When Windows 7 is dead in 2020 what OS will you migrate to??
Get the forum community involved in polls and surveys.
Windows 8/10/?
27
37%
ReactOS
0
No votes
Chrome
4
5%
Mac
5
7%
Unix
1
1%
Linux
28
38%
BeOS
0
No votes
Amix
0
No votes
FreeDos
2
3%
Other
6
8%
Total votes: 73
TheBeastie   1 MW
Re: When Windows 7 is dead in 2020 what OS will you migrate to??
Post by TheBeastie » Jan 27 2020 9:26am
--Oz-- wrote:
Jan 26 2020 11:23pm
Same, does not see it in file explorer. I also looked into the bios, the sata port is set to ahci by default, so I tried IDE ENHANCED mode, now the ssd boot drive was not recognized, switched back to ahci, it booted, but not 2TB. Any suggestions?
Don't have many suggestions, changing it from AHCI to IDE or back is what I would have suggested...
I have had a similar problem (from memory, I think) where I formatted it a drive with the bios SATA set to one of either AHCI/RAID/IDE and the drive was totally unreadable if I changed the bios over to one of the other SATA modes.
Maybe on the previous PC the bios was set to RAID? Maybe you dont even need a raid setup for it to be unreadable in Windows again.
I would say if you could plug the drive into a USB to SATA converter and if you can view the drive in windows that way, then copy its contents to another spare drive and then format the original drive in the new PC under AHCI.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
--Oz--   1 W
1 W
Post by --Oz-- » Jan 27 2020 3:01pm
OK, sounds good, I will toss it back in the gigbyte i7 system where is has lived for 8 years happy, check it there first, then if still not working try my usb-sata adapter.
The PlexHD MB only has 2 usb3 ports on the back (there is a MB connector for 2 more for front panel), I bought the cable for $3, not here yet. I also bought this pci-e 7 port usb3 card for $16, you see any issues with a cheap card like this?
https://www.aliexpress.com/item/3269498 ... 4c4dzQu7k5
I am looking for a pci-e sata3 raid card, 4~6 internal ports and 2 or more external (back panel) ports, suggestions (looking on ALI now)?
TheBeastie   1 MW
Post by TheBeastie » Jan 27 2020 7:22pm
--Oz-- wrote:
Jan 27 2020 3:01pm
Nar no suggestions on the hardware, but with "405 Reviews / 863 orders" looks like it should be good.
While that item looks like a solid choice, I would avoid ordering these comparatively easily obtainable items on Aliexpress and try and obtain them locally for the sake of fast delivery and warranty convenience, is all I have to add.
--Oz--   1 W
1 W
Post by --Oz-- » Jan 27 2020 10:30pm
I found my notes on my Asus P6x58-e-pro with i7-980x/24gb/gtx480, trying win10 (v1709 two years ago) it randomly bsod (nothing like the bsod on i7-920 every hour). The i7-980x bsod gave "whea.unrecoverable.error". When I have time I will try the latest version of windows. I am going to need a psu as i robbed it for the new xeon.
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Jan 28 2020 12:30pm
you look it!
iz that pix of you@the very moment you creamed your shortz? ?
Last edited by Toorbough ULL-Zeveigh on Jan 28 2020 5:02pm, edited 1 time in total.
--Oz--   1 W
1 W
Post by --Oz-- » Jan 28 2020 3:44pm
Banned spammer Alextort wrote: I switched to MacOS from Win7 two month ago and never been happier! ;)
Got a link to what you bought and how much you paid? tia
What apps do you run?
--Oz--   1 W
1 W
Post by --Oz-- » Feb 02 2020 2:02am
About 5 years ago there was a coworker praising his shinny mac-n-crack, i finally said i could built the same system for half the cost, he didn't believe it, we bet $20, I looked up the specs on his $2200 system, it was a i7, 16bg, and two video cards, the brand new shinny mac was using two 4 year old videos cards, lol, I pieced together a better system for $600, i took his $20, he could not believe it. After being burned for the cost of the mac, he said he only used the installed programs, i told him, he could of got by with a $300 pc.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 02 2020 3:10am
Is there any special version on the x5675 cpu I should buy or any $20 version will do?
