensor type from (1)hall start & sensorless run to (2) sensorless seems to have improved things slightly, but it still seems to have a mind of it's own on occasion.
I've not tried Autotune without CA3 connected yet, I'll try it & let you know the results. Thanks for the suggestion.
Regards.
OK, tried autotune without CA3 attached & got the same error message. Looks like I got a dud GMAC eh? I've emailed Grin, I know they're off the scale busy, but hopefully I'll hear something from them in a day or two.
What a bummer.
could be a bad phaserunner
https://endless-sphere.com/forums/viewtopic.php?f=2&t=111402&p=1650703&hilit=phaserunner+email#p1651516
i have one that wont turn off, and the transition from sensorless to sensored its rough, somethings going on with them or maybe the L10 connector????
Titan rw
https://endless-sphere.com/forums/viewtopic.php?f=49&t=112069#p1659508
