Your System's Power Density
Your system's power density
  • 1 - 4 W/Kg
    Votes: 1 100.0%
  • 5 - 8 W/Kg
    Votes: 0 0.0%
  • 9 - 12 W/Kg
    Votes: 0 0.0%
  • 13 - 16 W/Kg
    Votes: 0 0.0%
  • 17 - 20 W/Kg
    Votes: 0 0.0%
  • 21 - 24 W/Kg
    Votes: 0 0.0%
  • 25 - 28 W/Kg
    Votes: 0 0.0%
  • 29 - 32 W/Kg
    Votes: 0 0.0%
  • 33 - 36 W/Kg
    Votes: 0 0.0%
  • > 36 W/Kg
    Votes: 0 0.0%
  • Total voters
    1
xyster
Visualize Rural Sheep
What's your favorite e-ride's power density expressed as Watts/Kg, including peak motor efficiency and total rider + bike weight? (including batteries, motor, etc)
If unsure of peak efficiency, use 90% for brushless systems, and 80% for brushed.
Results should create a distribution curve we can later compare to acceleration times, or hill climbing grade @ speed results.
For example, my x5:
80 volts X 35 amps = 2,800 watts.
2,800 watts X 90% peak efficiency = 2,520 watts
2,520 watts of Power to the pavement.
Bike weight = 45kg. My weight = 77kg. Total weight = 122 kg
System Power Density = 2,520 watts / 122 kg = 20.6 Watts/Kg
My Currie:
24V x 35A @80% eff. = 672W
bike:34kg + me:72kg = 106kg
6.3W/kg
:lol:
6.3 W/kg!!!
Cheese Whiz man, you're almost better off just pedaling a lighter, normal bike! Time to overvolt that lazy Currie! :D :wink:
http://www.northeastcycling.com/neclimbs_hillcalc.htm
xyster said:
6.3 W/kg!!!
Could be...
but the density rating doesn't account for how many batteries I have... I can go slow for a good while with 48AH. A high-eff outrunner will be even better.
8)
According to the formula, 16.94 which I rounded to 17 and submitted. Guess to bikes weight makes rounding fair.
Have NO CLUE as to what this means. My 5304 on a 26" wheel with 2.0 slicks to 70 lbs, with 4 12V 12 AH SLA batteries pulls my 220 pound body to 32 mph with no wind and a comfortable 12 - 13 miles at 20 - 22 mph but the watts up is telling me to slow down by then if I want to get home. I've never pushed the batteries to dead so can only assume I could get 20 miles if I actually slowed it down.
Mike
Bicycle: 39kg (all-up-weight) + Me: 73kg = Total: 112kg
Peak power: 47V@20A@90% eff. = 846W
Peak watts per kg = 7.55W/kg
Overall the bike's acceleration is a bit slow, but the peak speed is a nice 28mph and I can ride well over 20 miles between charging (with pedaling, but I always pedal). I've never drained the pack, but based on estimated capacity left and the drain rate, I bet I could ride around 30 miles before I'd drain the pack.
38kg trike, 78kg me, =116kg.
84v X 30A = 2520 @ 90%=2268 / 116 = 19.55 w/kg:)
Lets see;
(36V X 20A) X 90% = 648W
34 Kg (bike) + 64 Kg (me) = 98 Kg total
648W / 98Kg = 6.61 W/Kg
