Theodore Voltaire
1 GW
I'm running my lights on a 1 amp fuse. If you try to put a fuse on your battery I recommend 80 amp.
fluid2150 said:80 mmm ok. What's the most the bombers pull in amps?
fluid2150 said:Just working on my new b52. Putting lights in and noticed they use giant Anderson plugs,
15480449390560.jpg but what I just realised is that there is no inline fuse, or fuse at all? This normal? I'm going to install a 60 amp audio inline fuse so I can tap into the power for my head light and tail light.
Any thoughts?
That's is one big battery
Theodore Voltaire said:VBoxx lubing done, so I mounted the shock. The eyes were a perfect fit, exactly like stock. It looks like it changed the ride height about 1" lower, or maybe only 7/8" but I'll take it. I'm wondering if the Chinesers calculate their ft lbs the same rest of us, because this 1000 lb spring doesn't feel much different than the stock 750 lb spring. That's good news though because this spring feels right in the ballpark. Now it makes more sense they were advertising this shock for a 70cc pit bike which would probably weigh even more than Bomber.
tomjasz said:Depressing to see your lift. Sold custom Kendon with the Vespa 250. Never thining how advantageous it would be with a heavy ass eBike.
Cowardlyduck said:Looking good TV.
Question for everyone...what lube do you use on your rear shock bushings?
Mine have been getting squeaky recently and I just threw some PTFE spray on there, but have no idea if that's a good idea or not. In the past I've used WD40 and regular lubrication oil...again, no idea what's best.
Cheers
