Welding down a torque arm
A place to discuss the repair, design, and customization of the bicycle itself, not the powertrain ( battery, controller, motor, etc ).
amberwolf   100 GW
Re: Welding down a torque arm
Post by amberwolf » May 04 2021 12:22am
FWIW, with a clamping torque arm (that is thoroughly attached to the frame), you wouldn't need axle nuts/washers (except whatever is used to mate the axle shoulders to the frame).
RTLSHIP   1 kW
Post by RTLSHIP » May 04 2021 6:20am
I think the culprit here is likely the regen. I may not need to weld anything. I want to do everything else I
mentioned (fix axle, wiring etc) and either use the small 18 amp controller or disconnect the regen on the Aotema stock. The small controller works great and doesn't have regen but is only good for 48v and is low amp rating. Here are a few more pics. How difficult is disconnecting regen on Aotema?
cat included
steel fork dropouts.JPG (1.95 MiB) Viewed 155 times
Campsolutions contrl vs modified stock controller
small vs stock controller.JPG (2.04 MiB) Viewed 155 times
about 10 mm width, 5mm prongs
5 mm steel..JPG (1.93 MiB) Viewed 155 times
two Aotema Brushless & Sensorless Kits
1 Free Spirit 12 Speed
RTLSHIP   1 kW
Post by RTLSHIP » May 04 2021 7:38am
amberwolf wrote:
May 04 2021 12:22am
What's your view on the regen controller? As John CR and Grin Tech suggest : the axle goes to an fro and is fighting against the dropouts. Without regen, the axle will only go one way. So to have regen on a front wheel drive, you need a nearly perfect set up. Regen makes practically no sense anyways as it makes tiny trickle charges.
John in CR   100 GW
Post by John in CR » May 04 2021 3:19pm
RTLSHIP wrote:
May 04 2021 7:38am
I can't believe someone is still posting these kinds of anti-regen falsehoods in 2021.
-Regen adds range, it's like getting 5% or more of free battery.
-Reduces maintenance time and cost (I haven't changed a brake pad or fiddled with brake adjustment in years, and I'd use regen if it had no other benefits.
-Increases safety by giving you anti-lock braking, and keeps mechanical brakes fresh and cool for emergency stops and for much safer descents.
I can't believe you're talking about welding on the motor axle when the dropouts those forks could so easily be adapted to become clamping dropouts
RTLSHIP   1 kW
Post by RTLSHIP » May 04 2021 5:26pm
John in CR wrote:
May 04 2021 3:19pm
RTLSHIP wrote:
May 04 2021 7:38am
I have read that it can give 1.5 miles on 30 miles of riding. That ain't much when you consider that most people don't need to ride
that far. Further I have read that regen is not so good with lithium as it can heat up battery. Further, I'm repeating what you and grin tech have publish in refrence to spinouts with repect to regen. So maybe I used histrionics calling it tiny trickle charges.
Finally, what I'm talking about now is using a controller without regen as opposed to welding. You are the guy that believed
somebody back in 2011? But you can't believe I believe something?
RTLSHIP   1 kW
Post by RTLSHIP » May 04 2021 5:28pm
RTLSHIP wrote:
May 04 2021 5:26pm
John in CR wrote:
May 04 2021 3:19pm
RTLSHIP wrote:
May 04 2021 7:38am
somebody back in 2012? But you can't believe I believe something? You apparently believe I'm living in 2010 because my kit is such?
E-HP   10 MW
Post by E-HP » May 04 2021 8:46pm
Chalo   100 GW
Post by Chalo » May 05 2021 12:58am
RTLSHIP wrote:
May 04 2021 6:20am
Dude. Those forks are janky AF. Would you use them as a wrench? No you would not. That makes them unsuitable for restraining axle torque.
In the USA, squashed-tube fork tips like that are common only on department store bikes from the 20th century. Is that what you're using?
RTLSHIP   1 kW
Post by RTLSHIP » May 05 2021 4:18am
Chalo wrote:
May 05 2021 12:58am
RTLSHIP wrote:
May 04 2021 6:20am
The forks are strong. They are Chromoly. The tips are solid 5 mm or 1/4" as you can see. No squashed tips. Yes the main body of the fork is tubular but that's common to every bike I've had. I can't imagine what a solid tubeless steel fork would weigh.