My stock i7-920 shows 4900 on passmark, thats at the stock 2.66ghz, a decade ago (lol) I had it up to 3.9ghz w/o adding voltage, but the games back then did not need it, so I been running it stock, curious what it would get at 3.9ghz on passmark?
I was going to try a m.2 drive, 250 or 500gb, bast bang for buck, links?
Also looking at the x99 boards/combos, the x99-tf looks like the best one, paired with the 2689 v3, suggestions?
https://www.aliexpress.com/item/4000440 ... b201603_55
TheBeastie   1 MW
Post by TheBeastie » Feb 04 2020 3:28am
--Oz-- wrote:
Feb 02 2020 3:10am
Probably any x5675 will do, there is probably around a ~50% chance that the more you pay for your X5675 the nicer the CPU chip will look aesthetically, and probably around ~25% increase in chance it will work better.
But I am just guessing, but that's how my probabilities would imagine it.
Don't know or really have an opinion on the other stuff. Cheers
John in CR   100 GW
Post by John in CR » Feb 11 2020 1:50pm
So is it finally time to go Linux when I finally give up my XP machine, even if I'm just an old guy not up on the latest and greatest geeky stuff. I'm definitely going SSDs, because 37yrs of waiting for computers to boot up is enough of paying my dues.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 12 2020 11:28am
I am loving the xeon e5-2689/32gb/rx580 system I just put together on win10, it has a 480gb SSD, but I think for $68 I am going to try the M.2 512gb ssd
https://www.aliexpress.com/item/4000116 ... 5ekfT&mp=1
After reading tomshardware, the speed and price of this drive is hard to beat. I am 50+ now, been repairing PC's to component level since the IBM-XT came out :shock: Win10 is basically free (~$5 keys on ebay, or just dont activate it)
I am still itching to try the 2689-v3 (passmark ~18,000, 12core/24thread) and the x99-FT motherboard combo, i can easily sell the current setup to a friend.
https://www.aliexpress.com/item/4000440 ... b201603_53
TheBeastie   1 MW
Post by TheBeastie » Feb 13 2020 1:18am
--Oz-- wrote:
Feb 12 2020 11:28am
I like the speed test comparison of that chart of that Aliexpress listing has put up, it shows the mechanical-harddrive vs the m2-ssd with the real-world performance showing 1.233MB/sec vs 437.3MB/sec on non-sequential reads of the HDD mechanical drive.
https://ae01.alicdn.com/kf/HTB1ORFzVhTp ... 2wXXaE.jpg
That 1.233MB/sec vs 437.3MB/sec shows the SSD drive performance 354 x times faster than a standard mechanical hard drive for real-world performance scenarios.
Some people just don't understand that looking at a sequential read speed of a mechanical HD is pointless and misleading, because the only time it mattered was the very first boot of a fresh installation of MS Windows... It only takes one single OS update where the updated DLLs/OS files were larger than the previous files hence causing those files to be allocated somewhere else on the hard drive causing fragmentation, hence 1.233MB/sec read speeds since it's now down to random read performance instead of sequential, only vinal record players have perfect sequential reads.
For the last 10 years now so many tech sites/articles have claimed that moving from mechanical storage to SSD increases your average read data speeds by as much as 10,000 times and by 100s of times at a minimum.
It's hard for the human mind to conceptualize this, so imagine earing 500x times more money than you do now, or living 500 times longer than you will, that's like living for 5000 years.
Mechanical hard drives were the main perpetrator of a perfect wicked and evil business model for Microsoft/Intel/PC builders because it only took a month before most folks on their mechanical hard drive PCs would say: "boy this thing is slow, I need to buy a whole new PC again.."
There are still folks out there using mechanical hard drives for OS/Software usage instead of merely just for video/archival purposes, it's a tragic story of the first world, all the invisible suffering, just as bad as sugar/junk food. There really should be a "World SSD and no more mechanical hard drive day", let's end the suffering!
