Motor selection for hauling a toddler on a hybrid
Get the forum community involved in polls and surveys.
Which motor configuration would you choose?
Front geared hub
0
No votes
Front direct drive
0
No votes
Mid-drive (BBS02, etc.)
2
100%
Rear geared hub
0
No votes
Rear direct drive
0
No votes
Total votes: 2
skyblaster   1 µW
Post by skyblaster » Feb 23 2018 11:08pm
I'm contemplating an eBike build (first ever) of my Norco XFR3. My reason for this poll is that I have a Topeak Babyseat II mounted to the rear rack and am trying to select a motor for proper weight distribution and torque. I'm not exactly sure where I'm going to mount the battery, but likely somewhere in the triangle.
Our daughter now weighs 36 pounds, so I recently ditched the Alfine IGH bike and bought a hybrid. It only sees fairly flat trail use on weekends and I'd like to be able to do the whole loop (26km) within a better time frame.....I'm a bit slow with all the extra weight.
Raisedeyebrows   1 kW
Re: Motor selection for hauling a toddler on a hybrid
Post by Raisedeyebrows » Feb 24 2018 1:56am
Voted mid-drive because I have one of those on my cargo bike and have hauled my daughter around for a couple years now on it. A lot of steep hills and the way the motor works with the bikes gearing gives you a lot of torque when you need it and when the assist is set on 1 it's good for just cruising at a reasonable speed on flat ground.
Yuba Mundo w/BBSHD
Specialized Hard Rock w/9c clone, statoraid, hubsink
Trek Fuel 90 w/BBSHD
Above all run on 14s4p 52v li-ion
Ecobike folder 36v
Currie Flyer scooter 24v on 24ah of SLA
Every trip made with electric bike is one less car trip, saves money, no toxic fumes, less noise, less impact on roads.