I got this bike practically free and brand new though it is a 1991. And the same designed forks have held down the other hub for several years without incident. I think this will work out fine if I go w/ nonregen controller and tie it down properly. I will not weld.
RTLSHIP   1 kW
Post by RTLSHIP » May 05 2021 6:49am
In reality, buying a decent $1000. integrated bike will eliminate these problems. I attend to do this one day, but at this point I want to use the materials I have. I will eventually not fool with conversion kits.
LewTwo   100 kW
Post by LewTwo » May 05 2021 8:12am
Chalo wrote:
May 05 2021 12:58am
Well I am in 150% agreement with Chalo. Pressed steel forks are garbage ...
and that is coming from someone that runs front hub motors on aluminum forks.
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
Chalo   100 GW
Post by Chalo » May 05 2021 10:22am
RTLSHIP wrote:
May 05 2021 4:18am
Well, either they're smashed into shape from the tube ends (like an old Huffy), or they're styled to look as if they were. I have never seen a chromoly fork with that treatment, but in principle chromoly can do all the same things that mild steel does, process-wise.
This is a more usual style of fork tip on a quality chromoly fork:
I hope you can see how these are better shaped to resist torque from a flatted axle than the fork tips you have.
[/quote]
Chalo   100 GW
Post by Chalo » May 05 2021 10:28am
John in CR wrote:
May 04 2021 3:19pm
Using 5% or more additional battery is cheaper and easier for most folks than making and installing clamping dropouts. It's much less likely to end your ride, your bike, and/or your face than using regen braking without clamping dropouts.
RTLSHIP   1 kW
Post by RTLSHIP » May 05 2021 11:21am
Chalo wrote:
May 05 2021 10:22am
RTLSHIP wrote:
May 05 2021 4:18am
[/quote] these forks were not crimped together if that's what you suggest. I did alter the appearance by filing to fit. Having read up on torque arms, I can now understand that I'm not the only incompetent one with this issue. Some have claimed that anything above 500 watts generates some smearing etc. Definitely as a 5 to 7 mile commuter, I don't need regen related torque.
Sooner or late I'll pony up and get an integrated rear wheel bike. It seems harder to let go or transition right now.
I do have forks similar in style (except for quick release dropouts) to your pic on a Mongoose Sycamore but that bike is for regular use only.
LewTwo   100 kW
Post by LewTwo » May 05 2021 12:32pm
Chalo wrote:
May 05 2021 10:22am
I downloaded the pictures and enlarged them a bit. They are not pressed steel forks but the appearance is deceiving. Still a weak design IMHO. I would not rum 'em with out torque arms. If a rear wheel drops out on a bike then you have a wreck. If the front wheel drops out on a bicycle then you go head over handlebars and your face meets the road (been there, done that and had the bloody T-shirt and scars to prove it).
E-HP   10 MW
Post by E-HP » May 05 2021 2:43pm
RTLSHIP wrote:
May 05 2021 6:49am
Are you talking about an ebike?
RTLSHIP   1 kW
Post by RTLSHIP » May 06 2021 5:26am
E-HP wrote:
May 05 2021 2:43pm
RTLSHIP wrote:
May 05 2021 6:49am
Yes, I want to get a rear wheel drive about 1000W. I'm assuming an integrated bike as an integrated torque system. I want something that will be compatible with my current battery packs such that battery packs can be alternated. Right now I just want to use what I have. I don't want to turn home into a bike barn, so I have to get rid of these kits/bikes if I'm going to replace them. That's the tougher part.
RTLSHIP   1 kW
Post by RTLSHIP » May 06 2021 5:28am
RTLSHIP wrote:
May 06 2021 5:26am
E-HP wrote:
May 05 2021 2:43pm
RTLSHIP wrote:
May 05 2021 6:49am
Yes, I want to get a rear wheel drive about 1000W. Decent could be more than $1000. I'm assuming an integrated bike has an integrated torque system. and want to go rear wheel. I want something that will be compatible with my current battery packs such that battery packs can be alternated. Right now I just want to use what I have. I don't want to turn home into a bike barn, so I have to get rid of these 2 kits/bikes if I'm going to replace them. That's the tougher part.