While that Aliexpress SSD drive looks fine, I don't think saving $10 etc is worth it compared to just buying locally, because you get incredibly convenient warranty buying locally. You only want to use Aliexpress on standout bargains like 8core CPUs and 32GB ram etc at a fraction of the price locally, that's a no brainer, but not really worth it for other stuff.
I have long been an MSY fan, they not so insanely cheap any more but they have an instant and very convenient all in one price PDF has been a long favourite of mine to check, its been the same format for 15years!
http://cdn.msy.com.au/Parts/PARTS.pdf
With that 12core CPU deal, I been thinking the future might be looking good for old server hardware repurposed for desktop usage, because the trend for AMD/Intel lately has been to release these super mega core CPUs that still run at rather lowish clock speeds, check out the new AMD Threadripper 3990X, it has 64 CPU cores running at base 2.9Ghz and turbo of 4.3Ghz
https://www.anandtech.com/show/15483/am ... 90x-review
CPUs like this should help push game developers to concentrate of making games that make use of ALL the CPU cores instead of being lazy coders and trying to rely on just ~3 CPU cores with a high IPC that are running at a higher Mhz, coding for high IPC instead of utilizing many CPU cores is code mindset of 15years ago.
This is what makes programs like Cinebench so great, because it shows you how much computing performance you can get out of a 6+ core CPU if its coded to take advantage of more threads/cores.
If game developers code games like how Cinebench runs, then CPUs from 10 years ago with 6+ cores will work great in future games with combined with a modern graphics card. Even the PCIe 2.0 bus is yet to be saturated, so PCIe v3 video cards in old motherboards do perform the same https://www.hardwaresecrets.com/pci-exp ... ce-gain/4/
TheBeastie   1 MW
Post by TheBeastie » Feb 13 2020 8:38pm
--Oz-- wrote:
Feb 12 2020 11:28am
I was just watching the YouTube video from "tech yes city" and he has a new review of an old Xeon and talks about how he is going to release some videos about how to unlock the multiplier for his "6 Core E5-2620 V3" with an X99 motherboard, but interestingly this setup requires DDR4 ram, which is a value downside.
Apparently there is an exploit where you take out a CPU microcode-update, once the CPU micro-code is removed it allows you to install a driver where you can set your OWN CPU max multiplier, allowing for overclocking. Only on very specific CPUs and via a specific setup. Hopefully, folks find more types of microcode CPU multiplier hacks.
https://www.youtube.com/watch?v=6Ox0cirdP3k
This site has a great "price history" chart where you can see this CPU has been about $400 for the last 6 years, so no point/value, but now in the last few months the arse has completely fallen out of it in price. I guess massive datacenter upgrades and turfing these out and they are hitting the reseller market making them better value.
https://www.cpubenchmark.net/cpu.php?cp ... Hz&id=2418
--Oz--   1 W
1 W
Post by --Oz-- » Feb 14 2020 1:37pm
I went back and forth on buying off newegg/tiger-direct, but to get similar speeds, the 512 drive was way more than $10, but I may have missed the deal your talking about?
The high end samsung drives have great spec's but are pricey.
CONSIDERABLE SHOUTING   10 W
Post by CONSIDERABLE SHOUTING » Feb 15 2020 1:02pm
TheBeastie wrote:
Feb 13 2020 1:18am
It's could be due to RISC-V architecture; Linus Tech Tips has a great video on the implications that it could be a (finally!) replacement for X86. I never knew that X86 basically plays musical chairs with processors instead of assigning specific tasks to each one. The other reason is just due to efficiency and power consumption.
We've begun to see cheap motherboards out of China that use Server processors and memory for simple machines- Word is, lots of Russians are making their gaming PCs that way using cheap DDR3 to get 1080p systems with minimal cost, thanks to the Rubel doing so poorly.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 15 2020 6:36pm
The bang for buck is awesome on that 6 Core E5-2620 V3 $20 cpu (passmark 10,000), the $52 cpu e5-2689 does 13,500 on passmark, not bad for $30 more and using low cost ecc server memory, but I did see on newegg yesterday shellshocker, ddr4 3200 16gb (2x8gb) for low $60's, so that helps a lot.
