Odogster   100 mW
Re: E-S Stealth Electric Bike Owners
Post by Odogster » Jan 13 2021 3:57pm
OK guys I’m hoping someone can clear something up for me here. I found a few places on the web that say they have utilized a Shinko 244 or 241 size 19” x 2.75” tire on the stock rim with the motor laced to it. I ordered one and have brought it to 2 places to install (couldn’t get it myself) and they have both said it’s too small. Am I missing something here? How do you get one of those tires on the stock rear rim? Does one need a different rim?
Odogster   100 mW
Post by Odogster » Jan 13 2021 4:42pm
Odogster wrote:
Jan 13 2021 3:52pm
FL bomber wrote:
Jan 12 2021 7:48pm
Odogster... Can you snap a photo of your bomber with the 72150. Like to see how it fits on the frame size wise. Are you still utilizing the cav3?
Thanks 👍
Sure will do. Unfortunately I can no longer utilize the cav3 the sabvotons aren’t compatible as far as I could find. However, the MQCON app that allows for all sorts of configuration options far outweigh the slight advantages the stock display has over the sabvoton ones. It’s incredible how customizable everything is using that Bluetooth app.
Allex   1 GW
1 GW
Post by Allex » Jan 13 2021 6:16pm
Theodore Voltaire wrote:
Jan 13 2021 10:49am
Does anyone have experience using this kind of controller on a Stealth?
https://www.kellycontrollers.eu/kls7230s
Sure, installing this one now
https://www.qsmotor.com/product/kelly-c ... -kls7218s/
Will connect it to the CA as well with this schematic:
viewtopic.php?t=84739
Sabvotons are way to bulky
Theodore Voltaire   10 MW
Post by Theodore Voltaire » Jan 13 2021 7:13pm
Allex wrote:
Jan 13 2021 6:16pm
Jan 13 2021 10:49am
Thanks a lot Allex
FL bomber   100 W
Post by FL bomber » Jan 13 2021 8:17pm
Thanks odogster..
Odogster wrote:
Jan 13 2021 4:42pm
Odogster wrote:
Jan 13 2021 3:52pm
FL bomber wrote:
Jan 12 2021 7:48pm
Thanks 👍
amberwolf   100 GW
Post by amberwolf » Jan 13 2021 8:33pm
Odogster wrote:
Jan 13 2021 3:52pm
The CA's are all compatible with all DC-powered devices, however, you may need to install an external shunt between battery and controller to measure current, if the controller you wish to use doesnt' have it's internal shunt wired out to an external connector.
YOu can buy those from Grin Tech prewired for the CA's typically-used connectors, or you can buy one elsewhere and wire it up yourself to the appropriate type of connector for your specific CA.
In any case, whether you use the controller's internal shunt or an exernal one, you need to know the new shunt resistance in milliohms, so you can change your CA's settings to match that, so the current readings are correct.
FL bomber   100 W
Post by FL bomber » Jan 14 2021 9:56am
amberwolf wrote:
Jan 13 2021 8:33pm
Odogster wrote:
Jan 13 2021 3:52pm
👍 Thanks for the info
FL bomber   100 W
Post by FL bomber » Jan 14 2021 9:58am
I'm thinking of pre-ordering power velocities 24fet.
FL bomber   100 W
Post by FL bomber » Jan 14 2021 10:24am
FL bomber wrote:
Jan 14 2021 9:58am
I mean the Next Gen FOC controller.
Post by Theodore Voltaire » Jan 14 2021 11:01am
FL bomber wrote:
Jan 14 2021 10:24am
FL bomber wrote:
Jan 14 2021 9:58am
That looks like a good one FL. It says it has, "Adjustable magnetic flux weakening for higher speeds and efficiency" I don't know anything about it, but it sounds interesting.
http://powervelocity.com/home/55-24f-15 ... mable.html
Post by Theodore Voltaire » Jan 14 2021 4:43pm
This is the antenna deployed, but the cloaking turned off. The second picture is with it activated.
Post by Theodore Voltaire » Jan 14 2021 7:25pm
Man you got to check this bike out. Storm Sondors just blew up the eMotorcycle market. $5000
6BG8fFma6nM&feature=emb_title
Odogster   100 mW
Post by Odogster » Jan 15 2021 6:20pm
Anyone know about the Shinko issue I mentioned above. I’m stuck with a couple of Shinko tires and wound up ordering Razorbacks
