Intentional short
Get the forum community involved in polls and surveys.
Should I intentionally dead short a 5s 8ah lipo battery just to see what happens
Poll ended at Feb 05 2015 5:49pm
1 yes and video it
12
100%
2 no its too dangerous
0
No votes
3 you are an idiot who shouldn't be around lipo
0
No votes
Total votes: 12
100volts+   10 kW
Intentional short
Post by 100volts+ » Feb 02 2015 5:49pm
I want to intentionally dead short a leaky 5s 8ah battery.
puffed and leaking.jpg (91.19 KiB) Viewed 2418 times
Here is the video I made a couple of days after the post.
http://endless-sphere.com/forums/viewto ... =1&t=57440
Unlike puppets we have the possibility of stopping in our movements,
looking up and perceiving the machinery by which we have been moved. In this
act lies the first steps towards freedom. - PETER BERGER Sociologist
dnmun   100 GW
Re: Intentional short
Post by dnmun » Feb 02 2015 6:30pm
you can use the remaining good pouches as spares on another battery pack.
Ohbse   10 kW
Post by Ohbse » Feb 02 2015 6:53pm
I seriously doubt there are any good cells in that pack. I certainly wouldn't roll the dice on reuse.
Shorting it out though, that's worth doing.
100volts+   10 kW
Post by 100volts+ » Feb 02 2015 7:18pm
It measures over 15.5v so it should do something. and that is after 3 years in an ammo can. I have to prop the phone cam on something though because my wife won't have anything to do with shorting it. My dad says she shows more maturity than me. (that's sad because I'm fixing to retire)
TheBeastie   1 MW
Post by TheBeastie » Feb 03 2015 1:35am
This about you having a learning experience so you can deal with safety better in the future.
I say you should charge it up to the max first... This seems to be important to get a more realistic picture of how bad it can get.
If you really want a show, over charge by around %10 should be a good test.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
amberwolf   100 GW
Post by amberwolf » Feb 03 2015 2:30am
Do you have an ammocan?
If so, and you do this "test", please see my ammocan / RC LiPo pack build/testing thread about how I modified the can (it's really simple) and try the test in the ammocan, to see if a full-bore burning pack will be stopped by the can from exhausting flame out of teh can itself. (to see if it's able to contain the fire completely)
It'd not only be fun to see tried, it'd also serve a more-or-less scientific purpose. :wink:
dnmun   100 GW
Post by dnmun » Feb 03 2015 3:09am
if you intend to just throw away the good pouches why not just put it on the bulk charger and overcharge it and measure the temperature of the pack when it finally goes to thermal runaway.
you can use a thermocouple inserted into the pack and run your leads out to the meter so you can tell how hot it is getting as you overcharge it and then we can have some useful info about what temperature of thermal breaker to use for an alarm on the pack charging.
