SURVEY: MXUS 3K setups
Get the forum community involved in polls and surveys.
korpin   10 kW
Re: SURVEY: MXUS 3K setups
Post by korpin » Jul 27 2015 11:42am
my build is going to be:
5T
110 VOLTS
45 MAX AMPS
80 PHASE AMPS
REVOLUTION FRAME WITH MXUS LACED TO 19" MOTOCYCLE RIM (25+" WITH TIRE)
COMBINED WEIGHT ABOUT 280 POUNDS
Grizzl-E   100 W
Post by Grizzl-E » Aug 25 2015 2:11pm
Build thread here: https://endless-sphere.com/forums/viewt ... 8#p1088272
6t
18s lipo right now
29-30" diameter fat tire
45kph max loaded speed with no field weakening
65kph with max field weakening
96a max phase current foc right now is not enough
Bike plus rider ~260lbs
Going to 20s 18650 and 200a max phase current foc shortly. I need my wheelies :)
Only brutal acceleration will do.
Doctorbass   100 GW
Post by Doctorbass » Aug 25 2015 2:52pm
Dual motor and dual Max-E
Motor wind: (3T)
Wheel size: (rim/wheel diameter)24" wheel
Voltage: 22s lipo
Battery current: 400 each controller
Not finished yet, to be tested in the next week
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
teslanv   100 MW
Post by teslanv » Sep 02 2015 7:44am
MXUS 3T in a 17" Moto rim with 21.5" O.D. tires.
Infineon 18FETx4110 controller
24S LiPo (98v max charge)
80A battery, 180A phase.
1/4-mile drag run:
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
madin88   100 MW
Post by madin88 » Sep 02 2015 12:25pm
setup one:
4T with 4mm² phase wires and custom drilled paired spoke holes, laced in 24" Alex DX32 rim with 2,5" hookworms
Max-E, set to 70A/120A in normal mode and 120/220A in boost
2kWh 22s11p 25R battery
setup two:
3T with 8mm² phase wires and custom axle, improved heat emission, laced into 17" moped rim with 2,5" Sava MC11
Max-E maxed out :)
2kWh 20s12p 25R battery
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
teslanv   100 MW
Post by teslanv » Sep 02 2015 9:30pm
Max-E maxed out :)
What kind of top speeds are you getting with that set-up?!?!
Bellevue, WA
USA
madin88   100 MW
Post by madin88 » Sep 03 2015 6:21am
teslanv wrote: What kind of top speeds are you getting with that set-up?!?!
honestly i have not tried it out. at the moment i'm away sick at home because i have broken my collar bone :(
I'll keep you posted
Doctorbass   100 GW
Post by Doctorbass » Sep 03 2015 8:20am
Ouch, I wish you you recover quickly !
Doc
markz   100 GW
Post by markz » Sep 03 2015 2:35pm
4T Version 2 with 18fet lyen, CA V3-DP, and a 26" 31mm Wide Downhill Crysatlyte Rim
12 and 10awg PTFE Teflon phase upgrade from http://www.apexjr.com/index.html
Might paint the inside with some sort of fancy dielectric or something else.
Will change to a 19" moto rim that gets me 24" diameter wheel.
At default 45A I was getting ~60kph, keeping up with traffic on 60km/h road.
Unibond: 6-1/4 in. LED Spot/Flood Light
A123 ANR26650M1A batteries
High discharge 18650 batteries
