Your Whours for kms
Re: Your Whours for kms
I rarely ride over 20mph continiously. Usually around 15mph continious with some occasional sprints on 25mph. If the road is flat without headwind and good i might cruise at 20-22mph.
Cruiser: 9-10wh per kilometre
Velomobile: 10-12wh per kilometre.
Usual figures. Sometimes i let it rip a bit if i can burn electrons without range anxiety.
Cruiser consumes really lot if i keep 25mph constantly. Something like 3Ah per 10km.
Member of a 10 000 mile club
http://helsinkiheroes.com/
New to ebikes, and I could use some help figuring out usage.
Is it possible to figure watt hours from start and end voltage?
On my 19.7 mile commute to work, the starting voltage of my 12S 6.6A pack was 49.2V. Arrived at work and the pack measured 45.4V. The controller is set to 20A. Is that enough info to make a calculation, or do I need a watt meter?
MTB & Beach Cruiser BBS02 https://endless-sphere.com/forums/viewt ... =6&t=71695
Over all my 2016 Volt will go 4 miles per kWh.
Take it easy... but take it. (Woody Guthrie)
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
BBSHD on a 14S9P Lithium cobalt made of old laptop 18650 that heat up like hell.
Bike : 700C wheels, 46T chainring, 14T rear gear, tyres to 70 PSI, bike weight (with motor kit and battery) 67 lbs, me 155 lbs
Did 17 km with 524 Whr averaging 28 km/h (lot of wind in my face because riding on the border of saint-laurent river)
So that's 31 Whs/km on a BBSHD
He missed that your more than half the power to get to 20 was coming from your legs and thought you were going light on the throttle during acceleration.SamTexas wrote:I don't know what to say. I have no idea how you came up with those wild theories. Imagination working overtime?
My long term average riding in a fun manner at vehicular speeds to match or slightly exceed traffic has been just over 40wh/km. 5 years ago or more I ran significantly higher consumption due to a much higher % of hard launches. Though the novelty of an amusement park ride for pennies a ride and no lines hasn't worn off, I've mellowed somewhat and take it easy much of the time. Just don't pull up next to me or worse, in front of me, with some smoke and noise belting beast, as you will be taught a lesson about how much better electrics are.
My trike averages 9-15 w/km, 20-40 kph, this is with a lot of peddling for my health but with pas. One of my rides is 70km on a paved bike trail twists and turns and small hills. 1. mostly pas used 500 watts for the 70km. 2. used pas but would throttle up hills and did not worry about saving watts used 1000 watts for the 70km.
- DogDipstick 10 kW
How about highest instantaneous ( at any moment) Wh/mi you have seen? I have seen over 800Wh/ mile.
Average about 50 Wh/mi. 85 lb bike 175 lb rider.
83.1v of Ironhorse XC..
by Chevy
Broke 10 horsies
(..about 85% healed..)..
Waddyamean? You cant tell me how many amperes/Ft.^2 of the plate ?!?!? WTF.
(gottenymoem4115thangs?Yall?)
Fabricator @ BSECo. Inc.
I will take my trike out and run it under power only to see the worst it can be. I only go 28mph/45kph tops so will not be that bad.
It will be good info for me anyway, how far can I go without a chain.
With my setup in grinn's motor's simulator 216 w/km and my motor would over heat just over a minute on a 20% grade.
flat ground it says 16.5w/km @ 51.7 kph but my trike will go 53 kph. so I will test it some time. Now if I could find a head wind
I get about 30wh/km @50km/h or 31mile/h
Running at 50km/h or 31mile/h, it uses about 1500-1600 watts. 72v 26.1AH battery, Sabvoton 72100, and some qs205 copy motor. Bikes ~130 pounds and I'm about 135.
Highracer recumbent with 26" wheels with a mxus xf07 geared hub, kt36 15a controller used to consume between 5-10wh/km measured out of wall. Heavily dependent from pedaling intensity due to low legal e-assist speed.
Everyday riding consumption: 2 Whr/km
Touring consumption: 5 Whr/km
The above touring consumption gets me on average 180 miles with 5000 feet of climbing per day, averaging between 30 and 38 mph. This is pedaling a Katanga WAW with a 36 volt Bafang BBS01b mid drive assist.
