Looking for help with my project! $$$
A subforum for posting jobs, work offers, etc... whether they be a one-time gigs, full employment, or something in between.
stevetedesco   1 µW
help with set up
Post by stevetedesco » Mar 02 2021 3:26am
Trying to run two 48v 800w hub motors on a four wheel scooter using twist throttle and separate controllers. What size battery would I need to get good run time? Need help with wire diagram too!!!
thank you
steve
stevetedesco   1 µW
Post by stevetedesco » Mar 02 2021 6:59am
Like to find someone that can help me with a project. $$$
Its a four wheel scooter.
Have 2- 800 watt 48v hub motors.
Have 2- controllers sold with motors.
Have twist throttle.
Need help picking either an e battery in case or build cell pack.
10-20 mph ok
Should I have bought lower watt motor?
thx
Steve
markz   100 GW
Re: help with set up
Post by markz » Mar 02 2021 8:22pm
You should have gotten a wire diagram with the controllers you purchased.
Size of battery in terms of voltage, amp-hour and amps depends on your controllers voltage rating and be sure your battery amps are less then the controllers amps, and ah is just how far you can ride. Power is voltage x amps = watts, so if you have to little watts you wont have lots of power to get up a hill. 36Vx10A = 360W which is quite wimpy but 36V x 40A = 1440W which is lots of power to get up hills. 36V is slower speed compared to 48V.
stevetedesco wrote:
Mar 02 2021 3:26am
thank you
steve
stevetedesco   1 µW
Re: Looking for help with my project! $$$
Post by stevetedesco » Mar 14 2021 4:56pm
Markz
Thank you for your response. Unfortunetly like reading chinese to me!
Way over my head. I asked for a diagram but got photos of wire mess!
What should I look for on controller?
If I start with the two hub wheels I can buy controllers here in US maybe.
What size battery should I be looking for?
Do you know good places to buy?
Is there something off wheels that would help you tell me where to start?
Thanks
Steve
thepronghorn   1 kW
Post by thepronghorn » Mar 18 2021 5:01pm
What does "good run time" mean to you? 1hr, 2hrs, 8hrs? Where will you be running it (on/off road, mud, hills, snow, etc.)? Also how much load (single person? multiple people? how much does the scooter weigh)?
For the wiring, there are probably others who can help better than me, but you could start by uploading the "photos of wire mess" that you received to see if we can help interpret them. Also links to what you have would also be helpful. The more details you provide, the better help people can provide.