Post by CONSIDERABLE SHOUTING » Feb 15 2020 7:30pm
--Oz-- wrote:
Feb 15 2020 6:36pm
Have you seen the Optiplex builds, by chance? You can now make a 1080p 60FPS Gaming PC for about $300 from used office parts, if you're lucky.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 15 2020 8:15pm
Yes on Linus Tech tips, they had some trouble but finally got it working. BTW, I hate Dell and their crappy proprietary junk (case/motherboard/psu/etc), actually all the, compaq/gateway/etc proprietary stuff, lol.
Post by CONSIDERABLE SHOUTING » Feb 16 2020 11:58am
The 3010, 7010 and 9010 actually aren't- it's the 9020 ect. that use proprietary power connectors on the MoBos.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 16 2020 2:42pm
CONSIDERABLE SHOUTING wrote:
Feb 16 2020 11:58am
I dont know the model numbers, but at work they toss pc's right and left, mostly dell's, from my experience, the psu/motherboard/case are all proprietary junk, why, proprietary = profit.
For example, if a dell psu dies, you cant pull a standard atx psu and install it, it wont fit (most times its too big, or their MB, they dont fit in any normal case/quite a few of them are low profile, so normal pci/e cards wont fit/etc
Post by CONSIDERABLE SHOUTING » Feb 16 2020 3:52pm
No question; those -10 series have really just hit the aftermarket so heavily BECAUSE they can be so easily modded by cheap newbies looking for the "5.3LS of computers". Cheap i7 that's easily OC-ed? Yes please!
Anyway, I'm looking to either use one of those OR this little free workstation PC as a learner for Linux OS'es soon. I'm thinking of starting with either Mint or Unbutu; any advice?
--Oz--   1 W
1 W
Post by --Oz-- » Feb 16 2020 11:52pm
Feb 16 2020 3:52pm
How do you OC a dell i7 or anything Dell for that matter, the bios is still so pathetic, just curious?
I am not a linux guy (I did try ultimate edition and semi liked it, but not really enough time on it to be efficient). There has been some recommendations in this thread, i think it has to do with what your goals are going to be, hopefully a linux guy will chime in.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 17 2020 1:15am
--Oz-- wrote:
Jan 27 2020 10:30pm
UPDATE: Took a new 480gb ssd, loaded the latest 1909 win10, a couple reboots and all drivers are loaded, and the same "whea.unrecoverable.error" bsod started happening.
I swapped the video card, loaded driver, and same,
swapped different ram, and then even down to just one stick,
even lowered the 1600 speed to 1333 and then 1033,
I started disabling onboard functions that I am not using (1394, serial port, etc),
then I disabled hyperthreading,
turning off any auto settings in bios,
Running stock freq settings, no OC.
Cpu is cold at under 50C, has huge heatsink/fan on it.
All the same bsod every 20 minutes or less.
Looking at win10 site, they say"
1. MBR or system file error. It boots fine every time, not sure what to do on this one?
2. BCD error.
3. Driver issue of hardware. I am using all win10 loaded drivers, so maybe this is the problem. Soon i will load all the drivers from Asus for my MB.
Suggestions?
UPDATE: there is only one driver in the Asus Win10 support page, its for the realtek audio, loaded it, rebooted and with in 2 minutes bsod, help, lol.
Post by CONSIDERABLE SHOUTING » Feb 17 2020 8:15am
--Oz-- wrote:
Feb 16 2020 11:52pm
Feb 16 2020 3:52pm
It depends on what MoBo you get, but tons of them weren't Dell-specific; some were subcontracted to Asus, Gigabyte, ect. so some you can reflash other BIOS to them to gain more control, provided you have the product code. I think Asus did have their own version, but don't quote me.
--Oz--   1 W
1 W
Post by --Oz-- » Feb 17 2020 6:09pm
On a side note, I bought a used Lenovo Yoga 15" (250ssd/16gb) for $100, mainly for satellite tracking with my scopes (lx200gps-14" and rcx400-12"). Here is the kicker, its a i7 that is a dual core (4 threads), wth, lol. It is a battery miser so that makes sense.
