http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1643
Here you are - specification:
At 1.5C discharge rate the sag at each cell will be around 600 mV within specification.
Are they able to work great at such rate ?
Is it the right choice for e-bikes supply ?
Is the cycles number competitive for that price ?
Is the voltage sag within fair range ?
Are you ready accept such voltage sag for your e-bike supply ?
Product Specifications
Capacity* Nominal 2200 mAh, Minimum 2150 mAh
Dimensions:
Diameter 18+/- 0.2 mm
Height 68+/- 0.2mm
Weight (Typical) Approx. 46 g yes
Nominal Voltage: Average 3.7V
Cut-off Voltage: 3.0V
Internal Impedance: less or equal to 180 milliohm (with PTC)
Cycle Performance: 90% of initial capacity at 400 cycles
Cycle life: > 500 cycles
Charge: Current = 0.5C mA Voltage = 4.2 V End Current = 0.01 mA
Discharge: Current = 0.5C mA End Voltage = 3.0V
Max. Charging current: 1.5C ma
Max. Discharging current 1.5C ma (for continuous discharge)
