Show off your Ebike creation here.
StudRock   100 W
Re: E-S Stealth Electric Bike Owners
Post by StudRock » Sep 09 2021 12:58pm
@abv - Thank you for sending over that link. I ordered the second kit that you sent over. I'm telling you I search and search all over for the JST 8 pin kits and couldn't find them. I'm going to give those a shot. They should be here on Saturday.
Thank you... No, the temp sensor was mounted that way from the factory. The only thing I did was the Phase wires.
1abv   100 kW
Post by 1abv » Sep 12 2021 3:28pm
More night riding...
StudRock   100 W
Post by StudRock » Sep 14 2021 5:40pm
Well... here is the update..
I was able to finally wire up the rest of the Hall & Temp wires in today and test everything out.
COMPLETED - The New 10 awg Phase wires and XT150 connectors installed
COMPLETED - Strap all of the wires down to the hub, heat shrink and revarnish everything
COMPLETED - Drill & Tap filler holes in hub cover
PENDING - Find and order Ferro Fluid
PENDING DELIVERY - HubSinks and Install ETA 9/20
COMPLETED - Put everything back together, say a little prayer and test
GOOD NEWS - Just about everything worked..!! I'll explain in a second
- Everything powered up fine and a little twist of throttle and all was good..VERY HAPPY..!!
- I didn't take it for a test drive yet, however, there was no delay, no hesitation, and the wheel spun strong.
ISSUE - After I connected everything back up, I turn the key on and everything was fine. the DC1 prompted me for my pass-code and ONLY the Up arrow and Menu button would work. The DOWN button and OK button would not. I had to hit the up arrow to each of the codes and wait 30 seconds or so for it to go to the next code so I can hit the number.
So I took the DC1 back out and took it apart to inspect
- I can feel a good "depress" of ALL of the buttons. I can hear & feel them click fine
- I sprayed a little T9 lubricant on each of the buttons
- I dont see or smell anything burnt on the circuit board
- The ribbon cable was all the way in and also in great shape
- The connector pins are also all tight and fully in the connector
- I reseated the thing about 10 times
- When you depress the Up arrow or the Menu button, you hear an audible beep, however, when you depress the Down Arrow or OK button you can "Feel" the button being depressed, but you dont hear anything
Any idea's...?
StudRock   100 W
Post by StudRock » Sep 15 2021 7:54am
Anyone's help or suggestions would be greatly appreciated. With the exception of this DC1, everything else appears to be working normally. I've also reached out to Stealth support as well. I'm still waiting to hear back. I'm also going to try and contact some Stealth dealers here in the US as well to see if these can be purchased or not.
Thoughts...?
1abv   100 kW
Post by 1abv » Sep 15 2021 3:39pm
This was from a little while ago not sure If I posted it before...
As far as your DC1 situation. Sorry man I have nothing for ya. I don't have one. good luck!
StudRock   100 W
Post by StudRock » Sep 16 2021 7:41am
Beautiful photo... I wish I had trails like that in my area on the east coast.
No worries about the DC1, I just hope I can find some support on it, or get it replaced (if I can).. I have a few calls out to people and and an email to Stealth, but I've not heard anything back as of yet. I'm not sure what my options are if I can't get this DC1 fixed or replaced.
I've been reading the posts in the (705-718 post pages) about some of you guys upgrading your controllers & battery packs for a little more performance. I may have to consider that as an option if I can't get this DC1 issue worked out. Plus it's always nice to get a little more performance out of the Bomber...
Rix   100 GW
Post by Rix » Sep 16 2021 1:24pm
StudRock wrote:
Sep 16 2021 7:41am
Whats your Bomber's frame #?
Edit: Never mind, its 744.
StudRock   100 W
Post by StudRock » Sep 16 2021 2:15pm
Yup... my build # is 744...
Thanks Rick..!!
Golfer-Electric   1 mW
Post by Golfer-Electric » Sep 16 2021 6:00pm
Can anybody out there help me troubleshoot my stealth bomber. I picked one up that wasn’t working a while back. It is an original. Bike #69. I ordered a new battery because the old one was only 20v. I got the new battery and connected it. Cycle analyst lit up fine. I lifted the rear wheel off the ground and hit the throttle. Seemed to be fine. When I went to ride it I realized a problem. When you hit the throttle it initially has great power but then it intermittently cuts in and out. I’m thinking throttle or controller. Any ideas?
StudRock   100 W
Post by StudRock » Sep 17 2021 11:33am
@Golfer....
I have to say, there are a LOT of knowledgeable people on here that I'm sure that can help you out. If I had to speculate, I would start by checking all of the connections. I recently had an issue with my hall wire connector. Since its intermittent, it would imply a loose or damaged wire.
I would remove and clean & inspect the connectors/pins and throw a little dielectric grease. Have you done anything to the bike recently...? I would start in that area first...
Just a thought...
Rix   100 GW
Post by Rix » Sep 17 2021 12:57pm
Golfer-Electric wrote:
Sep 16 2021 6:00pm
On these old bombers, they factory limited power by having a closed loop wire coming out of the CA. To get full power, the owner would have to pull off the side cover look up under the frame where the CA is, and cut the wire. Sounds like thats what you got going on.
Rix   100 GW
Post by Rix » Sep 17 2021 1:09pm
Here is a pic
power limit wire.jpg (258.84 KiB) Viewed 54 times
StudRock   100 W
Post by StudRock » Sep 17 2021 1:16pm
Interesting Rix... I didn't realize that would cause that type of issue..
1abv   100 kW
Post by 1abv » Sep 17 2021 10:21pm
Peekaboo
StudRock   100 W
Post by StudRock » Sep 18 2021 6:56am
1abv... you sure love the night riding...!! - I guess the temperature is cooler at night out there..
1abv   100 kW
Post by 1abv » Sep 19 2021 11:55am
from a ride earlier this year...
