5-wire motor to 6-wire controller?
kmxtornado
Bay Area
Hi, hoping you guys can help me out. I’m sure this is an easy one for some of you but I may be stumped if my assumptions are incorrect.
My motor (hall?) has 5-wires on the connector but my new controller has 6-wires. Are they compatible? Do I just skip the missing white wire? From searching through and reading some of the past posts here on the forum, it appears the white wire is simply a speed or temperature sensor wire of some sort and can be omitted. Correct?
Wiring of the connector looks likes this.
Perfect! Thanks!
