PWD's Rocky Mountain Blizzard - mid drive
thundercamel   1 kW
Re: PWD's Rocky Mountain Blizzard - mid drive
Post by thundercamel » Nov 14 2019 5:23pm
I think I would sooner get one of these before I try the tedious task of installing my own studs: https://www.schwalbetires.com/bike_tires/studded
My Ebike builds - Existing bikes, affordable motor kits, self built 14s6p batteries - Now with more recumbent!
pwd   100 W
Post by pwd » Nov 15 2019 9:32am
E-HP wrote:
Nov 14 2019 4:43pm
Ever consider heated grips? I started looking at them after reading DrkAngel's Snow Beast thread. They don't look like they draw too much current. Folks I know with them on motorcycles say they're pretty effective.
I am definitely willing to give heated grips a try. After my bar mitts are tested in the cold; that will determine how much more heating/insulation I will need for my fingers. :kff: <-- Kanadian Frozen Fingers
thundercamel wrote:
Nov 14 2019 5:23pm
Pre-studded tires would certainly save a lot of work. However, when it comes to fat tires (4.5+ inches wide) the price for pre-studded tires seems to be around $200 USD minimum per tire for something with a half-decent tread pattern :shock: !
I'll be reporting pack when I get these items tested on the bike. One thing is for sure; it is sure nice to go for a ride during these dark winter evenings. I was out for a run last night over some snow and ice and had a blast. I'm hoping to get some photos up soon!
Commuter/Street Build:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
em3ev 14S5P 30Q + 14S6P 25R pack
Build Thread: viewtopic.php?f=6&t=98286
Offroad Build:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 44T chain ring then 36T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q
thundercamel   1 kW
Post by thundercamel » Nov 15 2019 11:50am
That's right, I forgot which thread we're on :)
pwd   100 W
Post by pwd » Dec 03 2019 10:08am
The bike had been working well and I was finally able to test it out in some proper snow. The bike is a lot of fun; I've also aired down the tires for more traction. It does exceptionally well on semi-packed to fully packed snow. Anything deeper than about 20 cm of snow and it becomes very difficult to maintain traction.
bike1
While out for a ride in the bush one day; I manged to shear off my derailleur :flame: :
carnage1
carnage2
The bike has been out of commission for the past couple of weeks but is back on the road with a new derailleur hanger and plenty shift re-adjustment. The derailleur cage was also bent enough to cause the chain to rub; it seems to be back into shape now. As you can see from the photos; it also ripped a chunk of the frame dropout with it which was a bit concerning but the new hanger managed to stay on thanks to the clamping force of the quick release axle skewer.
I've been back on the bike but taking it easy to make sure I don't end up in the same boat again. I'm still waiting for my tire studs and bar mitts from Aliexpress. The roads around here are covered in ice; so the tire studs will be installed asap when they arrive.
Offroad Build:
em3ev 14S5P 30Q
SaabGuy   10 mW
Post by SaabGuy » Dec 03 2019 1:57pm
i found similar limitations on my fat ebike. around 7in (your 20cm :lol:) it gets very squirrely (and fun). i stay away from snow covered sidewalks and iced over areas without studs.
What studs did you buy? i found a few small ones on aliexpress but never ordered.
pwd   100 W
Post by pwd » Dec 04 2019 9:32am
SaabGuy wrote:
Dec 03 2019 1:57pm
These are the studs I ordered:
https://www.aliexpress.com/item/3284557 ... 4c4djFa3kB
I'm hoping to try them out over the weekend if they arrive this week.
Offroad Build:
em3ev 14S5P 30Q
