One motor refuses to run
apprisco
Hi all!
I recently repaired by dual motor drive ebike fully, where both motors now spin and do whatever they should.
However, I'm noticing a weird issue.
The rear throttle is intermittent(shouldn't be as this is a new throttle).
As in intermittent, what I mean is that the throttle refuses to accelerate the motor mid-spin, and only will accelerate if the motor has stopped spinning.
The rear motor is reversed, where the blue and green motor wires are swapped, along with the blue and green hall sensor wires.
Is this due to the reversed motor?
